    Fastest rotation?
    26 Posts 13 Posters 2.0k Views 13 Watching
    • Wo3DanW
      Wo3Dan
      (Even faster with a scene according to the groups local axes)
      Open the group > save a scene with its local axes saved (only these axes matter).
      Close group.
      Select saved scene > copy model to clipboard > reset axes to systems axes,
      Paste clipboard content to model again. It will be according to resetted (=systems) axes.
      • cottyC
        cotty
        Close group.
        👍 very fast! 😲
        (I know I have to bookmark this because I will forget the exact steps in about 10 minutes 😎 )
        my SketchUp gallery
        • Wo3DanW
          Wo3Dan
          @cotty said:
          I think the step "place it on ground plane" should change the orientation of the group? This step doesn't work for me... 😕 ...
          (I also thought of your solution, using one of the hidden lined on the side.)
          If you mean that new green and red of the rotated group should be aligned according to their previous projection on the ground plane, then you might be right, then my 'Glue to: any' component is only correct along blue. Then you need some extra marks for a final rotation about systems blue axis.
          Is this restriction included?
          • jeff hammondJ
            use the move tool (at least in this particular instance)
            [edit]
            • soloS
              In theory one should be able to use 'smartdrop', as the bounding box is alignedb (but does not), this works in Vue by simply lifting it above flat surface and smart dropping it.
              • cottyC
                cotty
                @wo3dan said:
                ... is only correct along blue.
                That was the only goal.
                my SketchUp gallery
                  Align Tool 3D By Didier Bur ?
                  http://sketchuppluginreviews.com/wp-content/uploads/2010/05/align_tool_small.gif
                  Draw a Plane wished as second end Object
                  and now just 5 clicks 😄
                  • Wo3DanW
                    Wo3Dan
                    Clever underestimated solution!
                    The tool lets you align to any current drawing axes with input 0, 90 etc. (degrees)
                    • cottyC
                      cotty
                      👍 Didn't try this one but have to...
                      This will only work if the group was created before the rotations but if this is the case, it is very fast too.
                      Didn't work for me in this case.
                      my SketchUp gallery
                      • mitcorbM
                        mitcorb
                        In case you folks didn't notice, Pilou has updated his post with a demo sequence.
                        • sdmitchS
                          sdmitch
                          Using the Ruby Console
                          Sketchup.active_model.selection.first.transformation=Geom;;Transformation.new
                          http://sdmitch.blogspot.com/
                            About the 3D Align tool by DIdier Bur above. 🤓
                            And works also even the object is not a group or a component!
                            So just a selection of something is sufficient! 😉
                            • cottyC
                              cotty
                              I will call it an expert solution 👍
                              Did I say that I love this forum? ☀
                              my SketchUp gallery
                                As always, there's more than one way to do this. Some great options offered. Here's another one just for the heck of it.
                                Assuming the cylinder is just loose geometry to start, make it a component, change it's axes so the bounding box is aligned to the geometry with the blue axis in the desired up direction. Bring in a copy of the component from the In Model Component library.
                                • T
                                  Trogluddite
                                  Easy - just open the previous version of your project that you saved before going nuts making the geometry all wonky! 😆
                                    In this particular start position Sketchyphics can also works! 💚
                                    • Jean LemireJ
                                      Jean Lemire
                                      Hi folks.
                                      If you want to practice with native tools, it takes only two quickly done rotations.
                                      Don't forget this trick from the help:
                                      Error 404 (Not Found)!!1
                                      (support.google.com)
                                      See this SU file for ideas:
                                      fastest_rotation - V6 - JL.skp
                                      • cottyC
                                        cotty
                                        my SketchUp gallery
                                          Or 3 rotations if the volume was more bad oriented! 😄
                                          • utilerU
                                            utiler
                                            @jean lemire said:
                                            Hi folks.
                                            What Jean said. Best tool! 👍
                                            Just Curious...
