    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    337 Posts 108 Posters 503.1k Views 108 Watching
      chooyod
      Hi tak2hata,
      I have a problem to run the BST Table Editor, as it showing up "Script Error" on my SU8, win7 64 bits.
      Please suggesting, thank you in advanced.
        tak2hata
        @chooyod said:
        Hi tak2hata,
        Hi,chooyod.
        I will test this case.
        But It may be difficult for me.
        Thanks.
        by TAK2HATA
          tak2hata
          Hi,everyone.
          I update this to version 1.7 in feb 19,2013.
          Improve for 000additionalPluginFolders.
          The link in list of translators will open with your current browser.
          Thanks.
          by TAK2HATA
            chooyod
            @tak2hata said:
            @chooyod said:
            Hi tak2hata,
            Hi,chooyod.
            Thanks.
            Hi TAK2HATA,
            Love your plugin, with the latest 1.7 and your effort to figure out, now the BST Table Editor is working fine.
            Thank you.
              BRONZY
              Would you be interested on modifying this on a consulting basis. We find it to be useful but it needs to be adapted to our specific needs.
                deprezzar
                Gracias! (Thanks)
                  tak2hata
                  I update to version1.8 in Mar 09,2013.
                  New function and small bugfix.
                  Hi,BRONZY.
                  Your proposal is very interesting for me.
                  But I have my work.
                  And the responsibility of scripting for work is a load on my mind.
                  So I select scripting freely.
                  Thanks very much.
                  by TAK2HATA
                    CTMan
                    Hi Tak2hata
                    Just downloaded 1.8 version - looks fantastic yet again !
                    I viewed the file on youtube and noticed the toolbar on the bottom of the screen.
                    Can you tell me what this is please
                    Thanks CTMan
                    What Toolbar ?
                      That's my 2dTool set...
                        johny1964
                        I have an isuue with the csv file. In which directory I have to put it?
                        Thx
                        • W Offline
                          wolfi60
                          β˜€ Dear tak2hata,
                          thanks for this great tool. For all german speaking members I could write a language file. I hope it will help... This is the first time that I'm posting something in a forum, but I'got something like a Sketchup ruby fan and I'm very happy that I can download so many excellent plugins So I also want to contribute a little bit. I hope you will continue with your great work.
                          Greetings from werni60 (Germany)
                          German language file (lang_de.txt)
                            tak2hata
                            @wolfi60 said:
                            :enlight: Dear tak2hata,
                            Hi,wolfi60.
                            Your language file for german will be include in BST next update.
                            It will come few days.
                            by TAK2HATA
                              tak2hata
                              Hi,Every one.
                              I update this to version 1.92 in Apr 28,2013.
                              Improve about UI.
                              Include Germany translation file by wolfi60.
                              Thanks wolfi60!
                              Enjoy! πŸ˜„
                              by TAK2HATA
                                Aeltan
                                I`ve downloaded the archive, unzipped, replaced the files into plugins folder but nothing happened, where I can find the toolbar itself??
                                  After a manual install, if you haven't restarted SketchUp then there will be nothing available...
                                  Otherwise the Plugins Menu should contain the tool's item, the tool's Toolbar can be activated from the View > Toolbars menu...
                                  If it doesn't, but you are sure you placed all of the files/subfolder+files into the Plugins folder exactly in the same relative locations as they are in the ZIP, then it suggests you don't have full permissions to the Plugins folder...
                                  This has been discussed/explained many times before... but here goes again...
                                  If there is a link button in the top bars of your Plugins folder's Windows Explorer window saying something like 'Compatibility Files...' that is a BAD sign...
                                  You need to have Admin rights to do the next steps effectively...
                                  Select the Plugins folder's icon and right-click > context-menu > Properties > Security > Edit... ensure everyone in the list has FULL rights to read/write the folder...
                                  Now you will be able to manually install scripts etc [or much easier using the auto-install button on the SketchUcation Plugin Store...]
                                  I also recommend that you give the same permissions to the Component, Materials and Styles folders as you will also want to write to those from time to time...
                                    tak2hata
                                    Hi,Aeltan.
                                    copy all to plugins folder.
                                    If you copyed the file including folder to plugins folder?
                                    And,your plugins folder path must no inlcude the non_english characters,because the problem of ruby and windows file system.
                                    And TIG's advice is most important for installing plugins.
                                    Thanks.
                                    by TAK2HATA
                                      refy
                                      Sir Tak2hata, Sorry i had to snatch you in this thread because your BST tool tops in my plug-ins and so your Vidro GI render approach. I need to know how lighting in vidro is done and how you program it.I wanted to see a vidro render material & lighting approach and how to add & edit lighting with notepad++.I Cant find a detailed tutorial on it...Help!!!
                                        tak2hata
                                        Hi,refy.
                                        English is not my native tongue.
                                        So my description is difficults.
                                        I create webpage about Su2objmtl_VIDRO.
                                        Please visit there.
                                        http://sketchup-onigiri.jimdo.com/tutorial/
                                        by TAK2HATA
                                          ROT
                                          respected creator of the plugin, posters please tell me how to download, after registration link does not appear.
                                            tak2hata
                                            Hi,ROT.
                                            Login to this forum.
                                            and visit top of this thread.
                                            http://sketchucation.com/forums/viewtopic.php?f=323&t=35798#p315482
                                            You will find the download link like this.
                                            screen capture
                                            by TAK2HATA
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 13 / 17
