    What's the best way ?! [Organic Shapes - Buildings]
    63 Posts 13 Posters 16.2k Views 13 Watching
    • yitzharY
      yitzhar
      i find out that the easy way was -
      draw the edges curves and than use this Extrude Edges by rail to lattice by Tig
      but this is if you only work with face and not circuls ..
      look for us on facebook : creatioIL
        DOD3R
        could it be done with one component? for example I make some crazy geometry and than triangle component. Is there any way how, to make that geometry from one triangular component?
        • jeff hammondJ
          • The vertical and horizontal cross-sections of the tower are all unique.
          • There is an asymmetric shape – no two rooms are the same. Every one of the 12,500 panes of glass on the façade is a different size, although each pane is triangular.
          • All 8,250 steel diagrid members are different thicknesses, length and orientation.
          more here:
          http://www.ctbuh.org/TallBuildings/FeaturedTallBuildings/CapitalGateTowerAbuDhabi/tabid/3380/language/en-GB/Default.aspx
          • yitzharY
            yitzhar
            jaff so whats your way for modeling that ?
              DOD3R
              LSS toolbar looks great, but didnt try it yet.
                Jeff so whats your way for modeling that ?
                I am affraid that you must draw one by one!
                If you want make "a real copycat" of course 😄
                • yitzharY
                  yitzhar
                  the lss tools is great tool - i used it mixing it with the edges to rails -
                  the lss for making the floors and the panes and than i took the edges to rails plugin
                  to make the grid with glass on the curve faces.
                  and did it twice one from the bottom up and one from up to the bottom that way you getting
                  X SHAPES for the grid and not \ DIRECTION ...
                    Show us some images of results 😉
                      altab
                      I second that.
                      • jeff hammondJ
                        my way? i'd use rhino's paneling tools.. i mean, the paneling tools are made for this type of stuff.. why make life difficult by trying to do it in sketchup 😉
                        2 rail sweep to get a surface..
                        make a paneling grid..
                        populate the grid with shape of your choice..
                          Rhino 5?
                          • jeff hammondJ
                            @thomthom said:
                            Rhino 5?
                            yeah.. (there is no rhino 4 for mac.. and actually, there's no official rhino 5 on mac either 😉.. still a beta)
                              Or in Moment of Inspiration where you can project any volumes on an another tortured one! 💚
                              Here my little triangles are not all in the same plan
                              so the circular "side" is slighty offseted
                              Colors are randomized on each volume!
                              Of course each triangle is deformed following the form!
                              • jeff hammondJ
                                yeah.. that's the same as flow along a surface in rhino.. doing that (obviously) distorts the shape to match the surface (i.e.- they are no longer triangles.)
                                paneling tools doesn't do that… in the drawing i posted above, all of the members of the triangles remain straight.. it's only the length & angles that change in order to fill the grid..
                                  Yep, i must just rotate source(& size) and target on the good directions for have the same 😉
                                  PS Have you seen the little Conoïde membrane problem?
                                  It's for you! 😉
                                  • jeff hammondJ
                                    It's for you! 😉
                                    haha.. i haven't opened that thread yet.. and i better not -- i have some things to do today..
                                    ok.. maybe just a peek 😄
                                    [EDiT].. same thing for that as this.. the conoid membrane is literally a 30 second deal in rhino and that's how i would draw something like that.. since this is a sketchup forum, i'll refrain from posting "use rhino for this" in yet another thread.. 😆
                                    • yitzharY
                                      yitzhar
                                      this is something in progress ...
                                      the tall building isnt the same as i wanted to saw at dubai's picture
                                      but all in all this is the sample of the mixed plugin i used.
                                      p.s. about the last rhino issue ... i knew i can make it easier in rhino
                                      but im trying to chack sketchup limition 😄
                                      sample
                                        In fact you right! 😉
                                        I must find another trick 😳
                                        Something like LineWeb / Planar = gride paneling
                                        So my volume is "facettized", so the Flow function don't curvate the triangles! 😉
                                        • jeff hammondJ
                                          it's not that you can't draw this in sketchup (i mean, i've driven a nail with pliers before.. plenty of times 😉 )
                                          it's just that it's a fairly convoluted process to do it in sketchup and once you've drawn something, you're stuck with it.. and it's a whole lot of work to start over with this type of process until you get the proportions etc correct..
                                          in all reality, my sketchup approach would go something like this:
                                          1)- draw the main profile curves with a whole bunch of segments per curve (the vertical profiles have 500 segments in this example) (i'm using fredo's BezierSpline plugin for these curves).. group the curves..
                                          2)- array a plane to represent the floors... using the line tool, custom draw new profiles.. the vertices will occur at the intersection of each floor plane and the mega-segmented curves.. using BZ-convert to, change the top and bottom curves to the same amount of evenly spaced segments (i used 10 in this case)..
                                          3)- while this looks pretty much the same as step #1, it's not.. the profile curves are now set up to make a proper grid on this shape..
                                          4)- using CurviLoft's skinning function, set it to generate edges only... you now have a nice grid to place your panel profiles over..
                                          5)- (next image) -- use profile builder to manually populate the grid.. only 30+ more floors to go then mirror it 😉
                                            A very cool solution! 👍
                                            • 1 / 4
