    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.1m Views 254 Watching
      slapfoot
      @ineshtine said:
      Yes, indeed. But this is not the problem. The real problem is, the grass generation is not evenly distributed (sometimes). There is more grass on some areas (looks like big triangles). It does this with the green dots, and also when making the fur.
      I have a suggestion. Can you implement clipping for the crowd? If we use a wide object instead of a tall object (like people), they go over the face edges. It would be nice if they clip, or moves inside so they don't go over the edges.
      BTW, Thanks for this fantastic plugin, I love it.
      Anyone have a solution to this problem? I've encountered the same issue. Even just drawing a simple rectangle and generating the grass - the fur is concentrated in these triangle shapes.
        slapfoot
        "The real problem is, the grass generation is not evenly distributed (sometimes). There is more grass on some areas (looks like big triangles). It does this with the green dots, and also when making the fur."
        Any solution to this issue yet? I'm experiencing the same problem (using SK8 if that helps). Even when generating fur on a simple rectangular face - the fur distributes unevenly into these weird triangles. So i'll be left with fur concentrated triangles and then more sparse regions. Any help would be most appreciated!
        • slapfoot
          tak2hata
          • slapfoot
          Hi,slapfoot.
          The generating method was not improved.
          Please set the large value to "MaxNumber(/Face) :".
          But too many furs will make the model file size too large.
          Please notice about this.
          by TAK2HATA
            cricrichan1984
            Thank you!! πŸ˜„
            That a sweet plugin
              jujepoy
              where to download?
                @jujepoy said:
                where to download?
                In the first post on the first page of this thread.
                  cucumuda
                  how to i get the plugin?
                  can u tell me how to download the plugin.... πŸ˜„
                  the plugin very nice....
                    Click on this link πŸ˜‰
                    it's the same than the current version that you can find on the first post of this thread!
                    Download it Unzip and put it on the Plugins folder!
                      jujepoy
                      pls help me where to download this plug.in
                      • massimoM Offline
                        massimo Moderator
                        Go to the very first post of the thread and scroll down a bit the page. Is there.
                          ATBP
                          Very nice.
                            Latetzki
                            What can I do to make this more precise so it wont place anything outside the selected face??
                              DavorP
                              Plugin is great but I have a problem. I use previously modeled component as fur instance. What happens is that each component that fur drops is inverted. How can I make sure this does not happen?
                                DavorP
                                You could use offset tool to make the area smaller. If the component is proprely centered on origin then measure the horizontal distance from origin to the farthest point of component geometry. Use that value to offset the boundary. If you have surface use offset on surface tool.
                                  tak2hata
                                  Hi,Davor.
                                  I guess that problem....
                                  Fur brade may up to Z aixis in the component.
                                  so I think your component is filpped for Z axis.
                                  or Your selected face for making fur is flipped.
                                  The Selected Face must directed to upward for you want.
                                  or The value of Force(Z) is too strong.
                                  Is your case there?
                                  Hi,Latetzki.
                                  I think like as Davor's,too.
                                  Fur is created on the points of selected face.
                                  But,The blade of fur has width.
                                  offset the face if you want more precise inside.
                                  Thanks.
                                  by TAK2HATA
                                    tak2hata
                                    Hi,All.
                                    I update to version2.0.1 in 2013.06.02.
                                    UI is improved.
                                    Hi,zieios.
                                    The icon is pretty cool! 😍
                                    Fur will be grown thick on sketchup!
                                    Thanks.
                                    by TAK2HATA
                                      Anton_S
                                      Amazing plugin!!!
                                      I just got a hair cut, and didn't know how to fullfill my hair.
                                      But, now I found a way
                                      Thank you 😎
                                        pepa
                                        Thanks for update, there is a czech translation.
                                        fur_lang_cz.txt
                                        http://jsvizualizace.daportfolio.com/
                                          tak2hata
                                          Hi,All.
                                          Now I place the new language files in language folder.
                                          fur_lang_farsi.txt:Persian translation by Majid.Thanks!
                                          fur_lang_cz.txt:Czech translation by Pepa.Thanks!
                                          Hi,Anton!
                                          Nice hair!
                                          I wish if I had hair like him.
                                          It will need too much hair spray.
                                          by TAK2HATA
                                          • majidM Offline
                                            majid
                                            Thank you for update and new interface 😍 πŸ‘
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 32
                                            • 33
                                            • 12 / 33
