    Large empty white screen pops up causing me to force quit
    renderpluginsextensions
    65 Posts 12 Posters 13.5k Views 12 Watching
    • jeff hammondJ
      [off:4u4dvp9q]
      @rich o brien said:
      When you initially open SketchUp and immediately close it you will not be asked for a 'Save' option. SketchUp will just close without a prompt to save
      off topic but this isn't always the case on mac.. certain plugins cause it but i've asked the suTeam several times to make a sweeping trap to prevent it.. but if i have one of the 'problem plugins', i can launch sketchup then immediately quit it yet i'll be asked to "save?" etc.. 😕[/off:4u4dvp9q]
      @shanna
      hmm. i've never once seen that happen but sometimes if you force quit an app, you can end up with a corrupt .plist file.. and it sounds as if you may have a corrupt plist because it keeps happening even after relaunching..
      i'd say try resetting sketchup to it's default configuration and rebuild the .plist..
      (this will literally make sketchup appear as if it's the very first time you installed it so if you have a lot of customized preferences, be prepared to reset everything to your liking.. it won't affect your license or custom shortcuts or any plugins etc you may have installed.. just things like starting template, toolbar positions, window size, etc.)
      --close sketchup
      --click on finder in the dock
      --click the 'go' menu at the top of the screen
      --hold down the option key
      --a new menu item named 'library' will appear under the go menu (this is the user library-- click on it)
      --open the folder named 'Preferences'
      --find the file 'com.google.sketchuppro8.plist' (or whatever version you're using)
      -- trash the file then launch sketchup**
      a new .plist will be created upon relaunching sketchup but everything will be set to defaults..
      **note- there will be a few files in this folder which start with com.google.sketchup.. feel free to delete them all but definitely make sure you get the one i mentioned..
      you may want to wait until this thread plays out a bit more (i.e.- we get more info about your mac model etc) but i'm heading out soon so i thought i'd post this now..
      • shannakaeS
        shannakae
        Ok, before I do anything I will provide additional info...
        I am on a Mac ultrabook 7i with, Graphics NVIDIA GeForce GT 650M 1024 MB, OS X 10.8.2, Memory 8 GB 1600 MHz DDR3, retina display. (I am now to MAC, just about two weeks now)
        I will try to explain the issue I am having in more detail. also if someone can tell me how to add an image here I will include a screenshot the next time it happens...
        I will be working in sketchup for a while, as always I save often... then all of the sudden a white window (like a pop up, but blank) pops up and covers my screen and I am forced to force quit because I can not see or access any of the sketch up tools, even if I am able to see a toolbar they are locked. I then go down to the bottom area where I see the sketchup icon and right click to quit the application and I am given two options, one is something like inspect changes and the other is something like abandon changes... (not exactly sure of the exact words but the gist is that there is not an option to save) So I choose one of the options and that window closes but the white blank pop up random thing is still there and sketchup remains open but frozen under the whit screen. So i have to go up to the top left corner and click on "force quit" then i pick sketchup from the list and it closes.
        I then re-open sketchup and am usually able to work for a while before it happens again, maybe an hour but sometimes it happens right away....
        Thank all of you for you input and help so far! I really appreciate it!
        • jeff hammondJ
          @shannakae said:
          %(grey)[Ok, before I do anything I will provide additional info...
          I am on a Mac ultrabook 7i with, Graphics NVIDIA GeForce GT 650M 1024 MB, OS X 10.8.2, Memory 8 GB 1600 MHz DDR3, retina display. (I am now to MAC, just about two weeks now)]
          that's a 15" macbook pro
          (ie- sweet computer and the graphic card is fine for anything sketchup)
          when you're composing a post, you'll see 'upload attachment' a little bit below the window you're typing in.. click that then navigate to the file etc..
