    [PLUGIN] Voronoi + Conic Curve
    140 Posts 55 Posters 252.0k Views 54 Watching
      juanjo
      Hi Matt
      Great plugin mate... lots of potential here
      But I have a little problem: you say that for this to run properly this plugin requires "delauney3.rb"
      I don't have it... I only have "delaunay2.rb".
      I get the Typical plugin error..."Error loading file VoronoiXY.rb no such file to load -- delauney3.rb"
      But I can't find the robust version that TIG is refering to here: http://forums.sketchucation.com/viewtopic.php?t=8314
      I did got the "conic curve" plugin to work and it's awesome.
      Also tried to use "qhull.rb" but it's a mess! I just get flashing DOS-screen ans crashes.... It's a shame, since it would also be a super-tool...
      Have you heard of any progress on that???
      http://forums.sketchucation.com/viewtopic.php?t=19040
      http://forums.sketchucation.com/viewtopic.php?t=8116
      I'd really appreciate your help so i can start using this baby!
        My 'modularized' version of 'delauney' [ delauney3.rb] ships as part of my 'Triangulate Points' tool - which is very much like Didier's original... BUT avoids potential clashes with common loose method names like 'triangulate' !
        http://forums.sketchucation.com/viewtopic.php?p=301274#p301274
        It doesn't replace the original, it just makes a 'safer' alternative for any tool that is using it instead...
          MattC
          Hi juanjo, if You download a zip package made by pjt, and not separate files from first post, then You will have "delauney3.rb" as a part of it.
          I couldn't get "qhull.rb" to work, and that was one of the reasons why I started to work on this project.
          But I have some problems with the code. Some cases generates strange forms. So the work continues.
          Greets
          Matt
            dtolios
            @mattc said:
            Pilou You 're teasing me ๐Ÿ˜„
            Is it Sketchup ??
            Or something else?
            Well only step that I miss from those, is generation of 3D Voronoi ๐Ÿ˜„
            For rest I have plugins already.
            @ Joel, indeed there WAS a problem - file in first message is updated.
            Matt
            Would it be too much to ask for 3D Voronoi?
            I would be in...even if not for free... ๐Ÿ‘
              MattC
              Well... I think 2D voronoi package (delauney triangulation by TIG + Voronoi on XY plane + Conic Curve + Convex hull on XY plane) is almost ready.
              Next step will be: (delauney triangulation in 3D + Voronoi 3D + Conic Curve + Convex hull 3D).
              But it is a lot more complicated.
              So it is a bit to early to decide free / paid - but I think donationware ( if You like it - gratify creator) is the way to go.
              Cheers
              Matt
                the.pjt
                hello Matt, did you got the Icons ? ... or a more important question: is this plugin still alive ?
                  MattC
                  Yes I got it, Thanks a lot, I am a bit busy at my normal work, but plugin is still alive.
                  I will try to get updated version online this weekend, but I was already focused on Voronoi2D version 2.0
                  Cheers
                  Matt
                    MattC
                    @ mitcorb - example : If You have polygon with 4 vertices, You can create 4 sets of points ([0,1,2],[1,2,3],[2,3,0],[3,0,1]).
                    You can use those sets of points to create rational bezier spline(http://en.wikipedia.org/wiki/B%C3%A9zier_curve#Rational_B.C3.A9zier_curves) by asigning weight to every point.
                    Special case is when You set for first and third point weight = 1 , and weight "w" for second point.
                    • when w>1 then created curve is a hyperbole
                    • when w=1 then created curve is a parabole
                    • when w<1 then created curve is an ellipse (in special case circle)
                      Hyperbole, parabole ellipse and circle are known as a conic curves or conic sections , because You can create them by cutting cone with a plane.
                      For further read : http://www.cs.mtu.edu/~shene/COURSES/cs3621/NOTES/spline/NURBS/RB-conics.html
                      http://en.wikipedia.org/wiki/Conic_section
                    If You draw square, and apply coniccurve with weight w = sqrt(2)/2 = 0,7071, You will get a circle.
                    @ Pilou - This is an implementation of 3DVoronoi - this is my next step, but at this moment I struggle a bit with a code...
