    Large empty white screen pops up causing me to force quit
    renderpluginsextensions
    65 Posts 12 Posters 13.5k Views 12 Watching
    • shannakaeS
      shannakae
      Ok, i figured out how to get a screenshot Shift+Command+4 gives me something similar to what Jing offers. Anyway I have an picture of this monster thing i have attached it. I guess actually i can access my tools and the move things around behind it but I just cant get it to go away... and the important message that would probably tell me what it is is conveniently behind it I'm sure...
      • GaieusG
        Shanna, you failed to attach the screenshot. You can use the edit button at the top of your post to add it (again?).
          driven
          hi,
          image not attached?
          if you right click on it do you have any options, in particular 'reload'...
          • shannakaeS
            shannakae
            Ok, it looks like the screenshots are too large for me to add, let me resize them and I will resend.
            • shannakaeS
              shannakae
              Ok I am attaching a screenshopt of the big whit box over my sketch up, and two images of what happend after I rand the Apple script editor as drected by "Driven".
              white screen thing
              apple script editor results
              white screen
                driven
                in 'System Preferences' Pane you need to enable assistive devices, forgot about that sorry...
                enable_GUI_scripting()
                on enable_GUI_scripting()
                	try
                		if (system attribute "sysv") < 4138 then display dialog "This script requires the installation of Mac OS X 10.3 or higher." buttons {"Cancel"} default button 1 with icon 2
                		tell application "System Events" to if not UI elements enabled then
                			tell me
                				activate
                				display dialog "This script requires the built-in Graphic User Interface Scripting architecture of Mac OS X, which is currently disabled." & return & return & "Enable GUI Scripting now? (You may be asked to enter your password.)" buttons {"Cancel", "Enable"} default button 2 with icon 2
                			end tell
                			set UI elements enabled to true
                			if not UI elements enabled then error number -128
                		end if
                		return "yes"
                	on error
                		return "no"
                	end try
                end enable_GUI_scripting
                this should help, run in AppleScript Editor
                  driven
                  in your second image the menu bar says it's Safari?
                  long shot but, does the box go away if you close Safari?
                  • shannakaeS
                    shannakae
                    ok will do that, in the meantime here is another screenshot of what I get when I go to close sketch up....I picked discard changes and it closed down sketchup.
                    what happens when I close sketch up
                      driven
                      Ok,
                      If you 'Review Changes' then 'Save' or 'Discard' on both, does SU then close itself?
                        driven
                        if you turn off 'Instructor' does it go away?
                        scroll area 1 of window "Instructor"
                          driven
                          hi
                          you can edit out the long list from the above post if you want....
                          what it tells me is you have these windows open
                          %(#0000BF)[window 2, possibly a suspect
                          window 3, possibly a suspect
                          window "Instructor"
                          window "Artisan" ,
                          window "Round Corner" ,
                          window "V-Ray for SketchUp" ,
                          window "Albatross - SketchUp Pro" ,
                          window "Untitled - SketchUp Pro" ,]
                          you need to turn them off one at a time to find which it is...
                          • jeff hammondJ
                            yeah, that is indeed very weird and should not be happening..
                            i wonder if it's somehow due to the retina display ? (ie- nobody in this thread has ever seen this before but none of us has a retina display either πŸ˜‰ ) ..but it seems like you're getting a window that isn't refreshing..
                            try to run sketchup in normal resolution:
                            β€’ right-click (2finger click) on the sketchup app inside the applications folder
                            β€’ choose 'Get Info' from the list
                            β€’ see if there's an option to 'open in low resolution' (or smthing like that)
                            β€’ try running sketchup again
                            if that clears up the problem, i would report it to the SketchUp developers so they can try to narrow down the cause and fix it..
                            if that doesn't clear it up.. honestly, you should probably take the computer to a genius bar if you have an apple store nearby.. there are so many variables here that it's going to be hard for someone to figure out the problem via a forum..
                            good luck
                            [edit] oh.. i would still try to turn off sketchup's autosave to see if that's triggering this..
