    [Plugin] AutoSmooth
    32 Posts 5 Posters 45.2k Views 5 Watching
      No problem! πŸ˜‰
      It's just when you see the volume you think that is right, but some "hidden" faces are no coplanars πŸ˜„
      So there is a problem somewhere! A point is not at the correct x,y,z value! But witch ? πŸ’š
        If I could make a suggestion....
        If somehow you could disable inferencing on ALT down it'd be great. πŸ‘
          Does this more clear with my image above ? πŸ˜„
          I'm afraid no. I don't understand what happens there and what are you expecting?
          Unfortunately no, only way would be to recreate the native tools.
            Ok, still an awesome tool.
              Saying that though, I'm currently recreating Move, Rotate and Scale for BezierSurface. Might spawn them off as a separate thing at some point.
                Happen nothing special: it's correct Plugin function πŸ˜„
                Expecting nothing special : Maybe I don't understand the "smooth" in general? 😳
                Does it allow to see a perfect volume in hidde some edges
                Does it allow to see a perfect volume in hidde some edges even some faces are not coplanar
                  Volumes? Are you thinking of solids? This plugin isn't related to solids - it works on any geometry.
                  You know when you modify some geometry and SketchUp triangulates the face because it's not planar any more? This plugin makes these edges Soft+Smooth - like when you Ctrl+Erase, or enable the Soft and Smooth checkboxes in the Entity Info.
                  I'm afraid I still do not understand what you are asking... πŸ˜• 😞 😳
                    I think Pilou thinks that if you move a point to make a non planar face that the resulting skin will be correct. As in a type of make planar but Pilouified
                    This tool does not smooth a face it smooths the harsh edge that the default move tool creates.
                    Sent from my iPad
                      Ok we are agree! β˜€
                      My image above show the same!
                        Right, yes, this plugin doesn't make a face planar.
                          @rich o brien said:
                          now if someone could write an exporter to obj that picked up these pseudo-quads and exported as a quad it'd be pretty sweet.
                          Rich, does the OBJ format support non-planar quads?
                          Are you trying to exchange data between SketchUp and Blender?
                            Yes. But Blender will export a nonplanar quad as 4 tris, well that's how SU imports a untriangulated blender .obj export.
                            Not just Blender. Most apps I use exchange nonplanar obj quads
                            Why?
                              Four triangles?
                              Can Blender import this mesh and the quads are restored as quads - or are they now triangles?
                              And you provide a small sample OBJ file?
                              I could write an export utility into QuadFace Tools.
                                What you want?
                                Blender .obj export
                                SU .obj import saved as .skp?
                                  OBJ file from Blender with non-planar quads. I'd like to see how Blender generates them.
                                    shawnkelly
                                    I would be interested as well, simply because I am not so sure that it does such a thing.
                                      It does - Blender exports non-planar quads. πŸ˜„ I already got an exporter in the making.
                                        Thom,
                                        I notice that if I have the move tool selected and then activate auto-smooth it fails to smooth.
                                        You may have mentioned that in the video but I missed it...
                                          Ah. That world be a bug. As I always tap Space and activates the Select tool, so I didn't test the scenario of having one of Move, Rotate or Scale already activated.
                                            copying a mesh with CTRL+Move will make the mesh edges soft/smooth as in this .gif....
