    [Plugin] ToolbarBuilder
    32 Posts 9 Posters 3.3k Views 9 Watching
    • KrisidiousK Offline
      Krisidious
      I have an input on that solution... Where is my invoice? I can't find it.
      By: Kristoff Rand
      • panixiaP Offline
        panixia
        i don't know how it works, i've been using this for quite a while and it works fine, and the toolbars keep the saved position.. but it loads only native tools.. 😒
        http://sketchucation.com/forums/viewtopic.php?t=10041
          Aerilius
          Jim's custom toolbars create "clones" of the native tools. Immediately after they have been created, he adds them to toolbars.
          The problem with custom toolbars from other plugins is not to add them too early (when commands are missing) and not too late (when SketchUp doesn't remember the toolbar's last position).
          • F Offline
            function
            pressing the save button does nothing for me 😕
            • renderizaR Offline
              renderiza
              If you have SketchUp Free Version you might need to do this...
              1. Open your default Plugin Folder.
              2. Make New Folder with name "Toolbars"
              3. Try Plugin Again.
              Cheers!
              [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
              • F Offline
                function
                ah that did it! thanks
                  Check you have FULL read/write security permissions to the Plugins folder, the manual creation of the subfolder might have fixed it for now but without FULL rights you will get problems with some scripts...
                  • H Offline
                    hebeijianke
                    Hope it can support chinese language
                    add some strings
                    <!DOCTYPE html>
                    <html lang="en-US">
                    <head>
                    [highlight=#ff4040:2056xzo0]<meta http-equiv="content-type" content="text/html;charset=utf-8">[/highlight:2056xzo0]
                    	<title>Smustard ToolbarBuilder</title>
                    	<style type="text/css">
                      RickW
                      Version 1.0.2 is now uploaded. I added a third button that loads all saved custom toolbars with a single click.
                      The problem with generating the buttons at SU launch is that not all .rb files have been loaded when ToolbarBuilder loads, and thus some commands have not been created. This causes errors when the plugin attempts to create the buttons. I will continue to explore possible resolutions to this issue.
                      RickW
                      [www.smustard.com](http://www.smustard.com)
                        Krisidious
                        How do we make custom bars for plugins that are not listed?
                        By: Kristoff Rand
                          RickW
                          I'll have to investigate that one. Right now, the plugin queries Toolbars and Command items to generate its list of items for customization. I'll have to see if there's a way to query (usually older) plugins that don't use the Command structure for creating their menu items.
                          EDIT: Are there any in particular that you don't see?
                          RickW
                            Krisidious
                            The one's I'm interested in making toolbars for are SDM tools, Vali Architect and ThomThom's many plugins
                            By: Kristoff Rand
                              RickW
                              Version 1.0.3 is now online, which has full autoloading of saved toolbars at launch, and they remember their positions!
                              Now to investigate Krisidious's request...
                              RickW
                              • panixiaP Offline
                                panixia
                                i can't see the wire tool button
                                • F Offline
                                  function
                                  Having trouble saving in the new version. I did a clean install of the new sketchup, upgraded to IE 10, turned off all firewalls and made sure the folders all have full read/write. The new version also does not show ordinary sketchup commands.
                                    RickW
                                    That is correct. It can only address Ruby commands created with UI::Command. Plugins that do not use this (i.e., they create menu items only), will not be available. This is a limitation of the Ruby API.
                                    RickW
                                      RickW
                                      Strange, it appears on my machine. Try opening the Ruby console before launching the WebDialog and see if there are any messages.
                                      WebDialog
                                      Resulting Toolbar
                                      RickW
                                      • F Offline
                                        function
                                        can't save to Toolbars folder
                                        ToolbarBuilder callback ; save
                                        Error; #<NameError; undefined local variable or method `d' for #<Smustard;;ToolbarBuilder;0xb369--->>
                                        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ToolbarBuilderPro.rb;283;in `write_file'
                                        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ToolbarBuilderPro.rb;258;in `create_html'
                                        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ToolbarBuilderPro.rb;283;in `call'
                                          RickW
                                          I'll look into it.
                                          EDIT: fixed (had a variable left over from command line testing, converted it to the "real" variable).
                                          Download 1.0.5 for the fix.
                                          RickW
                                          • 2 / 2
