    Fastest rotation?
    26 Posts 13 Posters 2.2k Views 13 Watching
    • cottyC
      cotty
      @sdmitch said:
      Using the Ruby Console
      Sketchup.active_model.selection.first.transformation=Geom;;Transformation.new
      I will call it an expert solution πŸ‘
      Did I say that I love this forum? β˜€
      my SketchUp gallery
        As always, there's more than one way to do this. Some great options offered. Here's another one just for the heck of it.
        Assuming the cylinder is just loose geometry to start, make it a component, change it's axes so the bounding box is aligned to the geometry with the blue axis in the desired up direction. Bring in a copy of the component from the In Model Component library.
        • T
          Trogluddite
          Easy - just open the previous version of your project that you saved before going nuts making the geometry all wonky! πŸ˜†
            In this particular start position Sketchyphics can also works! πŸ’š
            • Jean LemireJ
              Jean Lemire
              Hi folks.
              If you want to practice with native tools, it takes only two quickly done rotations.
              Don't forget this trick from the help:
              Error 404 (Not Found)!!1
              (support.google.com)
              See this SU file for ideas:
              fastest_rotation - V6 - JL.skp
              • cottyC
                cotty
                πŸ‘
                my SketchUp gallery
                  Or 3 rotations if the volume was more bad oriented! πŸ˜„
                  • utilerU
                    utiler
                    @jean lemire said:
                    Hi folks.
                    What Jean said. Best tool! πŸ‘
                    Just Curious...
                    • Jean LemireJ
                      Jean Lemire
                      Hi folks.
                      Another quick method based on Gerrit's (Wo3Dan's idea).
                      Two variants shown in the 2 scenes of this SU file:
                      fastest_rotation-2 - V6 - JL.skp
                      Just ideas.
                        3eighty
                        Use the rotate function in the Mover2 Plugin..
                        • dukejazzD
                          dukejazz
                          Hey
                          One component already on the orgin plane this make it easy to do,
                          if you have scaleGroupFloat_dj.rb loaded.
                          target save and move meathod:
                          step 1: Make one component unique. (right click to context list)
                          step 2: 1-time left click of the component you want to change. Save target, via scaleGroupFloat_dj (press ok).
                          step 3: 2-times left click set axes to component and 3-times more edit select the object of the component . Using the Move to target, via scaleGroupFloat_dj.(press ok), will auto aline component to orgin plain. Now select ouside of component now your done.
                          All above steps is shown here
                          If both were non aline to orgin plain then do other with step two and three too.
                          Advance woking of this; just add the axes tool into the mix. then turning object is just a breeze, for those tools that needs to be aline to x-y plain for z axis drops .
                          examples usesages to
                          [Plugin] Color by Z
                          drop
                          sandbox.rb
                          smartdrop.rb
                          TIG-drapematerials.rb
                          TIG-Drop Material onto Instances
                          tt_component_dropper
                          • 2 / 2
