    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    337 Posts 108 Posters 564.9k Views 108 Watching
    • OxerO
      Oxer
      Thanks to you!! πŸ‘
      • H
        hcltw1963
        Dear Tak2hata,
        Is it possible to generalize the script to use for another kind of construction type like wood? I thought that if the class name "RC_GIRDER","RC_BEAM","RC_WALL","RC_SLAB" substituted by "GIRDER","BEAM","WALL", and "SLAB", they will not be represented as RC construction only.
        So, it will be useful for different kind of construction cause materials been assigned clearly.
        • T
          tak2hata
          @hcltw1963 said:
          Dear Tak2hata,
          Hi,htcltw1963.
          It is possible.
          But STEEL_GIRDER,STEEL_BEAM,STEEL_COLUMN,RC_GIRDER,RC_BEAM,RC_COLUMN,WOODEN_GIRDER,WOODEN_BEAM,WOODEN_COLUMN.....
          I think it too many class to select.
          "ALL" CLASS with searching word can find by "TAG" and "PROFILE".
          I can add the new CLASS If surely required.
          But it will be very hard.I must change TABLE EDITOR,too.
          If there is the request same otherwise, it will inquire collectively.
          Thanks.
          by TAK2HATA
          • H
            hcltw1963
            @tak2hata said:
            @hcltw1963 said:
            Dear Tak2hata,
            Hi,htcltw1963.
            It is possible.
            Thanks.
            Thanks for reply so quickly. I think the modification is as:
            STEEL_GIRDER,STEEL_BEAM,STEEL_COLUMN,GIRDER,BEAM,COLUMN,OTHER
            It is because steel material has special profile, it needs independent class. The prismatic member like concrete, wood, and other can be categorized as same class. They can be identified by materials. I had experienced modifying your scripts by deleting key word "RC_" where in rubies but failed to execute. I hope the idea works for minimum modification.
            • chonC
              chon
              Hello,
              here a first french translation file. This is a first draft and may have mistakes, non-sences or else. This file is not my own. So frensh speaking, you can bring corrections as you want. πŸ˜‰
              2013/01/07 EDIT : File reloaded with 2013/01/05 V1.6a changes included.
              lang_fr.txt
              SU2019 pro 19.3.253 + VRay 4.00.02 (Next) on Win11-64Bits
              • chonC
                chon
                tak2hata,
                i've edited the french translation file with V1.6a changes. So, your "bst1.6a.rbz.zip" is out to date for the "lang_fr.txt" file. πŸ˜‰
                A request : In windows, it would be really nice when clicking on translation link in SU open the default web browser instead of IE (i hate IE). πŸ˜„
                Many thanks for all ! πŸ‘
                • T
                  tak2hata
                  Hi,hcltw1963.
                  Although I think that it is a wonderful idea.
                  But..
                  After I make this tool, about two years have passed.
                  When the point is changed now, it has influence on what is already made model.
                  So,please change the "class" words by translation file.
                  I inquire over many hours to a slight degree.
                  Hi,chon.
                  I will improve the problem about link openning with IE.
                  I hate IE, too. πŸ˜‰
                  Thanks.
                  by TAK2HATA
                  • K
                    Kuddl
                    Hi, Tak2hata
                    The program works fine, unfortunately not with Fredos 000_AdditionalPluginFolders.rb!What a pity! http://sketchucation.com/forums/posting.php?mode=reply&f=323&t=35798#
                    Best Regards
                    Kuddl
                    • C
                      chooyod
                      Hi tak2hata,
                      I have a problem to run the BST Table Editor, as it showing up "Script Error" on my SU8, win7 64 bits.
                      Please suggesting, thank you in advanced.
                      • T
                        tak2hata
                        @chooyod said:
                        Hi tak2hata,
                        Hi,chooyod.
                        I will test this case.
                        But It may be difficult for me.
                        Thanks.
                        by TAK2HATA
                        • T
                          tak2hata
                          Hi,everyone.
                          I update this to version 1.7 in feb 19,2013.
                          Improve for 000additionalPluginFolders.
                          The link in list of translators will open with your current browser.
                          Thanks.
                          by TAK2HATA
                          • C
                            chooyod
                            @tak2hata said:
                            @chooyod said:
                            Hi tak2hata,
                            Hi,chooyod.
                            Thanks.
                            Hi TAK2HATA,
                            Love your plugin, with the latest 1.7 and your effort to figure out, now the BST Table Editor is working fine.
                            Thank you.
                            • B
                              BRONZY
                              Would you be interested on modifying this on a consulting basis. We find it to be useful but it needs to be adapted to our specific needs.
                                deprezzar
                                Gracias! (Thanks)
                                • T
                                  tak2hata
                                  I update to version1.8 in Mar 09,2013.
                                  New function and small bugfix.
                                  Hi,BRONZY.
                                  Your proposal is very interesting for me.
                                  But I have my work.
                                  And the responsibility of scripting for work is a load on my mind.
                                  So I select scripting freely.
                                  Thanks very much.
                                  by TAK2HATA
                                  • C
                                    CTMan
                                    Hi Tak2hata
                                    Just downloaded 1.8 version - looks fantastic yet again !
                                    I viewed the file on youtube and noticed the toolbar on the bottom of the screen.
                                    Can you tell me what this is please
                                    Thanks CTMan
                                    What Toolbar ?
                                      That's my 2dTool set...
                                        johny1964
                                        I have an isuue with the csv file. In which directory I have to put it?
                                        Thx
                                        • W
                                          wolfi60
                                          β˜€ Dear tak2hata,
                                          thanks for this great tool. For all german speaking members I could write a language file. I hope it will help... This is the first time that I'm posting something in a forum, but I'got something like a Sketchup ruby fan and I'm very happy that I can download so many excellent plugins So I also want to contribute a little bit. I hope you will continue with your great work.
                                          Greetings from werni60 (Germany)
                                          German language file (lang_de.txt)
                                          • T
                                            tak2hata
                                            @wolfi60 said:
                                            :enlight: Dear tak2hata,
                                            Hi,wolfi60.
                                            Your language file for german will be include in BST next update.
                                            It will come few days.
                                            by TAK2HATA