                    Matt
                      dekay
                      tanks a lot, your script is very easy to use compared to others.it has been very helpful to me.
                      thank you once again..
                      • V Offline
                        victor hugo
                        Very interesting plugin...
                        where can I get the CPOINT creator or a CPOINT plugin?
                        Thanks.
                        • cottyC Offline
                          cotty
                          Thanks.
                          Here
                          my SketchUp gallery
                            Why not put in the first post the link for the Delauney3.rb by Tig ?
                            It was not so evident to find it! ๐Ÿ˜ฎ
                            here the link! ๐Ÿ˜‰
                            Else works fine ๐Ÿ˜„
                            • I Offline
                              ivreich
                              VoronoiXY Error
                              Hi MattC
                              I'm still having problems creating a simple 2D Voronoi. Have attached the file with the cpoints and the error message.
                              Conic curve seems to work fine...
                              Cheers
                              joel
                              UPDATE: I see what the problem is. It's still the co-linear points. The plugin will not work if any of the points are colinear in either the X or Y axis.
                              Something that can be fixed?
                              SU File
                              Error message
                                And about Conic Curve
                                Does this possible ?
                                  Hello
                                  For the Voronoรฏ (with SU V7 tested) images previous post
                                  All works fine except I must click on the Ok Botton for have a voronoรฏ polygon for each new polygon! ๐Ÿ˜ฒ ๐Ÿ˜ฎ
                                  Tig triangle works for a selection of points in one pass! ๐Ÿ‘
                                  And for the conic curve : does it possible to have the same for a selection of faces ?
                                  Click on each polygon is some tiedious when you have thousand of them!
                                  EDIT : About Voronoรฏ xy
                                  Works fine in V8 ! โ˜€
                                  But something must be made for the UNDO !!! ๐Ÿ˜‰
                                  Here you must make each CTRL+ Z for each polygon ! ๐Ÿ˜ฎ
                                    MattC
                                    Hi Pilou, Hello everybody
                                    Currently I am rewriting the whole Voronoi 2D plug-in.
                                    It is going painfully slow, but I have a lot of other things on my head right now.
                                    Why I am completely redesigning it? Well my understanding of Ruby got a bit better, and also I got some new ideas how to tackle this problem.
                                    What I want to accomplish:
                                    1. prepare a nice flow chart for a process of creating 2D Voronoi diagram
                                    2. based on that define set of standard functions that will be used
                                    3. compose final version of Voronoi 2D plug-in
                                    • do steps 1-3 with 3D Voronoi
                                    • do steps 1-3 with Conic Curve
                                    • do steps 1-3 with random point generator (2D and 3D)
                                    Shall I succeed then next step would be a "fracture tool" similar to one in Blender.
                                    @ Pilou
                                    So to create voronoi diagram You have to iterate through the message boxes i=1, i=2 ... etc?
                                    I think that that was one of the first complains and I have disabled it in one of later versions. If not I can do it one more time. the same applies to UNDO in one step. Conic curve on all faces in selection was also made, but I don't know if it was made an official release.
                                    Your last question is more complicated. Conic curve plug-in was made as a response to the topic in the first post. There You can see that there are multiple curves inside polygons. And all the polygons are convex. So the conic curve , which is a construction based on 3 points (let's say A B and C), is always located inside the smaller angle near the point B. In Your case polygon is Concave and conic curve will go outside. Is it possible to force it inside? Well it is.
                                    See explanation of how the conic curve is made in first post. You have to set an offset that will sit well inside, and also play with a weight value. But in this version You cannot set different weights for every vertex. Maybe I will get to that in one of the future releases.
                                    Stay tuned for more details. I will try to make a nice blog (possibly later an e-book) about it.
                                    Cheers
                                    Matt
                                      Cool ! โ˜€
                                      For the OK Button that must be something between V7 V8
                                      not works in V7, works in V8
                                      • N Offline
                                        notareal
                                        MattC, that sounds great! Cannot wait.
                                          MattC
                                          So it is officially begonnen:
                                          spin-heads.blogspot.com
                                          Cheers
                                          Matt
                                            Appetizing first page! โ˜€
                                            • 3 / 7
