    [PLUGIN] Voronoi + Conic Curve
    140 Posts 55 Posters 256.2k Views 54 Watching
      dtolios
      @mattc said:
      Pilou You 're teasing me ๐Ÿ˜„
      Is it Sketchup ??
      Or something else?
      Well only step that I miss from those, is generation of 3D Voronoi ๐Ÿ˜„
      For rest I have plugins already.
      @ Joel, indeed there WAS a problem - file in first message is updated.
      Matt
      Would it be too much to ask for 3D Voronoi?
      I would be in...even if not for free... ๐Ÿ‘
        MattC
        Well... I think 2D voronoi package (delauney triangulation by TIG + Voronoi on XY plane + Conic Curve + Convex hull on XY plane) is almost ready.
        Next step will be: (delauney triangulation in 3D + Voronoi 3D + Conic Curve + Convex hull 3D).
        But it is a lot more complicated.
        So it is a bit to early to decide free / paid - but I think donationware ( if You like it - gratify creator) is the way to go.
        Cheers
        Matt
          the.pjt
          hello Matt, did you got the Icons ? ... or a more important question: is this plugin still alive ?
            MattC
            Yes I got it, Thanks a lot, I am a bit busy at my normal work, but plugin is still alive.
            I will try to get updated version online this weekend, but I was already focused on Voronoi2D version 2.0
            Cheers
            Matt
              MattC
              @ mitcorb - example : If You have polygon with 4 vertices, You can create 4 sets of points ([0,1,2],[1,2,3],[2,3,0],[3,0,1]).
              You can use those sets of points to create rational bezier spline(http://en.wikipedia.org/wiki/B%C3%A9zier_curve#Rational_B.C3.A9zier_curves) by asigning weight to every point.
              Special case is when You set for first and third point weight = 1 , and weight "w" for second point.
              • when w>1 then created curve is a hyperbole
              • when w=1 then created curve is a parabole
              • when w<1 then created curve is an ellipse (in special case circle)
                Hyperbole, parabole ellipse and circle are known as a conic curves or conic sections , because You can create them by cutting cone with a plane.
                For further read : http://www.cs.mtu.edu/~shene/COURSES/cs3621/NOTES/spline/NURBS/RB-conics.html
                http://en.wikipedia.org/wiki/Conic_section
              If You draw square, and apply coniccurve with weight w = sqrt(2)/2 = 0,7071, You will get a circle.
              @ Pilou - This is an implementation of 3DVoronoi - this is my next step, but at this moment I struggle a bit with a code...
              Matt
                dekay
                tanks a lot, your script is very easy to use compared to others.it has been very helpful to me.
                thank you once again..
                • V Offline
                  victor hugo
                  Very interesting plugin...
                  where can I get the CPOINT creator or a CPOINT plugin?
                  Thanks.
                  • cottyC Offline
                    cotty
                    Thanks.
                    Here
                    my SketchUp gallery
                      Why not put in the first post the link for the Delauney3.rb by Tig ?
                      It was not so evident to find it! ๐Ÿ˜ฎ
                      here the link! ๐Ÿ˜‰
                      Else works fine ๐Ÿ˜„
                      • I Offline
                        ivreich
                        VoronoiXY Error
                        Hi MattC
                        I'm still having problems creating a simple 2D Voronoi. Have attached the file with the cpoints and the error message.
                        Conic curve seems to work fine...
                        Cheers
                        joel
                        UPDATE: I see what the problem is. It's still the co-linear points. The plugin will not work if any of the points are colinear in either the X or Y axis.
                        Something that can be fixed?
                        SU File
                        Error message
                          And about Conic Curve
                          Does this possible ?
                            Hello
                            For the Voronoรฏ (with SU V7 tested) images previous post
                            All works fine except I must click on the Ok Botton for have a voronoรฏ polygon for each new polygon! ๐Ÿ˜ฒ ๐Ÿ˜ฎ
                            Tig triangle works for a selection of points in one pass! ๐Ÿ‘
                            And for the conic curve : does it possible to have the same for a selection of faces ?
                            Click on each polygon is some tiedious when you have thousand of them!
                            EDIT : About Voronoรฏ xy
                            Works fine in V8 ! โ˜€
                            But something must be made for the UNDO !!! ๐Ÿ˜‰
                            Here you must make each CTRL+ Z for each polygon ! ๐Ÿ˜ฎ
                              MattC
                              Hi Pilou, Hello everybody
                              Currently I am rewriting the whole Voronoi 2D plug-in.
                              It is going painfully slow, but I have a lot of other things on my head right now.
                              Why I am completely redesigning it? Well my understanding of Ruby got a bit better, and also I got some new ideas how to tackle this problem.
                              What I want to accomplish:
                              1. prepare a nice flow chart for a process of creating 2D Voronoi diagram
                              2. based on that define set of standard functions that will be used
                              3. compose final version of Voronoi 2D plug-in
                              • do steps 1-3 with 3D Voronoi
                              • do steps 1-3 with Conic Curve
                              • do steps 1-3 with random point generator (2D and 3D)
                              Shall I succeed then next step would be a "fracture tool" similar to one in Blender.
                              @ Pilou
                              So to create voronoi diagram You have to iterate through the message boxes i=1, i=2 ... etc?
                              I think that that was one of the first complains and I have disabled it in one of later versions. If not I can do it one more time. the same applies to UNDO in one step. Conic curve on all faces in selection was also made, but I don't know if it was made an official release.
                              Your last question is more complicated. Conic curve plug-in was made as a response to the topic in the first post. There You can see that there are multiple curves inside polygons. And all the polygons are convex. So the conic curve , which is a construction based on 3 points (let's say A B and C), is always located inside the smaller angle near the point B. In Your case polygon is Concave and conic curve will go outside. Is it possible to force it inside? Well it is.
                              See explanation of how the conic curve is made in first post. You have to set an offset that will sit well inside, and also play with a weight value. But in this version You cannot set different weights for every vertex. Maybe I will get to that in one of the future releases.
                              Stay tuned for more details. I will try to make a nice blog (possibly later an e-book) about it.
                              Cheers
                              Matt
                                Cool ! โ˜€
                                For the OK Button that must be something between V7 V8
                                not works in V7, works in V8
                                • N Offline
                                  notareal
                                  MattC, that sounds great! Cannot wait.
                                    MattC
                                    So it is officially begonnen:
                                    spin-heads.blogspot.com
                                    Cheers
                                    Matt
                                      Appetizing first page! โ˜€
                                        Mra
                                        Hey, nice plugin - but I do not know how to use.
                                        Every option simply brings up a cmd.exe for a millisecond and nothing ever happens.
                                        The steps in the OP are unclear to me? How do we first generate the CP points?
                                          You just draw them as you want!
                                          First image
                                          One rectangle as plane background where you draw as you want the Control points
                                          DON'T erase the "background"
                                          Select points
                                          Call the plug
                                          Select points
                                          Erase points
                                          Second image
                                          Select lines
                                          Call Lattice Maker by Tig
                                          Call Random Painter by Chris Fullmer
                                          Selection Toys for select only points by ThomThom
                                          http://www.3dsaloon.fr/phpbb3/download/file.php?id=3741&mode=view/rokbox.jpg
                                          http://www.3dsaloon.fr/phpbb3/download/file.php?id=3743
                                            Mra
                                            Thank you very much for the help.
                                            But that's the first problem I had, I'm not sure of any tool in SketchUp to draw CP points, is this a plugin? I have no issue with the rest of the steps just how to initially draw the points.
                                            • 3 / 7
