    Something like "follow me" tool is needed
    29 Posts 7 Posters 4.5k Views 7 Watching
      ...and an infinite new world is opening for you! πŸ˜„
        banan666
        Thx guys for Your advices, it work with low angle lines. But it start to get problems when the curve its much biger, because when I use Arc to make a shepe, next line2tube I got a lot of gapes in the joints. I dont Know how to fix them, so I made second try with other shape maker, I used Cornu Spline from Curve Maker, the line2tubes, clean all internal curves and 'disks', and 'Entity Info' report me that the selected group as being not a 'solid', just group 1 in model...
        http://s1.pokazywarka.pl/bigImages/1705709/5988047.jpg
        TUBES.skp
          Try Profile Builder !
          With the free version you can't draw your own profile, but there are always tons inside! πŸ˜„
            banan666
            I have tried it before, great tool, but it doesnt work for me with OSCoolean. All the time the same problem, I couldnt make Solid form, its all the time (Group 1 in model) in Entity info and I dont know what happening...
            TUBES1.skp
            • cottyC Offline
              cotty
              You just have to close the two ends...
              my SketchUp gallery
                You can also use ' weld' [free script from smustard.com] on preselected connected arcs etc into one 'curve' before using a tool, to avoid separate parts getting made...
                  Or Recurve by Diggsey πŸ˜‰
                  • mitcorbM Offline
                    mitcorb
                    A little way back you said in your reply: "next line2tube I got a lot of gapes in the joints. I dont Know how to fix them, so I made second try with other shape maker," Lines2tubes is an excellent script, but it will make segments of the tubes, and sometimes you want that. TIG's TubeAlongPath, or even PipeAlongPath makes smooth results. Just a thought.
                      banan666
                      Great, thank You very much Pilou for the amazing tutorials, I will try to make it tomorrow, because today I had problem with my PC, my hard disk was broken so I have to buy new one, then install windows and all the rest stuff.
                      Im thinking all the time about this panel.
                      http://s1.pokazywarka.pl/i/1711679/685769/bez-nazwy.jpg
                      Now I now how to make pipe witch have the same width all the way, but how to change width, and depth at the same time. Like on the picture above, for example.
                        With Curviloft maybe? Not even just change width but also the shape of the cross section (if you wish).
                        • jeff hammondJ Offline
                            banan666
                            Ive been try to use the OSCoolean tool and Substract from Solid tools but Ive all the time some strange errors. OSCoolean give me "erroe of the intersect with" and some numbers, 21,2 etc. Substract from Solid its the same. When I made one line its ok, but the I want to take another one its not working beacause firt use change the model, and its not SOLID.
                            OSCoolean problem.rar
                              Before a dedicated plugin "Follow me Multiple" who is quasi terminated β˜€
                              here a workflow for one of your image πŸ˜‰
                              You will must use twice the Menu Window / Ruby console πŸ€“
                              Image 1 : Select all the Protrude's faces : Protrude by Jim Foltz
                              and input the text folling inside the Ruby Console for transform each faces on components
                              Must be on only one line (use the Notepad for verify)
                              Press Enter (Thx TIG) - Press the Select All, Right Click and copy past on your Ruby Console
                              m=Sketchup.active_model;n=m.active_entities;m.selection.to_a.each{|e|(g=n.add_group(e);g.to_component.definition.name="Face#1")if e.class==Sketchup;;Face}
                              Image 2
                              Give a thickness to the components selection
                              (again the text following must be on one line in the Ruby COnsole)
                              Press Enter (Thx Sdmitch) -Press the Select All, Right Click and copy past on your Ruby Console
                              mod=Sketchup.active_model;sel=mod.selection;sel.grep(Sketchup;;ComponentInstance).each{|c| c.definition.entities.each{|f|(f.pushpull -1;break) if f.class==Sketchup;;Face}}
                              Image 3
                              Make any component volume that you want
                              Select all the "faces components"
                              And Call the Component Dropper by Thomthom
                              Just click your module made has you want πŸ˜‰
                              That all! β˜€
                              Ps You can scale on x,y,z before or / and after the "Components Dropper"
                                And on image 2 you can put a randomly thickness! THX Sdmitch
                                Just use this line against the above
                                You replace "100" by any number you want! (rand*100)
                                    mod=Sketchup.active_model;sel=mod.selection;sel.grep(Sketchup;;ComponentInstance).each{|c| c.definition.entities.each{|f|(f.pushpull -(rand*100);break) if f.class==Sketchup;;Face}}
                                THX Sdmitch! β˜€
                                • 2 / 2
