    Large empty white screen pops up causing me to force quit
    renderpluginsextensions
    65 Posts 12 Posters 11.3k Views 12 Watching
      driven
      in 'System Preferences' Pane you need to enable assistive devices, forgot about that sorry...
      enable_GUI_scripting()
      on enable_GUI_scripting()
      	try
      		if (system attribute "sysv") < 4138 then display dialog "This script requires the installation of Mac OS X 10.3 or higher." buttons {"Cancel"} default button 1 with icon 2
      		tell application "System Events" to if not UI elements enabled then
      			tell me
      				activate
      				display dialog "This script requires the built-in Graphic User Interface Scripting architecture of Mac OS X, which is currently disabled." & return & return & "Enable GUI Scripting now? (You may be asked to enter your password.)" buttons {"Cancel", "Enable"} default button 2 with icon 2
      			end tell
      			set UI elements enabled to true
      			if not UI elements enabled then error number -128
      		end if
      		return "yes"
      	on error
      		return "no"
      	end try
      end enable_GUI_scripting
      this should help, run in AppleScript Editor
        driven
        in your second image the menu bar says it's Safari?
        long shot but, does the box go away if you close Safari?
        • shannakaeS Offline
          shannakae
          ok will do that, in the meantime here is another screenshot of what I get when I go to close sketch up....I picked discard changes and it closed down sketchup.
          what happens when I close sketch up
            driven
            Ok,
            If you 'Review Changes' then 'Save' or 'Discard' on both, does SU then close itself?
              driven
              if you turn off 'Instructor' does it go away?
              scroll area 1 of window "Instructor"
                driven
                hi
                you can edit out the long list from the above post if you want....
                what it tells me is you have these windows open
                %(#0000BF)[window 2, possibly a suspect
                window 3, possibly a suspect
                window "Instructor"
                window "Artisan" ,
                window "Round Corner" ,
                window "V-Ray for SketchUp" ,
                window "Albatross - SketchUp Pro" ,
                window "Untitled - SketchUp Pro" ,]
                you need to turn them off one at a time to find which it is...
                • jeff hammondJ Offline
                  yeah, that is indeed very weird and should not be happening..
                  i wonder if it's somehow due to the retina display ? (ie- nobody in this thread has ever seen this before but none of us has a retina display either πŸ˜‰ ) ..but it seems like you're getting a window that isn't refreshing..
                  try to run sketchup in normal resolution:
                  β€’ right-click (2finger click) on the sketchup app inside the applications folder
                  β€’ choose 'Get Info' from the list
                  β€’ see if there's an option to 'open in low resolution' (or smthing like that)
                  β€’ try running sketchup again
                  if that clears up the problem, i would report it to the SketchUp developers so they can try to narrow down the cause and fix it..
                  if that doesn't clear it up.. honestly, you should probably take the computer to a genius bar if you have an apple store nearby.. there are so many variables here that it's going to be hard for someone to figure out the problem via a forum..
                  good luck
                  [edit] oh.. i would still try to turn off sketchup's autosave to see if that's triggering this..
                  • daleD Offline
                    dale
                    I have the Retina display on a 17" MacBook Pro, and I have never experienced this.
                    This dialogue box is simply telling you you have 2 other SketchUp files open as well as the one you are working with, and you have not saved them recently.
                    If you have not opened these files, they could be partially to blame.
                    I notice you are on Mountain Lion, and there is an option in the OS (I'm new to Mountain Lion) that automatically opens any previous files when you start an application.
                    If you go to your System Preferences under the Apple dropdown menu at the top left of the screen, and go to "General"
                    You can make sure the "Close Windows when quitting an Application button is checked. You can also un-check the ask to keep changes dialogue to if you wish.
                      no such thing πŸ˜‰
                      apple ditched the 17" laptop all together after releasing the retinas..
                      hi rez 17" was 1920 x 1200 (2.3m pixels)
                      retina 15" is 2880 x 1800 (5m pixels)
                        no such thing
                        I really do not know where this is going. I mean it1s not just resolution but also size that you need to look at. What if they can squeeze 5 million pixels in a 1" monitor? Will they be happy? Can you tell those too close pixels apart? Will you still be able to see details?
                        It's all humbug to me.
