    Fastest rotation?
    26 Posts 13 Posters 2.2k Views 13 Watching
    • cottyC
      cotty
      @wo3dan said:
      ... is only correct along blue.
      That was the only goal.
      my SketchUp gallery
        Align Tool 3D By Didier Bur ?
        http://sketchuppluginreviews.com/wp-content/uploads/2010/05/align_tool_small.gif
        Draw a Plane wished as second end Object
        and now just 5 clicks πŸ˜„
        • Wo3DanW
          Wo3Dan
          use the move tool (at least in this particular instance)
          Clever underestimated solution!
          The tool lets you align to any current drawing axes with input 0, 90 etc. (degrees)
          • cottyC
            cotty
            πŸ‘ Didn't try this one but have to...
            This will only work if the group was created before the rotations but if this is the case, it is very fast too.
            @solo said:
            In theory one should be able to use 'smartdrop'
            Didn't work for me in this case.
            my SketchUp gallery
            • mitcorbM
              mitcorb
              In case you folks didn't notice, Pilou has updated his post with a demo sequence.
              • sdmitchS
                sdmitch
                Using the Ruby Console
                Sketchup.active_model.selection.first.transformation=Geom;;Transformation.new
                http://sdmitch.blogspot.com/
                  About the 3D Align tool by DIdier Bur above. πŸ€“
                  And works also even the object is not a group or a component!
                  So just a selection of something is sufficient! πŸ˜‰
                  • cottyC
                    cotty
                    I will call it an expert solution πŸ‘
                    Did I say that I love this forum? β˜€
                    my SketchUp gallery
                      As always, there's more than one way to do this. Some great options offered. Here's another one just for the heck of it.
                      Assuming the cylinder is just loose geometry to start, make it a component, change it's axes so the bounding box is aligned to the geometry with the blue axis in the desired up direction. Bring in a copy of the component from the In Model Component library.
                      • T
                        Trogluddite
                        Easy - just open the previous version of your project that you saved before going nuts making the geometry all wonky! πŸ˜†
                          In this particular start position Sketchyphics can also works! πŸ’š
                          • Jean LemireJ
                            Jean Lemire
                            Hi folks.
                            If you want to practice with native tools, it takes only two quickly done rotations.
                            Don't forget this trick from the help:
                            Error 404 (Not Found)!!1
                            (support.google.com)
                            See this SU file for ideas:
                            fastest_rotation - V6 - JL.skp
                            • cottyC
                              cotty
                              πŸ‘
                              my SketchUp gallery
                                Or 3 rotations if the volume was more bad oriented! πŸ˜„
                                • utilerU
                                  utiler
                                  @jean lemire said:
                                  Hi folks.
                                  What Jean said. Best tool! πŸ‘
                                  Just Curious...
                                  • Jean LemireJ
                                    Jean Lemire
                                    Hi folks.
                                    Another quick method based on Gerrit's (Wo3Dan's idea).
                                    Two variants shown in the 2 scenes of this SU file:
                                    fastest_rotation-2 - V6 - JL.skp
                                    Just ideas.
                                      3eighty
                                      Use the rotate function in the Mover2 Plugin..
                                      • dukejazzD
                                        dukejazz
                                        Hey
                                        One component already on the orgin plane this make it easy to do,
                                        if you have scaleGroupFloat_dj.rb loaded.
                                        target save and move meathod:
                                        step 1: Make one component unique. (right click to context list)
                                        step 2: 1-time left click of the component you want to change. Save target, via scaleGroupFloat_dj (press ok).
                                        step 3: 2-times left click set axes to component and 3-times more edit select the object of the component . Using the Move to target, via scaleGroupFloat_dj.(press ok), will auto aline component to orgin plain. Now select ouside of component now your done.
                                        All above steps is shown here
                                        If both were non aline to orgin plain then do other with step two and three too.
                                        Advance woking of this; just add the axes tool into the mix. then turning object is just a breeze, for those tools that needs to be aline to x-y plain for z axis drops .
                                        examples usesages to
                                        [Plugin] Color by Z
                                        drop
                                        sandbox.rb
                                        smartdrop.rb
                                        TIG-drapematerials.rb
                                        TIG-Drop Material onto Instances
                                        tt_component_dropper
