    Something like "follow me" tool is needed
    29 Posts 7 Posters 4.7k Views 7 Watching
    • B
      banan666
      Ok guys, finally I made it πŸ˜„
      http://s1.pokazywarka.pl/bigImages/1694527/5946503.jpg
      But how could I make other shape, for example circle, or square down there??
      http://s1.pokazywarka.pl/bigImages/1694531/5946506.jpg
        Maybe just draw tubes or long boxes πŸ˜„
        A simple Push pull can do that!
        And make intersections with a big box!
        Lines2tubes by Didier Bur can help you πŸ˜‰
        With it you can make from 3 sides to 100 section polygons !
        Just make lines bigger than the box for easy intersection!
        Seems each cylinder is a volume you can Make boolean operation with the pro version
        but you have not πŸ˜„
        so intersection will be a solution
        • B
          banan666
          I made a try of the "line2tube" plugin and it doesnt work for me with "boolean OSCoolean".
          Everything is ok with straight lines, but when I make some curves, then use "line2tube", and then try to use "boolean", nothing hapends. It only say: OSCoolean is processing....Nothing else.
          http://s1.pokazywarka.pl/bigImages/1704567/5982803.jpg
            Ps Anf for your beginning post I know a ruby coder who is making a ruby one so be patient πŸ˜„
              Better if you save also the skp file πŸ˜‰
              Like that I have not to modelize something!
              Seems works for me! β˜€
              I make the line to tube
              Kill the line generator
              Explode the tube volume
              Group it
              and all works fine πŸ˜„
              tube1.skp
              • B
                banan666
                I dont know why it doesnt work for me, please check my sketch.
                Untitled.skp
                  Ok I have found the problem πŸ˜‰
                  When you click your object (the curvated volume) and call the Info box model info..., that is not a "solid"!!!
                  so that can't work!
                  So make it as solid and all will work as a charm!
                  explode all, kill the middle ring, explode curve, kill the curve generator, make a group
                  = you must have a clean solid!
                  all works fine β˜€
                  tube2.skp
                    Well spotted Pilou !
                    A 'solid' is necessary for doing boolean operations.
                    A solid contains only faces and edges.
                    Every edge must have two faces.
                    No fewer and no more.
                    The 'tube' group as made still has the curve curve snaking up its center - edges with NO faces.
                    It also seem to have a central disk partition - edges with three faces !
                    I prefer an even simpler way of fixing this.
                    Edit the group, Xray mode and then pick the internal curves edges and Delete key.
                    Similarly with the 'disk'.
                    Now 'Entity Info' should report the selected group as being a 'solid'...
                      ...and an infinite new world is opening for you! πŸ˜„
                      • B
                        banan666
                        Thx guys for Your advices, it work with low angle lines. But it start to get problems when the curve its much biger, because when I use Arc to make a shepe, next line2tube I got a lot of gapes in the joints. I dont Know how to fix them, so I made second try with other shape maker, I used Cornu Spline from Curve Maker, the line2tubes, clean all internal curves and 'disks', and 'Entity Info' report me that the selected group as being not a 'solid', just group 1 in model...
                        http://s1.pokazywarka.pl/bigImages/1705709/5988047.jpg
                        TUBES.skp
                          Try Profile Builder !
                          With the free version you can't draw your own profile, but there are always tons inside! πŸ˜„
                          • B
                            banan666
                            I have tried it before, great tool, but it doesnt work for me with OSCoolean. All the time the same problem, I couldnt make Solid form, its all the time (Group 1 in model) in Entity info and I dont know what happening...
                            TUBES1.skp
                            • cottyC
                              cotty
                              You just have to close the two ends...
                              my SketchUp gallery
                                You can also use ' weld' [free script from smustard.com] on preselected connected arcs etc into one 'curve' before using a tool, to avoid separate parts getting made...
                                  Or Recurve by Diggsey πŸ˜‰
                                  • mitcorbM
                                    mitcorb
                                    A little way back you said in your reply: "next line2tube I got a lot of gapes in the joints. I dont Know how to fix them, so I made second try with other shape maker," Lines2tubes is an excellent script, but it will make segments of the tubes, and sometimes you want that. TIG's TubeAlongPath, or even PipeAlongPath makes smooth results. Just a thought.
                                    • B
                                      banan666
                                      Great, thank You very much Pilou for the amazing tutorials, I will try to make it tomorrow, because today I had problem with my PC, my hard disk was broken so I have to buy new one, then install windows and all the rest stuff.
                                      Im thinking all the time about this panel.
                                      http://s1.pokazywarka.pl/i/1711679/685769/bez-nazwy.jpg
                                      Now I now how to make pipe witch have the same width all the way, but how to change width, and depth at the same time. Like on the picture above, for example.
                                      • GaieusG
                                        With Curviloft maybe? Not even just change width but also the shape of the cross section (if you wish).
                                        • jeff hammondJ
                                          • B
                                            banan666
                                            Ive been try to use the OSCoolean tool and Substract from Solid tools but Ive all the time some strange errors. OSCoolean give me "erroe of the intersect with" and some numbers, 21,2 etc. Substract from Solid its the same. When I made one line its ok, but the I want to take another one its not working beacause firt use change the model, and its not SOLID.
                                            OSCoolean problem.rar
