    Fastest rotation?
    26 Posts 13 Posters 2.2k Views 13 Watching
    • jeff hammondJ
      use the move tool (at least in this particular instance)
      [edit]
      • soloS
        In theory one should be able to use 'smartdrop', as the bounding box is alignedb (but does not), this works in Vue by simply lifting it above flat surface and smart dropping it.
        • cottyC
          cotty
          @wo3dan said:
          ... is only correct along blue.
          That was the only goal.
          my SketchUp gallery
            Align Tool 3D By Didier Bur ?
            http://sketchuppluginreviews.com/wp-content/uploads/2010/05/align_tool_small.gif
            Draw a Plane wished as second end Object
            and now just 5 clicks ๐Ÿ˜„
            • Wo3DanW
              Wo3Dan
              Clever underestimated solution!
              The tool lets you align to any current drawing axes with input 0, 90 etc. (degrees)
              • cottyC
                cotty
                ๐Ÿ‘ Didn't try this one but have to...
                This will only work if the group was created before the rotations but if this is the case, it is very fast too.
                Didn't work for me in this case.
                my SketchUp gallery
                • mitcorbM
                  mitcorb
                  In case you folks didn't notice, Pilou has updated his post with a demo sequence.
                  • sdmitchS
                    sdmitch
                    Using the Ruby Console
                    Sketchup.active_model.selection.first.transformation=Geom;;Transformation.new
                    http://sdmitch.blogspot.com/
                      About the 3D Align tool by DIdier Bur above. ๐Ÿค“
                      And works also even the object is not a group or a component!
                      So just a selection of something is sufficient! ๐Ÿ˜‰
                      • cottyC
                        cotty
                        I will call it an expert solution ๐Ÿ‘
                        Did I say that I love this forum? โ˜€
                        my SketchUp gallery
                          As always, there's more than one way to do this. Some great options offered. Here's another one just for the heck of it.
                          Assuming the cylinder is just loose geometry to start, make it a component, change it's axes so the bounding box is aligned to the geometry with the blue axis in the desired up direction. Bring in a copy of the component from the In Model Component library.
                          • T
                            Trogluddite
                            Easy - just open the previous version of your project that you saved before going nuts making the geometry all wonky! ๐Ÿ˜†
                              In this particular start position Sketchyphics can also works! ๐Ÿ’š
                              • Jean LemireJ
                                Jean Lemire
                                Hi folks.
                                If you want to practice with native tools, it takes only two quickly done rotations.
                                Don't forget this trick from the help:
                                Error 404 (Not Found)!!1
                                (support.google.com)
                                See this SU file for ideas:
                                fastest_rotation - V6 - JL.skp
                                • cottyC
                                  cotty
                                  ๐Ÿ‘
                                  my SketchUp gallery
                                    Or 3 rotations if the volume was more bad oriented! ๐Ÿ˜„
                                    • utilerU
                                      utiler
                                      @jean lemire said:
                                      Hi folks.
                                      What Jean said. Best tool! ๐Ÿ‘
                                      Just Curious...
                                      • Jean LemireJ
                                        Jean Lemire
                                        Hi folks.
                                        Another quick method based on Gerrit's (Wo3Dan's idea).
                                        Two variants shown in the 2 scenes of this SU file:
                                        fastest_rotation-2 - V6 - JL.skp
                                        Just ideas.
                                          3eighty
                                          Use the rotate function in the Mover2 Plugin..
                                          • dukejazzD
                                            dukejazz
                                            Hey
                                            One component already on the orgin plane this make it easy to do,
                                            if you have scaleGroupFloat_dj.rb loaded.
                                            target save and move meathod:
                                            step 1: Make one component unique. (right click to context list)
                                            step 2: 1-time left click of the component you want to change. Save target, via scaleGroupFloat_dj (press ok).
                                            step 3: 2-times left click set axes to component and 3-times more edit select the object of the component . Using the Move to target, via scaleGroupFloat_dj.(press ok), will auto aline component to orgin plain. Now select ouside of component now your done.
                                            All above steps is shown here
                                            If both were non aline to orgin plain then do other with step two and three too.
                                            Advance woking of this; just add the axes tool into the mix. then turning object is just a breeze, for those tools that needs to be aline to x-y plain for z axis drops .
                                            examples usesages to
                                            [Plugin] Color by Z
                                            drop
                                            sandbox.rb
                                            smartdrop.rb
                                            TIG-drapematerials.rb
                                            TIG-Drop Material onto Instances
                                            tt_component_dropper
