    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.3m Views 254 Watching
      cas_123
      I did but it doesn't work πŸ˜•
      • IneshtineI Offline
        Ineshtine
        Make sure that the fur_en folder and the fur_en.rb file is in your ..*Sketchup\Plugins* folder and re-start Sketchup if it was already opened.
        if that doesn't work still, then let me ask.. what doesn't work? The fur plugin? or it's not in your Plugin menu? Give me some clues.
        What? you haven't tried Raylectron yet?
          cas_123
          Thank you very much, the problem was that I had it all in fur_en15a folder (not.zip), instead of having it autonomously in Plugins folder, now it works, thanks a lot and sorry for keeping on at you.
          • Z Offline
            Zacchia
            Thanks for this very helpful plugin! I will use it for carpets.
            Is it possilbe to delete a preset I saved ? How?
              slapfoot
              @ineshtine said:
              Yes, indeed. But this is not the problem. The real problem is, the grass generation is not evenly distributed (sometimes). There is more grass on some areas (looks like big triangles). It does this with the green dots, and also when making the fur.
              I have a suggestion. Can you implement clipping for the crowd? If we use a wide object instead of a tall object (like people), they go over the face edges. It would be nice if they clip, or moves inside so they don't go over the edges.
              BTW, Thanks for this fantastic plugin, I love it.
              Anyone have a solution to this problem? I've encountered the same issue. Even just drawing a simple rectangle and generating the grass - the fur is concentrated in these triangle shapes.
                slapfoot
                "The real problem is, the grass generation is not evenly distributed (sometimes). There is more grass on some areas (looks like big triangles). It does this with the green dots, and also when making the fur."
                Any solution to this issue yet? I'm experiencing the same problem (using SK8 if that helps). Even when generating fur on a simple rectangular face - the fur distributes unevenly into these weird triangles. So i'll be left with fur concentrated triangles and then more sparse regions. Any help would be most appreciated!
                • slapfoot
                  tak2hata
                  • slapfoot
                  Hi,slapfoot.
                  The generating method was not improved.
                  Please set the large value to "MaxNumber(/Face) :".
                  But too many furs will make the model file size too large.
                  Please notice about this.
                  by TAK2HATA
                    cricrichan1984
                    Thank you!! πŸ˜„
                    That a sweet plugin
                      jujepoy
                      where to download?
                        @jujepoy said:
                        where to download?
                        In the first post on the first page of this thread.
                          cucumuda
                          how to i get the plugin?
                          can u tell me how to download the plugin.... πŸ˜„
                          the plugin very nice....
                            Click on this link πŸ˜‰
                            it's the same than the current version that you can find on the first post of this thread!
                            Download it Unzip and put it on the Plugins folder!
                              jujepoy
                              pls help me where to download this plug.in
                              • massimoM Offline
                                massimo Moderator
                                Go to the very first post of the thread and scroll down a bit the page. Is there.
                                  ATBP
                                  Very nice.
                                    Latetzki
                                    What can I do to make this more precise so it wont place anything outside the selected face??
                                      DavorP
                                      Plugin is great but I have a problem. I use previously modeled component as fur instance. What happens is that each component that fur drops is inverted. How can I make sure this does not happen?
                                        DavorP
                                        You could use offset tool to make the area smaller. If the component is proprely centered on origin then measure the horizontal distance from origin to the farthest point of component geometry. Use that value to offset the boundary. If you have surface use offset on surface tool.
                                          tak2hata
                                          Hi,Davor.
                                          I guess that problem....
                                          Fur brade may up to Z aixis in the component.
                                          so I think your component is filpped for Z axis.
                                          or Your selected face for making fur is flipped.
                                          The Selected Face must directed to upward for you want.
                                          or The value of Force(Z) is too strong.
                                          Is your case there?
                                          Hi,Latetzki.
                                          I think like as Davor's,too.
                                          Fur is created on the points of selected face.
                                          But,The blade of fur has width.
                                          offset the face if you want more precise inside.
                                          Thanks.
                                          by TAK2HATA
                                            tak2hata
                                            Hi,All.
                                            I update to version2.0.1 in 2013.06.02.
                                            UI is improved.
                                            Hi,zieios.
                                            The icon is pretty cool! 😍
                                            Fur will be grown thick on sketchup!
                                            Thanks.
                                            by TAK2HATA
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 32
                                            • 33
                                            • 24 / 33