                          the iphones are even higher rez (325 pixels per inch as opposed to 225 on the laptops)
                          as i gather, these aren't really retina quality and apple is basically using the word as a marketing thing..
                          true retina (somewhere around 400 ppi) means the human eye is unable to differentiate pixels at normal viewing distance.. basically, everything will look like liquid at that point..
                          (and in graphic/cad apps, that would be really nice.. the circle will look absolutely like true circles (even in apps that have true circles, they are still 'faked' because of the pixels..))
                          further, anti aliasing and those types of visual tricks will no longer be needed..
                          dunno, i'm all for it.. they'll eventually figure out a way to get the pixels onto cloth.. maybe paint.. etc..
                          • daleD Offline
                            dale
                            More off topic
                            😳 of course Jeff You are absolutely right. When I first got it I took a ruler and measured diagonally across the screen (like for old TV's) and it was 17"+- , and that has always stuck with me.
                            Truth is the 15" MacBook is only a little over 14" with just over 13"of viewable screen.or from an aspect ratio view...
                            For a 16:10 aspect ratio screen:
                            screen width = screen height * 16/10
                            MacBook Pro: 15.4" diag. is 13.06" W x 8.16" H
                            These are screen dimensions only, not the dimensions of the computer.
                            Gai
                            Where you really notice the difference is in Hi Res photography. But since a lot of applications are not optimized for retina, sometimes I really don't notice any difference.
                              [off:33ndr0uv]@csaba
                              oh.. and it's not like everything keeps getting smaller on your screen..
                              a line that's 1px wide on older monitors will be like 5px wide on retina..
                              they look the same size except the retina one will be much less jagged (ultimately, no jaggies at all)
                              so the details are incredibly at that resolution compared to low rez monitors.. it's not as if the details get so small that they disappear.. they actually become clearer an more discernible[/off:33ndr0uv]
                                Ah well... I do not have a retina display device (nor any Mac device btw) but am building a website which will have responsive features. I already have a headache how to display images on 1200+, 960-1200, 768-960, 480-768 and 480- screens. And now Apple comes up with this retina display. What should I put there? Where is the bandwidth for a mobile phone to load those large images?
                                When we are at it: what is a pun multiplied by another pun? πŸ˜’
                                  ha.. yeah.. sounds sort of like the same thing the sketchup devs are up against.. they increase the app's performance then people start making higher poly models.. then back to square 1
                                  When we are at it: what is a pun multiplied by another pun? :roll
                                  not sure.. and i can't even come up with any silly guesses right now.. i'll be sure to check back to find out the answer though πŸ˜†
                                  [edit]- a pundemic ? lol.. i don't know..
                                    Well, a pun upon a pun (just read it up)
                                      [off:2fhpntml]
                                      πŸ˜†
                                      (once i said it one time, i made sure not to do it again.. that's one of those things that will get stuck in your head for a few days )[/off:2fhpntml]
                                        @dale said:
                                        More off topic
                                        oh. nice.. i finally was able to use sketchup today for something.. but yeah.. those dimensions check out properly..
                                        πŸ˜†
                                        and i think (as in, i don't really know at all.. it's just what i think).. i think these days, all monitors and screens and tvs and such are labeled in size according to their diagonal measurement..
                                          shannakae
                                          Ok I had to work all day and am just now returning... before I left I turned off auto save and I have not seen the white monster since I got home. It has been about an hour so far... fingers crossed that turning off auto save was the solution... Thanks everyone for your help!!! Hopefully this will be the end of this post : /
                                            shannakae
                                            Blasted! I thought that the turning off auto save had worked.... but alas he darn white monster is back looming over my sketch up...
                                            So far I have tired, the two suggestions that Jeff had, reset sketchup by removing the plst files... and turning off autosave. I though that both of them had worked but eventually the darn whit thing came back.
                                            I have run the GUI scripting that "driven:" gave me (not sure if they were able to make out anything from what I sent), also not sure they got what I sent as it seems that half of the posts the I am posting here aren't showing up?? (maybe because I am new or because i did not do something correct when submitting).
                                            I am now going to look into Rich's suggesting regarding the splash screen on startup.
                                            Thanks everyone for trying to help me. i am at a loss... It does seem to happen sometime after I render with vray...maybe vray is the problem? I am using the trial version of gray
                                            • 2 / 4
