    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    337 Posts 108 Posters 535.3k Views 108 Watching
    • H Offline
      hcltw1963
      @tak2hata said:
      @hcltw1963 said:
      Dear Tak2hata,
      Is it possible to generalize the script to use for another kind of construction type like wood? I thought that if the class name "RC_GIRDER","RC_BEAM","RC_WALL","RC_SLAB" substituted by "GIRDER","BEAM","WALL", and "SLAB", they will not be represented as RC construction only.
      So, it will be useful for different kind of construction cause materials been assigned clearly.
      Hi,htcltw1963.
      It is possible.
      But STEEL_GIRDER,STEEL_BEAM,STEEL_COLUMN,RC_GIRDER,RC_BEAM,RC_COLUMN,WOODEN_GIRDER,WOODEN_BEAM,WOODEN_COLUMN.....
      I think it too many class to select.
      "ALL" CLASS with searching word can find by "TAG" and "PROFILE".
      I can add the new CLASS If surely required.
      But it will be very hard.I must change TABLE EDITOR,too.
      If there is the request same otherwise, it will inquire collectively.
      Thanks.
      Thanks for reply so quickly. I think the modification is as:
      STEEL_GIRDER,STEEL_BEAM,STEEL_COLUMN,GIRDER,BEAM,COLUMN,OTHER
      It is because steel material has special profile, it needs independent class. The prismatic member like concrete, wood, and other can be categorized as same class. They can be identified by materials. I had experienced modifying your scripts by deleting key word "RC_" where in rubies but failed to execute. I hope the idea works for minimum modification.
      • chonC Offline
        chon
        Hello,
        here a first french translation file. This is a first draft and may have mistakes, non-sences or else. This file is not my own. So frensh speaking, you can bring corrections as you want. πŸ˜‰
        2013/01/07 EDIT : File reloaded with 2013/01/05 V1.6a changes included.
        lang_fr.txt
        • chonC Offline
          chon
          tak2hata,
          i've edited the french translation file with V1.6a changes. So, your "bst1.6a.rbz.zip" is out to date for the "lang_fr.txt" file. πŸ˜‰
          A request : In windows, it would be really nice when clicking on translation link in SU open the default web browser instead of IE (i hate IE). πŸ˜„
          Many thanks for all ! πŸ‘
            tak2hata
            Hi,hcltw1963.
            Although I think that it is a wonderful idea.
            But..
            After I make this tool, about two years have passed.
            When the point is changed now, it has influence on what is already made model.
            So,please change the "class" words by translation file.
            I inquire over many hours to a slight degree.
            Hi,chon.
            I will improve the problem about link openning with IE.
            I hate IE, too. πŸ˜‰
            Thanks.
            by TAK2HATA
              Kuddl
              Hi, Tak2hata
              The program works fine, unfortunately not with Fredos 000_AdditionalPluginFolders.rb!What a pity! http://sketchucation.com/forums/posting.php?mode=reply&f=323&t=35798#
              Best Regards
              Kuddl
                chooyod
                Hi tak2hata,
                I have a problem to run the BST Table Editor, as it showing up "Script Error" on my SU8, win7 64 bits.
                Please suggesting, thank you in advanced.
                  tak2hata
                  @chooyod said:
                  Hi tak2hata,
                  Hi,chooyod.
                  I will test this case.
                  But It may be difficult for me.
                  Thanks.
                  by TAK2HATA
                    tak2hata
                    Hi,everyone.
                    I update this to version 1.7 in feb 19,2013.
                    Improve for 000additionalPluginFolders.
                    The link in list of translators will open with your current browser.
                    Thanks.
                    by TAK2HATA
                      chooyod
                      @tak2hata said:
                      @chooyod said:
                      Hi tak2hata,
                      Hi,chooyod.
                      Thanks.
                      Hi TAK2HATA,
                      Love your plugin, with the latest 1.7 and your effort to figure out, now the BST Table Editor is working fine.
                      Thank you.
                        BRONZY
                        Would you be interested on modifying this on a consulting basis. We find it to be useful but it needs to be adapted to our specific needs.
                          deprezzar
                          Gracias! (Thanks)
                            tak2hata
                            I update to version1.8 in Mar 09,2013.
                            New function and small bugfix.
                            Hi,BRONZY.
                            Your proposal is very interesting for me.
                            But I have my work.
                            And the responsibility of scripting for work is a load on my mind.
                            So I select scripting freely.
                            Thanks very much.
                            by TAK2HATA
                              CTMan
                              Hi Tak2hata
                              Just downloaded 1.8 version - looks fantastic yet again !
                              I viewed the file on youtube and noticed the toolbar on the bottom of the screen.
                              Can you tell me what this is please
                              Thanks CTMan
                              What Toolbar ?
                              • TIGT Online
                                That's my 2dTool set...
                                  johny1964
                                  I have an isuue with the csv file. In which directory I have to put it?
                                  Thx
                                  • W Offline
                                    wolfi60
                                    β˜€ Dear tak2hata,
                                    thanks for this great tool. For all german speaking members I could write a language file. I hope it will help... This is the first time that I'm posting something in a forum, but I'got something like a Sketchup ruby fan and I'm very happy that I can download so many excellent plugins So I also want to contribute a little bit. I hope you will continue with your great work.
                                    Greetings from werni60 (Germany)
                                    German language file (lang_de.txt)
                                      tak2hata
                                      @wolfi60 said:
                                      :enlight: Dear tak2hata,
                                      Hi,wolfi60.
                                      Your language file for german will be include in BST next update.
                                      It will come few days.
                                      by TAK2HATA
                                        tak2hata
                                        Hi,Every one.
                                        I update this to version 1.92 in Apr 28,2013.
                                        Improve about UI.
                                        Include Germany translation file by wolfi60.
                                        Thanks wolfi60!
                                        Enjoy! πŸ˜„
                                        by TAK2HATA
                                          Aeltan
                                          I`ve downloaded the archive, unzipped, replaced the files into plugins folder but nothing happened, where I can find the toolbar itself??
                                          • TIGT Online
                                            After a manual install, if you haven't restarted SketchUp then there will be nothing available...
                                            Otherwise the Plugins Menu should contain the tool's item, the tool's Toolbar can be activated from the View > Toolbars menu...
                                            If it doesn't, but you are sure you placed all of the files/subfolder+files into the Plugins folder exactly in the same relative locations as they are in the ZIP, then it suggests you don't have full permissions to the Plugins folder...
                                            This has been discussed/explained many times before... but here goes again...
                                            If there is a link button in the top bars of your Plugins folder's Windows Explorer window saying something like 'Compatibility Files...' that is a BAD sign...
                                            You need to have Admin rights to do the next steps effectively...
                                            Select the Plugins folder's icon and right-click > context-menu > Properties > Security > Edit... ensure everyone in the list has FULL rights to read/write the folder...
                                            Now you will be able to manually install scripts etc [or much easier using the auto-install button on the SketchUcation Plugin Store...]
                                            I also recommend that you give the same permissions to the Component, Materials and Styles folders as you will also want to write to those from time to time...
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 13 / 17
