    [Plugin] Boolean--OSCoolean (Dec 2013) for SU 8 up free ver
    301 Posts 123 Posters 306.8k Views 123 Watching
    • I
      ikkim
      @j-pags said:
      I figured it out. OSCoolean does not work when sketchyphysics is enabled. At least on my computer. I disabled it, and now it's working fine.
      thanks J-pags.
      I had the same problem
      you saved my da πŸ‘
      and many thanks to oscarlok πŸŽ‰
        dickcobra
        What is the most complex objects that can be used. I am trying to make a vaulted slab but it must be too complex because it will not intersect them. it just creates some strange copies.
        If I make a simple square and a cylinder it works πŸ˜ƒ
        @N02/8392415889/" alt="http://www.flickr.com/photos/21717497@N02/8392415889/" class="img-markdown img-fluid" />
        Slab intersect Japan.skp
          Not sure if I removed the right bit...
          The Pro Solid tools work fine...
          Are you sure you are picking in the right order etc ?
          Also you could probably do this using the native Intersect tool [both Free & Pro]... combined with some judicious Erasing of unwanted geometry...
            dickcobra
            Thanks TIG,
            The Coolean plug in finally did work. Also I thought intersect was only in Pro. Ill have to look into intersect some more.
              matsambu
              Hello to everyone, this is my very first post so please mind any errors or mistakes. My OSCoolean does not seem to work. When I select the objects nothing happens. I have tried this with two simple boxes(that ar both groups) and it still doesn't work. I have removed OSCoolean and saved it again but still nothing happens.
              On the Ruby console the errors are :
              Error: #<NameError: uninitialized class variable @@select in AdditionalPluginFolder6::OSCoolean>
              (eval):330:in `onMouseMove'
              (eval):356:in set_current_point' (eval):321:in onLButtonUp'
              (eval):330
              The first appears when I move the mouse over any object and the second appers when I click the 2nd object.
              Could someone please tell me what I have done wrong or how I can fix this. Any help will be appreciated. I have SketchUp version 8.0.15158
                Sounds like AdditionalFolders might be interfering. I'm guessing it's because it's trying to load the RBS file and because of that it ends up loaded within the namespace of AdditionalPluginFolder6. Think this needs to be reported to Fredo.
                  matsambu
                  How does one report errors like these? Or, if you don't mind, can you reprt it on my behalf?Also, is there anything I can do on to fix it?
                    Just make a post in the thread for the plugin.
                    (I gave Fredo a nudge to look at this thread this time.)
                    • fredo6F
                      I just made a fix to 000_AdditionalPluginFolder, as version 3.1a
                      See this post for downloading.
                      Thanks to Thomthom and Dan Rathbun for signaling and providing solutions for fixing the issue
                        awkonradi
                        Hello All,
                        In my hands, OSCoolean generates the intersection between two overlapping cubes. But, OSCoolean does not generate the intersection between the two solids in the attached file. Is my "wing" just too complex? The "wing" is a CurviLoft output. Any reason to believe the solid tools in SU 8 Pro, or other non-free tools, would succeed?
                        I appreciate everyone's patience. I am a beginner.
                        Andrei
                        intersect these solids.skp
                          My v8Pro Solid Tools managed it OK, although some faces were reversed, but fixable...
                          If there are any tiny facets in the objects/results you can get issues...
                          intersect these solids[TIG].skp
                            awkonradi
                            TIG, thank you very much for that information.
                              joergber
                              is this plugin still maintained by anybody?
                              I would like to know if it is possible to substract an capsulated group from the surrounding one ...
                              For example by selecting the groups through the outliner (this doesn't work).
                              Or does anybody know of a manual way to do that?
                              Many thanks in advance!
                              Moin,
                              JΓΆrg
                              • gillesG
                                gilles
                                Make your groups components copy them outside with paste in place, substract and delete
                                  joergber
                                  Hi Gilles,
                                  thanks for the quick reply ...
                                  But I don't get it ...
                                  'copy them outside with paste in place' seems quite paradox to me ...
                                  Could you pls. explain again?
                                  (slowly) πŸ˜•
                                  Many thanks!!!!
                                  JΓΆrg
                                  • gillesG
                                    gilles
                                    What I understood it that you have a group inside another and you want them to substract.
                                    So making them components allow you to make copies and place those copies(instances) in a context they can interfere with each other.
                                    Paste in place make you sure their respective positions are good.
                                    Procede the boolean operation, then delete them the instances have been modified.
                                    • gillesG
                                      gilles
                                      Forget what I said before about components, this plugin only works with groups
                                        joergber
                                        thank you anyway!
                                        I tried adding an 'object' to the inner group that is not encapsulated ...
                                        So I have some kind of selector.
                                        But this doesn't work either 😞
                                        Any other suggestions?
                                        JΓΆrg
                                        • gillesG
                                          gilles
                                          But if your two groups are nested at the same level doesnt' it work?
                                          • gillesG
                                            gilles
                                            I made some tries and it seems that subtract fail and sometimes crash with two copies of the same group.
                                            could your share the model at least the two groups in their context?
                                            • 11
                                            • 12
                                            • 15
                                            • 16
                                            • 10 / 16
