    Fastest rotation?
    26 Posts 13 Posters 2.0k Views 13 Watching
      About the 3D Align tool by DIdier Bur above. πŸ€“
      And works also even the object is not a group or a component!
      So just a selection of something is sufficient! πŸ˜‰
      • cottyC
        cotty
        @sdmitch said:
        Using the Ruby Console
        Sketchup.active_model.selection.first.transformation=Geom;;Transformation.new
        I will call it an expert solution πŸ‘
        Did I say that I love this forum? β˜€
        my SketchUp gallery
          As always, there's more than one way to do this. Some great options offered. Here's another one just for the heck of it.
          Assuming the cylinder is just loose geometry to start, make it a component, change it's axes so the bounding box is aligned to the geometry with the blue axis in the desired up direction. Bring in a copy of the component from the In Model Component library.
          • T
            Trogluddite
            Easy - just open the previous version of your project that you saved before going nuts making the geometry all wonky! πŸ˜†
              In this particular start position Sketchyphics can also works! πŸ’š
              • Jean LemireJ
                Jean Lemire
                Hi folks.
                If you want to practice with native tools, it takes only two quickly done rotations.
                Don't forget this trick from the help:
                Error 404 (Not Found)!!1
                (support.google.com)
                See this SU file for ideas:
                fastest_rotation - V6 - JL.skp
                • cottyC
                  cotty
                  πŸ‘
                  my SketchUp gallery
                    Or 3 rotations if the volume was more bad oriented! πŸ˜„
                    • utilerU
                      utiler
                      @jean lemire said:
                      Hi folks.
                      What Jean said. Best tool! πŸ‘
                      Just Curious...
                      • Jean LemireJ
                        Jean Lemire
                        Hi folks.
                        Another quick method based on Gerrit's (Wo3Dan's idea).
                        Two variants shown in the 2 scenes of this SU file:
                        fastest_rotation-2 - V6 - JL.skp
                        Just ideas.
                          3eighty
                          Use the rotate function in the Mover2 Plugin..
                          • dukejazzD
                            dukejazz
                            Hey
                            One component already on the orgin plane this make it easy to do,
                            if you have scaleGroupFloat_dj.rb loaded.
                            target save and move meathod:
                            step 1: Make one component unique. (right click to context list)
                            step 2: 1-time left click of the component you want to change. Save target, via scaleGroupFloat_dj (press ok).
                            step 3: 2-times left click set axes to component and 3-times more edit select the object of the component . Using the Move to target, via scaleGroupFloat_dj.(press ok), will auto aline component to orgin plain. Now select ouside of component now your done.
                            All above steps is shown here
                            If both were non aline to orgin plain then do other with step two and three too.
                            Advance woking of this; just add the axes tool into the mix. then turning object is just a breeze, for those tools that needs to be aline to x-y plain for z axis drops .
                            examples usesages to
                            [Plugin] Color by Z
                            drop
                            sandbox.rb
                            smartdrop.rb
                            TIG-drapematerials.rb
                            TIG-Drop Material onto Instances
                            tt_component_dropper
                            • 2 / 2
