    Barley Twist Spirals
    119 Posts 12 Posters 10.0k Views 12 Watching
      @gilles said:
      Sorry Dave, there are two starts and I could have done n starts in one shot.
      Show the setup. And which version of Screw are you using.
      • gillesG Offline
        gilles
        screw1_5.rb.
        select 3 profiles (in the following case), set start point, set end point, enter n steps n turn and go.
          Thanks. that should help the OP.
          Isn't it great there are usually multiple ways to arrive at the same point in SketchUp?
          And you finally drew a barley twist. πŸ˜‰ Here's a cutter profile for that.
          http://ecx.images-amazon.com/images/I/31uqkUSlwNL.jpg
            @dave r said:
            Pilou, you trot that video out every time someone asks how to draw anything. πŸ˜’ πŸ˜†
            That's not a barley twist either.
            True but otherwise a brilliant solution!
            (I could imagine Kito Raupp is Pilou himself in a humble disguise)
            πŸ˜†
            • gillesG Offline
              gilles
              Here is a step by step.
              profile
              follow me around the circle
              erase unwanted
              intersect
              erase unwanted
              select the two profiles (center must be on blue axis at origin) run screw plugin
              cut  unwanted whit zorro plugin
              intersect
              erase unwanted
                archturn
                @gilles said:
                Made in one shot with screw1_5.rb.
                AND it works also with components.
                This is what we call a rope twist not a barley twist. The barley twist has another (interior) radius. The rope twist looks like rope - though your method may work for a barley twist as well. David R's is definitely a barley
                  Nice rope twist. πŸ˜‰
                    archturn
                    Love your solution but I need to fit it to the other part of my newel. Gilles method looks like it will work. In CAD I'll usually do a sweep of the newel profile then draw my barley twist profile - sweep the barley profile with the correct pitch then subtract it from my newel sweep. I wish I could do it this way (specifically the subtract function) in SU since this yields the most realistic geometry - though again Gilles looks pretty right (just needs more interior radius to be classified as a true barley twist). Thanks
                    • gillesG Offline
                      gilles
                      Its up to you to create the good profile. πŸ’š
                      You can also do this with screw:
                        archturn, you could use the method I showed and create the transitions when you've finished. There isn't any reason you couldn't fit it to the rest of the turning. I did on the table legs. The transitions are similar to creating the pommels which I've showed in several other blog posts so I didn't bother with them in that one. The Screw plugin is nice, too. although you can do multiple starts the way Gilles shows, I would still make a single turn as a component and copy it as I did in the blog to keep file size down and make it easier to adjust the length.
                        • gillesG Offline
                          gilles
                          Totally agree with this. πŸ‘
                          • charly2008C Offline
                            charly2008
                            here are two more options
                              archturn
                              I can see that I should have been visiting the forum more frequently instead of pulling my hair out. Awesome!!!
                                Yes. You should have. πŸ˜‰ And as I wrote before, there's more than one way to arrive at the final result in SketchUp. This is a great example.
                                  archturn
                                  @charly2008 said:
                                  Charly
                                  I'm wondering how to use the "follow me keep" plugin". I installed it and though it shows up in my plugin menu nothing seems to happen when I click it.
                                  • massimoM Offline
                                    massimo Moderator
                                    You have first to select both the path and the face and then run the plugin.
                                    • gillesG Offline
                                      gilles
                                      Just a question: why use two plugins instead of one which does very well the job?
                                        archturn
                                        I'm going to try them all. I remeber some time back trying the "draw helix" without the "follow me keep" tool. That was one of the times I gave up. The result from using the native "follow me" is pretty ugly so I thought I would see what this tool was all about.
                                        Again, I wasted a lot of time by not coming here first.
                                          archturn
                                          @gilles said:
                                          screw1_5.rb.
                                          Could you elaborate on using screw1_5??
                                          • gillesG Offline
                                            gilles
                                            Will do later, its late here in France and I should sleep.
                                            • 2 / 6
