    [PLUGIN] Voronoi + Conic Curve
    140 Posts 55 Posters 242.8k Views 54 Watching
    • gillesG Offline
      gilles
      However, some regions will not work for some strange reason
      Same thing for me.
      Also Tab key does not open dialog box (Macbook pro), for me.
        On a MAC the TAB a onKeyDown method doesn't work [known bug!] - you need to use a onKeyUp method to spot the press of the TAB-key for MAC AND PC.
        Also note that TAB key-mapping will differ between PC and MAC - if key==9 || key==15... DON'T use key 48 as that is only TAB on some Linux setups [I think] and causes issues with mainstream users [== 0 ?] - an error is some of my older code that should be fixed in MY scripts ๐Ÿ˜•
        The regional differences might be caused because there's a ',' as a decimal separator rather than a '.' ?
        If dialog values are taken as 'float' or 'length' then this should be accounted for automatically by Sketchup ?
        Use inputbox rather than UI.inputbox as it checks user inputs better...
        [include a require 'sketchup.rb' in the first line of the script to ensure it's available to you]
        Don't use @@dek.to_mm you've already predefined it as a 'length' as @@dek=25.mm - later you mess with it again .to_f.mm - because you first set it as a length then the user's current units will be used instead anyway - there's no need to restrict it to 'mm' at all - just use 'Offset:' as the prompt... similarly the other inputbox values can only be what you set them as so if it starts as a float the user's input must be a valid float so typing 3 returns 3.0 anyway...
        • I Offline
          ivreich
          Hi MattC
          Still unable to use your plugin. Here's the error message and file...
          Joel
          Error file
          Error message
            It's possible to have two 'lines' that don't intersect and produce 'nil' as the result, so the code needs to trap for the existence of the point and only proceed with it if it's not nil...
            That should be a relatively simple 'trap' to construct...
              MattC
              True TIG
              I already implemented this trap, but also encountered another case that is a bit problematic.
              It is geometry limitation of Sketchup.
              I will update script when this will be solved, in a meantime if anyone also has non-working combination of points, post it here.
              I will have more material to analyse.
              Matt
                Putting the code inside a begin...do_point...rescue...end structure will allow the code to fail on the point without a crash ?
                But a simple intersect_lines...if point...do_stuff...else...next_point...end would suffice here...
                Something like:
                if **int &&** (test[0]==0)&&(test[1]==0)&&(test[2]==0) intprim=int+int.vector_to(pointstable[bpntindx])+int.vector_to(pointstable[bpntindx]) points<<intprim.project_to_line([midlines[0][0],midlines[0][1]]) points<<intprim points<<intprim.project_to_line([midlines[1][0],midlines[1][1]]) els**if int** points<<int end
                and
                if **int &&** point_is_between(p1,p2,int)&&point_is_between(polygon[i],polygon[j],int) point<<int end
                AND any other place where int is set as an 'intersection' that might fail - test for its existence before trying to use it.
                Only uses int if it's not ' nil'.
                  MattC
                  Yup, second way is exactly how I changed it.
                  My fault was testing it on set of random points, and combination of 3 colinear points didn't occure.
                  Matt
                    Sl-m
                    Hi there,
                    I found this Voronoi so cool... couldn't resist posting this.
                    Interacting with the mouse moving over the points.
                    Is that code any useful to ruby Heros ?
                    http://mbostock.github.com/d3/ex/voronoi.html
                    Have a great day/night!
                    Sl!m
                      juanjo
                      Hi Matt
                      Great plugin mate... lots of potential here
                      But I have a little problem: you say that for this to run properly this plugin requires "delauney3.rb"
                      I don't have it... I only have "delaunay2.rb".
                      I get the Typical plugin error..."Error loading file VoronoiXY.rb no such file to load -- delauney3.rb"
                      But I can't find the robust version that TIG is refering to here: http://forums.sketchucation.com/viewtopic.php?t=8314
                      I did got the "conic curve" plugin to work and it's awesome.
                      Also tried to use "qhull.rb" but it's a mess! I just get flashing DOS-screen ans crashes.... It's a shame, since it would also be a super-tool...
