    Something like "follow me" tool is needed
    29 Posts 7 Posters 4.7k Views 7 Watching
      You must start with a simple plan, not a volume!!!
      You can find a mutiple face offset here by R.Knowles
      Another one by Remus
      Lattice-izer by Tig can help for some thing
      And a more complex Offset multiples by Sdmitch
      • cottyC
        cotty
        @banan666 said:
        Firt I select the lines, but when I make a group of them, then I couldn`t use the "multiple offset".
        The group of lines is only used to make a fast selection of the lines after using multiple offset and has nothing to do with the offset process. For this, you select all faces and use the plugin.
        my SketchUp gallery
          Here a simple different method ๐Ÿ˜‰
          choco1.skp
            Ok I believe now a more easy method! โ˜€
            (because the Cotty method don't work for me : all corners are disturbed ! ๐Ÿ˜ฎ )
            (maybe the V6...)
            Draw a rectangle
            Trace your lines with the Zorro 2 by Whaat
            ( more easy but you can draw lines normally ๐Ÿ˜‰
            Select all
            Multi Faces Offset (with plugins above)
            Invert Selection by TIG so faces are selected ! The trick ! ๐Ÿ’ญ
            Move UP Faces + Alt
            That's all ๐Ÿ˜„
            • B
              banan666
              Ok guys, finally I made it ๐Ÿ˜„
              http://s1.pokazywarka.pl/bigImages/1694527/5946503.jpg
              But how could I make other shape, for example circle, or square down there??
              http://s1.pokazywarka.pl/bigImages/1694531/5946506.jpg
                Maybe just draw tubes or long boxes ๐Ÿ˜„
                A simple Push pull can do that!
                And make intersections with a big box!
                Lines2tubes by Didier Bur can help you ๐Ÿ˜‰
                With it you can make from 3 sides to 100 section polygons !
                Just make lines bigger than the box for easy intersection!
                Seems each cylinder is a volume you can Make boolean operation with the pro version
                but you have not ๐Ÿ˜„
                so intersection will be a solution
                • B
                  banan666
                  I made a try of the "line2tube" plugin and it doesnt work for me with "boolean OSCoolean".
                  Everything is ok with straight lines, but when I make some curves, then use "line2tube", and then try to use "boolean", nothing hapends. It only say: OSCoolean is processing....Nothing else.
                  http://s1.pokazywarka.pl/bigImages/1704567/5982803.jpg
                    Ps Anf for your beginning post I know a ruby coder who is making a ruby one so be patient ๐Ÿ˜„
                      Better if you save also the skp file ๐Ÿ˜‰
                      Like that I have not to modelize something!
                      Seems works for me! โ˜€
                      I make the line to tube
                      Kill the line generator
                      Explode the tube volume
                      Group it
                      and all works fine ๐Ÿ˜„
                      tube1.skp
                      • B
                        banan666
                        I dont know why it doesnt work for me, please check my sketch.
                        Untitled.skp
                          Ok I have found the problem ๐Ÿ˜‰
                          When you click your object (the curvated volume) and call the Info box model info..., that is not a "solid"!!!
                          so that can't work!
                          So make it as solid and all will work as a charm!
                          explode all, kill the middle ring, explode curve, kill the curve generator, make a group
                          = you must have a clean solid!
                          all works fine โ˜€
                          tube2.skp
                            Well spotted Pilou !
                            A 'solid' is necessary for doing boolean operations.
                            A solid contains only faces and edges.
                            Every edge must have two faces.
                            No fewer and no more.
                            The 'tube' group as made still has the curve curve snaking up its center - edges with NO faces.
                            It also seem to have a central disk partition - edges with three faces !
                            I prefer an even simpler way of fixing this.
                            Edit the group, Xray mode and then pick the internal curves edges and Delete key.
                            Similarly with the 'disk'.
                            Now 'Entity Info' should report the selected group as being a 'solid'...
                              ...and an infinite new world is opening for you! ๐Ÿ˜„
                              • B
                                banan666
                                Thx guys for Your advices, it work with low angle lines. But it start to get problems when the curve its much biger, because when I use Arc to make a shepe, next line2tube I got a lot of gapes in the joints. I dont Know how to fix them, so I made second try with other shape maker, I used Cornu Spline from Curve Maker, the line2tubes, clean all internal curves and 'disks', and 'Entity Info' report me that the selected group as being not a 'solid', just group 1 in model...
                                http://s1.pokazywarka.pl/bigImages/1705709/5988047.jpg
                                TUBES.skp
                                  Try Profile Builder !
                                  With the free version you can't draw your own profile, but there are always tons inside! ๐Ÿ˜„
                                  • B
                                    banan666
                                    I have tried it before, great tool, but it doesnt work for me with OSCoolean. All the time the same problem, I couldnt make Solid form, its all the time (Group 1 in model) in Entity info and I dont know what happening...
                                    TUBES1.skp
                                    • cottyC
                                      cotty
                                      You just have to close the two ends...
                                      my SketchUp gallery
                                        You can also use ' weld' [free script from smustard.com] on preselected connected arcs etc into one 'curve' before using a tool, to avoid separate parts getting made...
                                          Or Recurve by Diggsey ๐Ÿ˜‰
                                          • mitcorbM
                                            mitcorb
                                            A little way back you said in your reply: "next line2tube I got a lot of gapes in the joints. I dont Know how to fix them, so I made second try with other shape maker," Lines2tubes is an excellent script, but it will make segments of the tubes, and sometimes you want that. TIG's TubeAlongPath, or even PipeAlongPath makes smooth results. Just a thought.
