    [PLUGIN] Voronoi + Conic Curve
    140 Posts 55 Posters 252.0k Views 54 Watching
      MattC
      Yes I got it, Thanks a lot, I am a bit busy at my normal work, but plugin is still alive.
      I will try to get updated version online this weekend, but I was already focused on Voronoi2D version 2.0
      Cheers
      Matt
        MattC
        @ mitcorb - example : If You have polygon with 4 vertices, You can create 4 sets of points ([0,1,2],[1,2,3],[2,3,0],[3,0,1]).
        You can use those sets of points to create rational bezier spline(http://en.wikipedia.org/wiki/B%C3%A9zier_curve#Rational_B.C3.A9zier_curves) by asigning weight to every point.
        Special case is when You set for first and third point weight = 1 , and weight "w" for second point.
        • when w>1 then created curve is a hyperbole
        • when w=1 then created curve is a parabole
        • when w<1 then created curve is an ellipse (in special case circle)
          Hyperbole, parabole ellipse and circle are known as a conic curves or conic sections , because You can create them by cutting cone with a plane.
          For further read : http://www.cs.mtu.edu/~shene/COURSES/cs3621/NOTES/spline/NURBS/RB-conics.html
          http://en.wikipedia.org/wiki/Conic_section
        If You draw square, and apply coniccurve with weight w = sqrt(2)/2 = 0,7071, You will get a circle.
        @ Pilou - This is an implementation of 3DVoronoi - this is my next step, but at this moment I struggle a bit with a code...
        Matt
          dekay
          tanks a lot, your script is very easy to use compared to others.it has been very helpful to me.
          thank you once again..
          • V Offline
            victor hugo
            Very interesting plugin...
            where can I get the CPOINT creator or a CPOINT plugin?
            Thanks.
            • cottyC Offline
              cotty
              Thanks.
              Here
              my SketchUp gallery
                Why not put in the first post the link for the Delauney3.rb by Tig ?
                It was not so evident to find it! 😮
                here the link! 😉
                Else works fine 😄
                • I Offline
                  ivreich
                  VoronoiXY Error
                  Hi MattC
                  I'm still having problems creating a simple 2D Voronoi. Have attached the file with the cpoints and the error message.
                  Conic curve seems to work fine...
                  Cheers
                  joel
                  UPDATE: I see what the problem is. It's still the co-linear points. The plugin will not work if any of the points are colinear in either the X or Y axis.
                  Something that can be fixed?
                  SU File
                  Error message
                    And about Conic Curve
                    Does this possible ?
                      Hello
                      For the Voronoï (with SU V7 tested) images previous post
                      All works fine except I must click on the Ok Botton for have a voronoï polygon for each new polygon! 😲 😮
                      Tig triangle works for a selection of points in one pass! 👍
                      And for the conic curve : does it possible to have the same for a selection of faces ?
                      Click on each polygon is some tiedious when you have thousand of them!
                      EDIT : About Voronoï xy
                      Works fine in V8 ! ☀
                      But something must be made for the UNDO !!! 😉
                      Here you must make each CTRL+ Z for each polygon ! 😮
                        MattC
                        Hi Pilou, Hello everybody
                        Currently I am rewriting the whole Voronoi 2D plug-in.
                        It is going painfully slow, but I have a lot of other things on my head right now.
                        Why I am completely redesigning it? Well my understanding of Ruby got a bit better, and also I got some new ideas how to tackle this problem.
                        What I want to accomplish:
                        1. prepare a nice flow chart for a process of creating 2D Voronoi diagram
                        2. based on that define set of standard functions that will be used
                        3. compose final version of Voronoi 2D plug-in
                        • do steps 1-3 with 3D Voronoi
                        • do steps 1-3 with Conic Curve
                        • do steps 1-3 with random point generator (2D and 3D)
                        Shall I succeed then next step would be a "fracture tool" similar to one in Blender.
                        @ Pilou
                        So to create voronoi diagram You have to iterate through the message boxes i=1, i=2 ... etc?
                        I think that that was one of the first complains and I have disabled it in one of later versions. If not I can do it one more time. the same applies to UNDO in one step. Conic curve on all faces in selection was also made, but I don't know if it was made an official release.
                        Your last question is more complicated. Conic curve plug-in was made as a response to the topic in the first post. There You can see that there are multiple curves inside polygons. And all the polygons are convex. So the conic curve , which is a construction based on 3 points (let's say A B and C), is always located inside the smaller angle near the point B. In Your case polygon is Concave and conic curve will go outside. Is it possible to force it inside? Well it is.
                        See explanation of how the conic curve is made in first post. You have to set an offset that will sit well inside, and also play with a weight value. But in this version You cannot set different weights for every vertex. Maybe I will get to that in one of the future releases.
                        Stay tuned for more details. I will try to make a nice blog (possibly later an e-book) about it.
                        Cheers
                        Matt
                          Cool ! ☀
                          For the OK Button that must be something between V7 V8
                          not works in V7, works in V8
                          • N Offline
                            notareal
                            MattC, that sounds great! Cannot wait.
                              MattC
                              So it is officially begonnen:
                              spin-heads.blogspot.com
                              Cheers
                              Matt
                                Appetizing first page! ☀
                                  Mra
                                  Hey, nice plugin - but I do not know how to use.
                                  Every option simply brings up a cmd.exe for a millisecond and nothing ever happens.
                                  The steps in the OP are unclear to me? How do we first generate the CP points?
                                    You just draw them as you want!
                                    First image
                                    One rectangle as plane background where you draw as you want the Control points
                                    DON'T erase the "background"
                                    Select points
                                    Call the plug
                                    Select points
                                    Erase points
                                    Second image
                                    Select lines
                                    Call Lattice Maker by Tig
                                    Call Random Painter by Chris Fullmer
                                    Selection Toys for select only points by ThomThom
                                    http://www.3dsaloon.fr/phpbb3/download/file.php?id=3741&mode=view/rokbox.jpg
                                    http://www.3dsaloon.fr/phpbb3/download/file.php?id=3743
                                      Mra
                                      Thank you very much for the help.
                                      But that's the first problem I had, I'm not sure of any tool in SketchUp to draw CP points, is this a plugin? I have no issue with the rest of the steps just how to initially draw the points.
                                      • cottyC Offline
                                        cotty
                                        For this, I use the plugin point from Matt666...
                                        my SketchUp gallery
                                          Personnally I use the Old Projection Toolbar by Didier Bur for the Cpoints! 😉
                                          because there is also some crazzy tools on it : mutiple PushPull random and the crazzy
                                          Extrude line! 👍
                                          old Projection
                                            Mra
                                            • 3 / 7