                      Have you heard of any progress on that???
                      http://forums.sketchucation.com/viewtopic.php?t=19040
                      http://forums.sketchucation.com/viewtopic.php?t=8116
                      I'd really appreciate your help so i can start using this baby!
                        My 'modularized' version of 'delauney' [ delauney3.rb] ships as part of my 'Triangulate Points' tool - which is very much like Didier's original... BUT avoids potential clashes with common loose method names like 'triangulate' !
                        http://forums.sketchucation.com/viewtopic.php?p=301274#p301274
                        It doesn't replace the original, it just makes a 'safer' alternative for any tool that is using it instead...
                          MattC
                          Hi juanjo, if You download a zip package made by pjt, and not separate files from first post, then You will have "delauney3.rb" as a part of it.
                          I couldn't get "qhull.rb" to work, and that was one of the reasons why I started to work on this project.
                          But I have some problems with the code. Some cases generates strange forms. So the work continues.
                          Greets
                          Matt
                            dtolios
                            @mattc said:
                            Pilou You 're teasing me ๐Ÿ˜„
                            Is it Sketchup ??
                            Or something else?
                            Well only step that I miss from those, is generation of 3D Voronoi ๐Ÿ˜„
                            For rest I have plugins already.
                            @ Joel, indeed there WAS a problem - file in first message is updated.
                            Matt
                            Would it be too much to ask for 3D Voronoi?
                            I would be in...even if not for free... ๐Ÿ‘
                              MattC
                              Well... I think 2D voronoi package (delauney triangulation by TIG + Voronoi on XY plane + Conic Curve + Convex hull on XY plane) is almost ready.
                              Next step will be: (delauney triangulation in 3D + Voronoi 3D + Conic Curve + Convex hull 3D).
                              But it is a lot more complicated.
                              So it is a bit to early to decide free / paid - but I think donationware ( if You like it - gratify creator) is the way to go.
                              Cheers
                              Matt
                                the.pjt
                                hello Matt, did you got the Icons ? ... or a more important question: is this plugin still alive ?
                                  MattC
                                  Yes I got it, Thanks a lot, I am a bit busy at my normal work, but plugin is still alive.
                                  I will try to get updated version online this weekend, but I was already focused on Voronoi2D version 2.0
                                  Cheers
                                  Matt
                                    MattC
                                    @ mitcorb - example : If You have polygon with 4 vertices, You can create 4 sets of points ([0,1,2],[1,2,3],[2,3,0],[3,0,1]).
                                    You can use those sets of points to create rational bezier spline(http://en.wikipedia.org/wiki/B%C3%A9zier_curve#Rational_B.C3.A9zier_curves) by asigning weight to every point.
                                    Special case is when You set for first and third point weight = 1 , and weight "w" for second point.
                                    • when w>1 then created curve is a hyperbole
                                    • when w=1 then created curve is a parabole
                                    • when w<1 then created curve is an ellipse (in special case circle)
                                      Hyperbole, parabole ellipse and circle are known as a conic curves or conic sections , because You can create them by cutting cone with a plane.
                                      For further read : http://www.cs.mtu.edu/~shene/COURSES/cs3621/NOTES/spline/NURBS/RB-conics.html
                                      http://en.wikipedia.org/wiki/Conic_section
                                    If You draw square, and apply coniccurve with weight w = sqrt(2)/2 = 0,7071, You will get a circle.
                                    @ Pilou - This is an implementation of 3DVoronoi - this is my next step, but at this moment I struggle a bit with a code...
                                    Matt
                                      dekay
                                      tanks a lot, your script is very easy to use compared to others.it has been very helpful to me.
                                      thank you once again..
                                      • V Offline
                                        victor hugo
                                        Very interesting plugin...
                                        where can I get the CPOINT creator or a CPOINT plugin?
                                        Thanks.
                                        • cottyC Offline
                                          cotty
                                          Thanks.
                                          Here
                                          my SketchUp gallery
                                            Why not put in the first post the link for the Delauney3.rb by Tig ?
                                            It was not so evident to find it! ๐Ÿ˜ฎ
                                            here the link! ๐Ÿ˜‰
                                            Else works fine ๐Ÿ˜„
                                            • 3 / 7
