    [Plugin] AutoSmooth
    32 Posts 5 Posters 44.9k Views 5 Watching
      Ok, still an awesome tool.
        Saying that though, I'm currently recreating Move, Rotate and Scale for BezierSurface. Might spawn them off as a separate thing at some point.
          I'm afraid no. I don't understand what happens there and what are you expecting?
          Happen nothing special: it's correct Plugin function πŸ˜„
          Expecting nothing special : Maybe I don't understand the "smooth" in general? 😳
          Does it allow to see a perfect volume in hidde some edges
          Does it allow to see a perfect volume in hidde some edges even some faces are not coplanar
            Volumes? Are you thinking of solids? This plugin isn't related to solids - it works on any geometry.
            You know when you modify some geometry and SketchUp triangulates the face because it's not planar any more? This plugin makes these edges Soft+Smooth - like when you Ctrl+Erase, or enable the Soft and Smooth checkboxes in the Entity Info.
            I'm afraid I still do not understand what you are asking... πŸ˜• 😞 😳
              I think Pilou thinks that if you move a point to make a non planar face that the resulting skin will be correct. As in a type of make planar but Pilouified
              This tool does not smooth a face it smooths the harsh edge that the default move tool creates.
              Sent from my iPad
                Ok we are agree! β˜€
                My image above show the same!
                  Right, yes, this plugin doesn't make a face planar.
                    @rich o brien said:
                    now if someone could write an exporter to obj that picked up these pseudo-quads and exported as a quad it'd be pretty sweet.
                    Rich, does the OBJ format support non-planar quads?
                    Are you trying to exchange data between SketchUp and Blender?
                      Yes. But Blender will export a nonplanar quad as 4 tris, well that's how SU imports a untriangulated blender .obj export.
                      Not just Blender. Most apps I use exchange nonplanar obj quads
                      Why?
                        Four triangles?
                        Can Blender import this mesh and the quads are restored as quads - or are they now triangles?
                        And you provide a small sample OBJ file?
                        I could write an export utility into QuadFace Tools.
                          What you want?
                          Blender .obj export
                          SU .obj import saved as .skp?
                            OBJ file from Blender with non-planar quads. I'd like to see how Blender generates them.
                              shawnkelly
                              I would be interested as well, simply because I am not so sure that it does such a thing.
                                It does - Blender exports non-planar quads. πŸ˜„ I already got an exporter in the making.
                                  Thom,
                                  I notice that if I have the move tool selected and then activate auto-smooth it fails to smooth.
                                  You may have mentioned that in the video but I missed it...
                                    Ah. That world be a bug. As I always tap Space and activates the Select tool, so I didn't test the scenario of having one of Move, Rotate or Scale already activated.
                                      copying a mesh with CTRL+Move will make the mesh edges soft/smooth as in this .gif....
                                        Doh! Hmm... that's be tricky to catch...
                                          Ahmed0007
                                          not work with TGI Move 😞
                                            Ahmed0007
                                            not work tgi move any advice?