          fullscreen screenshot on mac is shift-cmmd-3 ..screenshot with selection window is shift-cmmd-4
          %(grey)[will be working in sketchup for a while, as always I save often... then all of the sudden a white window (like a pop up, but blank) pops up and covers my screen and I am forced to force quit because I can not see or access any of the sketch up tools, even if I am able to see a toolbar they are locked. I then go down to the bottom area where I see the sketchup icon and right click to quit the application and I am given two options, one is something like inspect changes and the other is something like abandon changes... (not exactly sure of the exact words but the gist is that there is not an option to save) So I choose one of the options and that window closes but the white blank pop up random thing is still there and sketchup remains open but frozen under the whit screen. So i have to go up to the top left corner and click on "force quit" then i pick sketchup from the list and it closes.
          Thank all of you for you input and help so far! I really appreciate it!]
          that sounds like a sheet instead of a popup.. very few things in sketchup use sheets.. it's usually little windows with the stoplight buttons at the top left..
          does it look like this?
          mockup
          if so.. the only thing that uses those in sketchup are more on the osx side of things.. Save As, Import/export, and printing..
          maybe you should try disabling auto-save in sketchup (for one, autosave in sketchup is no good anyway.. two, you already said you save often.. and three, since it's seemingly appearing random and the Save As dialog uses the same style sheet, there's possibly some sort of glitch going on in which autosave is showing a sheet when it should remain hidden)
          anyway, in sketchup, go to 'general' in preferences (sketchup menu-> preferences -> general)
          untick the box named 'auto-save'
          if that doesn't stop the behavior then see my earlier post.. maybe that other thing sounds all techny and nerdy but it's really not.. it's just throwing away a little text file.. (though maybe spelling out every single step of how to get to said file makes it seem 🤓 )
          • shannakaeS
            shannakae
            Wait! Right after I posted this I went back to my sketch up window and there was that big whit blank screen again : ( argh. Being new to mac, i also dont know how to get a screenshot of this thing? I have jing installed on my computer but it is not coming up or it is hidden behind the big blank white screen.... : / any ideas?
              driven
              Is it always the same model that causes this?
              To find out what the 'Window' is,
              the next time it happens, leave SU and open AppleScript Editor.app (use Spotlight to find it or the Finder(menu) » Go » Utilities » AppleScript...)
              then Paste this in and Run (green button in toolbar)
              tell application "Sketchup"
              	activate
              end tell
              tell application "System Events"
              	get entire contents of every window of process "SketchUp"
              end tell
              you'l get a list of all the open SU windows, and may have a clue what it is...
              you can try this out first, even with SU closed, it will open it for you.
              • shannakaeS
                shannakae
                Ok, i figured out how to get a screenshot Shift+Command+4 gives me something similar to what Jing offers. Anyway I have an picture of this monster thing i have attached it. I guess actually i can access my tools and the move things around behind it but I just cant get it to go away... and the important message that would probably tell me what it is is conveniently behind it I'm sure...
                • GaieusG
                  Shanna, you failed to attach the screenshot. You can use the edit button at the top of your post to add it (again?).
                    driven
                    hi,
                    image not attached?
                    if you right click on it do you have any options, in particular 'reload'...
                    • shannakaeS
                      shannakae
                      Ok, it looks like the screenshots are too large for me to add, let me resize them and I will resend.
                      • shannakaeS
                        shannakae
                        Ok I am attaching a screenshopt of the big whit box over my sketch up, and two images of what happend after I rand the Apple script editor as drected by "Driven".
                        white screen thing
                        apple script editor results
                        white screen
                          driven
                          in 'System Preferences' Pane you need to enable assistive devices, forgot about that sorry...