                            • daleD
                              dale
                              I have the Retina display on a 17" MacBook Pro, and I have never experienced this.
                              This dialogue box is simply telling you you have 2 other SketchUp files open as well as the one you are working with, and you have not saved them recently.
                              If you have not opened these files, they could be partially to blame.
                              I notice you are on Mountain Lion, and there is an option in the OS (I'm new to Mountain Lion) that automatically opens any previous files when you start an application.
                              If you go to your System Preferences under the Apple dropdown menu at the top left of the screen, and go to "General"
                              You can make sure the "Close Windows when quitting an Application button is checked. You can also un-check the ask to keep changes dialogue to if you wish.
                              • jeff hammondJ
                                no such thing πŸ˜‰
                                apple ditched the 17" laptop all together after releasing the retinas..
                                hi rez 17" was 1920 x 1200 (2.3m pixels)
                                retina 15" is 2880 x 1800 (5m pixels)
                                • GaieusG
                                  no such thing
                                  I really do not know where this is going. I mean it1s not just resolution but also size that you need to look at. What if they can squeeze 5 million pixels in a 1" monitor? Will they be happy? Can you tell those too close pixels apart? Will you still be able to see details?
                                  It's all humbug to me.
                                  • jeff hammondJ
                                    the iphones are even higher rez (325 pixels per inch as opposed to 225 on the laptops)
                                    as i gather, these aren't really retina quality and apple is basically using the word as a marketing thing..
                                    true retina (somewhere around 400 ppi) means the human eye is unable to differentiate pixels at normal viewing distance.. basically, everything will look like liquid at that point..
                                    (and in graphic/cad apps, that would be really nice.. the circle will look absolutely like true circles (even in apps that have true circles, they are still 'faked' because of the pixels..))
                                    further, anti aliasing and those types of visual tricks will no longer be needed..
                                    dunno, i'm all for it.. they'll eventually figure out a way to get the pixels onto cloth.. maybe paint.. etc..
                                    • daleD
                                      dale
                                      More off topic
                                      😳 of course Jeff You are absolutely right. When I first got it I took a ruler and measured diagonally across the screen (like for old TV's) and it was 17"+- , and that has always stuck with me.
                                      Truth is the 15" MacBook is only a little over 14" with just over 13"of viewable screen.or from an aspect ratio view...
                                      For a 16:10 aspect ratio screen:
                                      screen width = screen height * 16/10
                                      MacBook Pro: 15.4" diag. is 13.06" W x 8.16" H
                                      These are screen dimensions only, not the dimensions of the computer.
                                      Gai
                                      Where you really notice the difference is in Hi Res photography. But since a lot of applications are not optimized for retina, sometimes I really don't notice any difference.
                                      • jeff hammondJ
                                        [off:33ndr0uv]@csaba
                                        oh.. and it's not like everything keeps getting smaller on your screen..
                                        a line that's 1px wide on older monitors will be like 5px wide on retina..
                                        they look the same size except the retina one will be much less jagged (ultimately, no jaggies at all)
                                        so the details are incredibly at that resolution compared to low rez monitors.. it's not as if the details get so small that they disappear.. they actually become clearer an more discernible[/off:33ndr0uv]
                                        • GaieusG
                                          Ah well... I do not have a retina display device (nor any Mac device btw) but am building a website which will have responsive features. I already have a headache how to display images on 1200+, 960-1200, 768-960, 480-768 and 480- screens. And now Apple comes up with this retina display. What should I put there? Where is the bandwidth for a mobile phone to load those large images?
                                          When we are at it: what is a pun multiplied by another pun? πŸ˜’
                                          • jeff hammondJ
                                            ha.. yeah.. sounds sort of like the same thing the sketchup devs are up against.. they increase the app's performance then people start making higher poly models.. then back to square 1
                                            When we are at it: what is a pun multiplied by another pun? :roll
                                            not sure.. and i can't even come up with any silly guesses right now.. i'll be sure to check back to find out the answer though πŸ˜†
                                            [edit]- a pundemic ? lol.. i don't know..
                                            • 1 / 4
