    [Plugin] Boolean--OSCoolean (Dec 2013) for SU 8 up free ver
    301 Posts 123 Posters 268.1k Views 123 Watching
    • N Offline
      NickMalvern
      Sorry!
      Of course you are quite correct, and I can only apologise for what was indeed a stupid error.
      In my defence, I was having terrible trouble yesterday getting the page to load properly - and to find the downlad file at all - so I missed the obvious!
      I still haven't got any of the 'help' videos on OSC to play at a resolution that enables me to actually read anything on the screen - so I was battling with a whole host of 'unknowns' (to me!) at once.
      Now I'm trying to get my head round 'intersect' - as that may actually do what I was trying to achive. We'll see.
      As I only started on SU 2 days ago, perhaps you can forgive some initial confusion.
      Thanks very much for 'being there' and willing to help - even if.....
      • N Offline
        NickMalvern
        P.S. I mean the various UTube videos - not the basic ones on the download page
          The three main videos are linked on this page http://sketchucation.com/forums/viewtopic.php?p=112057#p112057
          Here are all of the others http://www.youtube.com/results?search_query=oscoolean&oq=oscoolean&gs_l=youtube.3..0.1259.1656.0.2397.2.2.0.0.0.0.84.131.2.2.0...0.0...1ac.1.DAAkiyBaAIA
            AtlanticSpirit
            I just cant get OSCoolean to work, I’ve tried re-loading, turning of sketchy physics, saving as groups etc and have read the related threads in search of a solution, to no avail.
            Im using v8 free version 8.0.16846
            The tool bar displays, however when I select the objects (Grouped) for dissection, click the relevant OS Coolean icon nothing happens.
            I have been using sketch up for 3 years and have never had a problem with a plug-in before...I was so pleased that this plug-in was developed, but I’m going crazy as I can’t get it to work.
            Any help would be greatly appreciated.
              Are the two groups both 'solids' ?
              Have you tried it with a simple pair of cubes that you know are 'solids' ['Entity Info' will say so].
              Any errors in the Ruby Console when you try any of this ?
              Can you post an example SKP which fails ?
              • I Offline
                ikkim
                @j-pags said:
                I figured it out. OSCoolean does not work when sketchyphysics is enabled. At least on my computer. I disabled it, and now it's working fine.
                thanks J-pags.
                I had the same problem
                you saved my da 👍
                and many thanks to oscarlok 🎉
                  dickcobra
                  What is the most complex objects that can be used. I am trying to make a vaulted slab but it must be too complex because it will not intersect them. it just creates some strange copies.
                  If I make a simple square and a cylinder it works 😃
                  @N02/8392415889/" alt="http://www.flickr.com/photos/21717497@N02/8392415889/" class=" img-fluid img-markdown" />
                  Slab intersect Japan.skp
                    Not sure if I removed the right bit...
                    The Pro Solid tools work fine...
                    Are you sure you are picking in the right order etc ?
                    Also you could probably do this using the native Intersect tool [both Free & Pro]... combined with some judicious Erasing of unwanted geometry...
                      dickcobra
                      Thanks TIG,
                      The Coolean plug in finally did work. Also I thought intersect was only in Pro. Ill have to look into intersect some more.
                        matsambu
                        Hello to everyone, this is my very first post so please mind any errors or mistakes. My OSCoolean does not seem to work. When I select the objects nothing happens. I have tried this with two simple boxes(that ar both groups) and it still doesn't work. I have removed OSCoolean and saved it again but still nothing happens.
                        On the Ruby console the errors are :
                        Error: #<NameError: uninitialized class variable @@select in AdditionalPluginFolder6::OSCoolean>
                        (eval):330:in `onMouseMove'
                        (eval):356:in set_current_point' (eval):321:in onLButtonUp'
                        (eval):330
                        The first appears when I move the mouse over any object and the second appers when I click the 2nd object.
                        Could someone please tell me what I have done wrong or how I can fix this. Any help will be appreciated. I have SketchUp version 8.0.15158
                          Sounds like AdditionalFolders might be interfering. I'm guessing it's because it's trying to load the RBS file and because of that it ends up loaded within the namespace of AdditionalPluginFolder6. Think this needs to be reported to Fredo.
                            matsambu
                            How does one report errors like these? Or, if you don't mind, can you reprt it on my behalf?Also, is there anything I can do on to fix it?
                              Just make a post in the thread for the plugin.
                              (I gave Fredo a nudge to look at this thread this time.)
                              • fredo6F Offline
                                I just made a fix to 000_AdditionalPluginFolder, as version 3.1a
                                See this post for downloading.
                                Thanks to Thomthom and Dan Rathbun for signaling and providing solutions for fixing the issue
                                  awkonradi
                                  Hello All,
                                  In my hands, OSCoolean generates the intersection between two overlapping cubes. But, OSCoolean does not generate the intersection between the two solids in the attached file. Is my "wing" just too complex? The "wing" is a CurviLoft output. Any reason to believe the solid tools in SU 8 Pro, or other non-free tools, would succeed?
                                  I appreciate everyone's patience. I am a beginner.
                                  Andrei
                                  intersect these solids.skp
                                    My v8Pro Solid Tools managed it OK, although some faces were reversed, but fixable...
                                    If there are any tiny facets in the objects/results you can get issues...
                                    intersect these solids[TIG].skp
                                      awkonradi
                                      TIG, thank you very much for that information.
                                        joergber
                                        is this plugin still maintained by anybody?
                                        I would like to know if it is possible to substract an capsulated group from the surrounding one ...
                                        For example by selecting the groups through the outliner (this doesn't work).
                                        Or does anybody know of a manual way to do that?
                                        Many thanks in advance!
                                        Moin,
                                        Jörg
                                        • gillesG Offline
                                          gilles
                                          Make your groups components copy them outside with paste in place, substract and delete
                                            joergber
                                            Hi Gilles,
                                            thanks for the quick reply ...
                                            But I don't get it ...
                                            'copy them outside with paste in place' seems quite paradox to me ...
                                            Could you pls. explain again?
                                            (slowly) 😕
                                            Many thanks!!!!
                                            Jörg
                                            • 11
                                            • 12
                                            • 15
                                            • 16
                                            • 10 / 16
