    Barley Twist Spirals
    119 Posts 12 Posters 20.0k Views 12 Watching
      archturn
      @gilles said:
      Made in one shot with screw1_5.rb.
      AND it works also with components.
      This is what we call a rope twist not a barley twist. The barley twist has another (interior) radius. The rope twist looks like rope - though your method may work for a barley twist as well. David R's is definitely a barley
        @gilles said:
        Here is a step by step.
        Nice rope twist. ๐Ÿ˜‰
          archturn
          Love your solution but I need to fit it to the other part of my newel. Gilles method looks like it will work. In CAD I'll usually do a sweep of the newel profile then draw my barley twist profile - sweep the barley profile with the correct pitch then subtract it from my newel sweep. I wish I could do it this way (specifically the subtract function) in SU since this yields the most realistic geometry - though again Gilles looks pretty right (just needs more interior radius to be classified as a true barley twist). Thanks
          • gillesG
            gilles
            Its up to you to create the good profile. ๐Ÿ’š
            You can also do this with screw:
              archturn, you could use the method I showed and create the transitions when you've finished. There isn't any reason you couldn't fit it to the rest of the turning. I did on the table legs. The transitions are similar to creating the pommels which I've showed in several other blog posts so I didn't bother with them in that one. The Screw plugin is nice, too. although you can do multiple starts the way Gilles shows, I would still make a single turn as a component and copy it as I did in the blog to keep file size down and make it easier to adjust the length.
              • gillesG
                gilles
                Totally agree with this. ๐Ÿ‘
                • charly2008C
                  charly2008
                  here are two more options
                    archturn
                    I can see that I should have been visiting the forum more frequently instead of pulling my hair out. Awesome!!!
                      Yes. You should have. ๐Ÿ˜‰ And as I wrote before, there's more than one way to arrive at the final result in SketchUp. This is a great example.
                        archturn
                        @charly2008 said:
                        Charly
                        I'm wondering how to use the "follow me keep" plugin". I installed it and though it shows up in my plugin menu nothing seems to happen when I click it.
                        • massimoM
                          massimo Moderator
                          You have first to select both the path and the face and then run the plugin.
                          • gillesG
                            gilles
                            Just a question: why use two plugins instead of one which does very well the job?
                              archturn
                              I'm going to try them all. I remeber some time back trying the "draw helix" without the "follow me keep" tool. That was one of the times I gave up. The result from using the native "follow me" is pretty ugly so I thought I would see what this tool was all about.
                              Again, I wasted a lot of time by not coming here first.
                                archturn
                                @gilles said:
                                screw1_5.rb.
                                select 3 profiles (in the following case), set start point, set end point, enter n steps n turn and go.
                                Could you elaborate on using screw1_5??
                                • gillesG
                                  gilles
                                  Will do later, its late here in France and I should sleep.
                                  • jeff hammondJ
                                    use a whole bunch of profile curves then apply wonky style?
                                    • daleD
                                      dale
                                      Just a quick question. In reality, can you turn a Barley Twist, or is it more of a carving exercise?
                                        Dale, barley twists can be turned, sort of. There's a machine that combines a router with a lathe and gears them together for creating barley twists and other ornamental milling. Check out this link. I used to have one of their machines and used it a lot. Of course now with CNC-driven equipment, it gets even more sophisticated. I can't say I would recommend dealing with the company but the idea was interesting.
                                        • daleD
                                          dale
                                          Thanks Dave, really interesting machine. I often wish I was a machinist, boy there would be trouble then.
                                            archturn
                                            Here are two videos of turning a barley twist and then a rope twist on my machine.
                                            http://www.youtube.com/watch?v=LcjVLg0ql7c
                                            Barley Twist
                                            http://www.youtube.com/watch?v=0zVD22NqgSc>
                                            Rope Twist
                                            • 2 / 6
