    Something like "follow me" tool is needed
    29 Posts 7 Posters 4.1k Views 7 Watching
      Maybe just draw tubes or long boxes πŸ˜„
      A simple Push pull can do that!
      And make intersections with a big box!
      Lines2tubes by Didier Bur can help you πŸ˜‰
      With it you can make from 3 sides to 100 section polygons !
      Just make lines bigger than the box for easy intersection!
      Seems each cylinder is a volume you can Make boolean operation with the pro version
      but you have not πŸ˜„
      so intersection will be a solution
        banan666
        I made a try of the "line2tube" plugin and it doesnt work for me with "boolean OSCoolean".
        Everything is ok with straight lines, but when I make some curves, then use "line2tube", and then try to use "boolean", nothing hapends. It only say: OSCoolean is processing....Nothing else.
        http://s1.pokazywarka.pl/bigImages/1704567/5982803.jpg
          Ps Anf for your beginning post I know a ruby coder who is making a ruby one so be patient πŸ˜„
            Better if you save also the skp file πŸ˜‰
            Like that I have not to modelize something!
            Seems works for me! β˜€
            I make the line to tube
            Kill the line generator
            Explode the tube volume
            Group it
            and all works fine πŸ˜„
            tube1.skp
              banan666
              I dont know why it doesnt work for me, please check my sketch.
              Untitled.skp
                Ok I have found the problem πŸ˜‰
                When you click your object (the curvated volume) and call the Info box model info..., that is not a "solid"!!!
                so that can't work!
                So make it as solid and all will work as a charm!
                explode all, kill the middle ring, explode curve, kill the curve generator, make a group
                = you must have a clean solid!
                all works fine β˜€
                tube2.skp
                  Well spotted Pilou !
                  A 'solid' is necessary for doing boolean operations.
                  A solid contains only faces and edges.
                  Every edge must have two faces.
                  No fewer and no more.
                  The 'tube' group as made still has the curve curve snaking up its center - edges with NO faces.
                  It also seem to have a central disk partition - edges with three faces !
                  I prefer an even simpler way of fixing this.
                  Edit the group, Xray mode and then pick the internal curves edges and Delete key.
                  Similarly with the 'disk'.
                  Now 'Entity Info' should report the selected group as being a 'solid'...
                    ...and an infinite new world is opening for you! πŸ˜„
                      banan666
                      Thx guys for Your advices, it work with low angle lines. But it start to get problems when the curve its much biger, because when I use Arc to make a shepe, next line2tube I got a lot of gapes in the joints. I dont Know how to fix them, so I made second try with other shape maker, I used Cornu Spline from Curve Maker, the line2tubes, clean all internal curves and 'disks', and 'Entity Info' report me that the selected group as being not a 'solid', just group 1 in model...
                      http://s1.pokazywarka.pl/bigImages/1705709/5988047.jpg
                      TUBES.skp
                        Try Profile Builder !
                        With the free version you can't draw your own profile, but there are always tons inside! πŸ˜„
                          banan666
                          I have tried it before, great tool, but it doesnt work for me with OSCoolean. All the time the same problem, I couldnt make Solid form, its all the time (Group 1 in model) in Entity info and I dont know what happening...
                          TUBES1.skp
                          • cottyC Offline
                            cotty
                            You just have to close the two ends...
                            my SketchUp gallery
                              You can also use ' weld' [free script from smustard.com] on preselected connected arcs etc into one 'curve' before using a tool, to avoid separate parts getting made...
                                Or Recurve by Diggsey πŸ˜‰
                                • mitcorbM Offline
                                  mitcorb
                                  A little way back you said in your reply: "next line2tube I got a lot of gapes in the joints. I dont Know how to fix them, so I made second try with other shape maker," Lines2tubes is an excellent script, but it will make segments of the tubes, and sometimes you want that. TIG's TubeAlongPath, or even PipeAlongPath makes smooth results. Just a thought.
                                    banan666
                                    Great, thank You very much Pilou for the amazing tutorials, I will try to make it tomorrow, because today I had problem with my PC, my hard disk was broken so I have to buy new one, then install windows and all the rest stuff.
                                    Im thinking all the time about this panel.
                                    http://s1.pokazywarka.pl/i/1711679/685769/bez-nazwy.jpg
                                    Now I now how to make pipe witch have the same width all the way, but how to change width, and depth at the same time. Like on the picture above, for example.
                                      With Curviloft maybe? Not even just change width but also the shape of the cross section (if you wish).
                                      • jeff hammondJ Offline
                                          banan666
                                          Ive been try to use the OSCoolean tool and Substract from Solid tools but Ive all the time some strange errors. OSCoolean give me "erroe of the intersect with" and some numbers, 21,2 etc. Substract from Solid its the same. When I made one line its ok, but the I want to take another one its not working beacause firt use change the model, and its not SOLID.
                                          OSCoolean problem.rar
                                            Before a dedicated plugin "Follow me Multiple" who is quasi terminated β˜€
                                            here a workflow for one of your image πŸ˜‰
                                            You will must use twice the Menu Window / Ruby console πŸ€“
                                            Image 1 : Select all the Protrude's faces : Protrude by Jim Foltz
                                            and input the text folling inside the Ruby Console for transform each faces on components
                                            Must be on only one line (use the Notepad for verify)
                                            Press Enter (Thx TIG) - Press the Select All, Right Click and copy past on your Ruby Console
                                            m=Sketchup.active_model;n=m.active_entities;m.selection.to_a.each{|e|(g=n.add_group(e);g.to_component.definition.name="Face#1")if e.class==Sketchup;;Face}
                                            Image 2
                                            Give a thickness to the components selection
                                            (again the text following must be on one line in the Ruby COnsole)
                                            Press Enter (Thx Sdmitch) -Press the Select All, Right Click and copy past on your Ruby Console
                                            mod=Sketchup.active_model;sel=mod.selection;sel.grep(Sketchup;;ComponentInstance).each{|c| c.definition.entities.each{|f|(f.pushpull -1;break) if f.class==Sketchup;;Face}}
                                            Image 3
                                            Make any component volume that you want
                                            Select all the "faces components"
                                            And Call the Component Dropper by Thomthom
                                            Just click your module made has you want πŸ˜‰
                                            That all! β˜€
                                            Ps You can scale on x,y,z before or / and after the "Components Dropper"
