    Barley Twist Spirals
    119 Posts 12 Posters 13.4k Views 12 Watching
      archturn
      @gilles said:
      Just a question: why use two plugins instead of one which does very well the job?
      I'm going to try them all. I remeber some time back trying the "draw helix" without the "follow me keep" tool. That was one of the times I gave up. The result from using the native "follow me" is pretty ugly so I thought I would see what this tool was all about.
      Again, I wasted a lot of time by not coming here first.
        archturn
        @gilles said:
        screw1_5.rb.
        select 3 profiles (in the following case), set start point, set end point, enter n steps n turn and go.
        Could you elaborate on using screw1_5??
        • gillesG Offline
          gilles
          Will do later, its late here in France and I should sleep.
          • jeff hammondJ Offline
            use a whole bunch of profile curves then apply wonky style?
            • daleD Offline
              dale
              Just a quick question. In reality, can you turn a Barley Twist, or is it more of a carving exercise?
                Dale, barley twists can be turned, sort of. There's a machine that combines a router with a lathe and gears them together for creating barley twists and other ornamental milling. Check out this link. I used to have one of their machines and used it a lot. Of course now with CNC-driven equipment, it gets even more sophisticated. I can't say I would recommend dealing with the company but the idea was interesting.
                • daleD Offline
                  dale
                  Thanks Dave, really interesting machine. I often wish I was a machinist, boy there would be trouble then.
                    archturn
                    Here are two videos of turning a barley twist and then a rope twist on my machine.
                    http://www.youtube.com/watch?v=LcjVLg0ql7c
                    Barley Twist
                    http://www.youtube.com/watch?v=0zVD22NqgSc>
                    Rope Twist
                    • daleD Offline
                      dale
                      That's Great. So can you directly import from SketchUp to you machine?
                      ( Oh and, I guess I'm still living in the past, as I was thinking of how difficult if not impossible to turn it by hand. 😳 )
                        archturn
                        My machine is not a full CNC but a step below it. It is a hydraulic copier so it traces a profile. The indexing function (used for the twisting) however is computer controlled so the setting up of gears and indexing pins that Dave R referred is not necessary. The templates I use for the turning profile are drawn in CAD and sent to a machine shop with a laser CNC so I can get a pretty fine template for tracing
                          archturn
                          @archturn said:
                          As for turning by hand, it's not impossible but I wouldn't want to make a living like that.
                            Archturn, I was just looking at an old book on turning from the Gutenberg Project and toward the end they spend some time talking about doing various spiral turning by hand. They show some pretty cool examples in the photos. I'm sure you're getting them done in a lot less time.
                            Talk to you tonight with live demo. πŸ˜‰
                              archturn
                              I've had to do 100-200 at a time so it's not really feasible for the turnings I do. God Bless 'em for they were able to do 100 years ago.
                              • gillesG Offline
                                gilles
                                About Screw1_5.rb:
                                Download to:
                                http://rhin.crai.archi.fr/rld/plugin_details.php?id=357
                                In fact Screw1_5.rb is version 3 not 1.5 so this the most achieve.
                                # Name ;          Screw 3.0
                                # Description ;   screw/spins a set of edges/components around the
                                #                 z-axis (if "turns" is a negative number, rotation
                                #                 is clockwise)
                                # Author ;        Frank Wiesner
                                # Usage ;         1. select edges and/or Components
                                #                 2. run script
                                #                 3. enter desired values in dialog box
                                #                 4. pick two points (offset vector)
                                # Note;           selecting the "spin" tool is a shortcut for selecting
                                #                 the "screw" tool and picking two identical points for
                                #                 the offset vector.
                                # Date ;          25.Jun.2oo5
                                # Type ;          script
                                # History;
                                #                 3.0 (25.Jun.2005) - offset vector is picked interactively
                                #                 2.2 (31.Aug.2004) - supports spin operation
                                #                 2.1 (31.Aug.2004) - remembers turn/step values during SU session
                                #                                     expressions in dialog (i.e. use turns = 483/360.0 for a 483 degrees turn)
                                #                 2.0 (30.Aug.2004) - support for ConstructionPoints
                                #                                     instant drawing (although Sketchup does not update during execution)
                                #                                     status info
                                #                                     new algorithm for offset vector
                                #                                     fractional value support
                                #                 1.4  (5.Aug.2oo4) - cleaned up ugly transformation code, script now faster
                                #                                     error checking for "add_face'; Points are not planar" errors
                                #                 1.3  (4.Aug.2oo4) - support for components
                                #                 1.2  (4.Aug.2oo4) - edges are smoothed
                                #                 1.1  (3.Aug.2oo4) - if "turns" is a negative number, rotation is clockwise, minor fixes
                                #                 1.o  (3.Aug.2oo4) - first version
                                  archturn
                                  Thanks Gilles
                                  • pbacotP Offline
                                    Next project?
                                    http://cache.virtualtourist.com/4/1793507-Baldacchino_canopy_Vatican_City.jpg
                                      archturn
                                      Piece of cake...lol
                                        archturn
                                        @gilles said:
                                        Here is a step by step.
                                        Gilles
                                        I've used your method for the barley twist. Thanks to you and Dave R the twist (using the screw plugin) is a piece of cake. The "intersect model" used to join the newel with the twist , however, is another thing altogether. I'm really struggling with that part of it. Can you give me any pointers?
                                          archturn
                                          I've been having a time trying to intersect the barley twisted part into the rest of the newel. watched YTube videos and I'm wondering if there is an issue with intersecting complex surfaces?N114.jpg
                                            I can't tell from your image but it could be you are running up against SketchUp's dislike of tiny faces. It won't fill in very tiny ones which will leave a ragged edge. The fix is to perform the intersection after scaling the model up by a factor of 100 or 1000.
                                            It looks like you could use some softening of the ends, there and your barley twist is inside out. πŸ˜‰
                                            Are you making the intersecting 'bowl' in the same context as the twist?
                                            • 2 / 6