                          enable_GUI_scripting()
                          on enable_GUI_scripting()
                          	try
                          		if (system attribute "sysv") < 4138 then display dialog "This script requires the installation of Mac OS X 10.3 or higher." buttons {"Cancel"} default button 1 with icon 2
                          		tell application "System Events" to if not UI elements enabled then
                          			tell me
                          				activate
                          				display dialog "This script requires the built-in Graphic User Interface Scripting architecture of Mac OS X, which is currently disabled." & return & return & "Enable GUI Scripting now? (You may be asked to enter your password.)" buttons {"Cancel", "Enable"} default button 2 with icon 2
                          			end tell
                          			set UI elements enabled to true
                          			if not UI elements enabled then error number -128
                          		end if
                          		return "yes"
                          	on error
                          		return "no"
                          	end try
                          end enable_GUI_scripting
                          this should help, run in AppleScript Editor
                            driven
                            in your second image the menu bar says it's Safari?
                            long shot but, does the box go away if you close Safari?
                            • shannakaeS
                              shannakae
                              ok will do that, in the meantime here is another screenshot of what I get when I go to close sketch up....I picked discard changes and it closed down sketchup.
                              what happens when I close sketch up
                                driven
                                Ok,
                                If you 'Review Changes' then 'Save' or 'Discard' on both, does SU then close itself?
                                  driven
                                  if you turn off 'Instructor' does it go away?
                                  scroll area 1 of window "Instructor"
                                    driven
                                    hi
                                    you can edit out the long list from the above post if you want....
                                    what it tells me is you have these windows open
                                    %(#0000BF)[window 2, possibly a suspect
                                    window 3, possibly a suspect
                                    window "Instructor"
                                    window "Artisan" ,
                                    window "Round Corner" ,
                                    window "V-Ray for SketchUp" ,
                                    window "Albatross - SketchUp Pro" ,
                                    window "Untitled - SketchUp Pro" ,]
                                    you need to turn them off one at a time to find which it is...
                                    • jeff hammondJ
                                      yeah, that is indeed very weird and should not be happening..
                                      i wonder if it's somehow due to the retina display ? (ie- nobody in this thread has ever seen this before but none of us has a retina display either 😉 ) ..but it seems like you're getting a window that isn't refreshing..
                                      try to run sketchup in normal resolution:
                                      • right-click (2finger click) on the sketchup app inside the applications folder
                                      • choose 'Get Info' from the list
                                      • see if there's an option to 'open in low resolution' (or smthing like that)
                                      • try running sketchup again
                                      if that clears up the problem, i would report it to the SketchUp developers so they can try to narrow down the cause and fix it..
                                      if that doesn't clear it up.. honestly, you should probably take the computer to a genius bar if you have an apple store nearby.. there are so many variables here that it's going to be hard for someone to figure out the problem via a forum..
                                      good luck
                                      [edit] oh.. i would still try to turn off sketchup's autosave to see if that's triggering this..
                                      • daleD
                                        dale
                                        I have the Retina display on a 17" MacBook Pro, and I have never experienced this.
                                        This dialogue box is simply telling you you have 2 other SketchUp files open as well as the one you are working with, and you have not saved them recently.
                                        If you have not opened these files, they could be partially to blame.
                                        I notice you are on Mountain Lion, and there is an option in the OS (I'm new to Mountain Lion) that automatically opens any previous files when you start an application.
                                        If you go to your System Preferences under the Apple dropdown menu at the top left of the screen, and go to "General"
                                        You can make sure the "Close Windows when quitting an Application button is checked. You can also un-check the ask to keep changes dialogue to if you wish.
                                        • jeff hammondJ
                                          no such thing 😉
                                          apple ditched the 17" laptop all together after releasing the retinas..
                                          hi rez 17" was 1920 x 1200 (2.3m pixels)
                                          retina 15" is 2880 x 1800 (5m pixels)
                                          • GaieusG
                                            no such thing
                                            I really do not know where this is going. I mean it1s not just resolution but also size that you need to look at. What if they can squeeze 5 million pixels in a 1" monitor? Will they be happy? Can you tell those too close pixels apart? Will you still be able to see details?
                                            It's all humbug to me.
                                            • 1 / 4
