    What's the best way ?! [Organic Shapes - Buildings]
    63 Posts 13 Posters 11.9k Views 13 Watching
    • yitzharY Offline
      yitzhar
      hi everyone
      what would be the best way for doing constractions like those curved?
      i tried out few ways -
      first i built the shape with lss tool - blend for the curved shape
      than i thought i would seperate the wireframe and make the line to pipe tool
      for the line without the faces ... but i only got the floor line and one more
      line in one direction .. i need the mirror line too and more of the complex cons'.
      tried the subdiv' tools but they all still have one directions line and not two sides.
      what do you say ?
      look for us on facebook : creatioIL
        Maybe this Extrude Edges by rail to lattice by Tig ?
        • yitzharY Offline
          yitzhar
          i have tried lattice by tig its little bit hard to under stand and to get that shapes ...
          i need to have the shape as it shown on the pictures under the glass ... the metals ?
          someone can give me and other tutorial please?
          thank you
          • gillesG Offline
            gilles
            Something like this?
            FredoScale http://sketchucation.com/forums/viewtopic.php?t=42089
            FFD http://sketchucation.com/forums/viewtopic.php?t=6029#p36127
            leaning-building.skp
            • yitzharY Offline
              yitzhar
              YES, this is exactly what i ment (to directions for the line)
              please can you give little more details on how excactly you did it ?
              thank you
              • gillesG Offline
                gilles
                Just drawn two floors, copy, deform with Fredo's taper and Cphillips FFD.
                Did you open the file?
                Pour Pilou avant réclamation.
                • yitzharY Offline
                  yitzhar
                  the problem is with the lines and not with the curve shape...
                  i know how to make the twist but not the constr' lines that you showed in your file.
                  its look like trinangle shapes on the faces and on your file its look like 2 trin' on same shape
                  • gillesG Offline
                    gilles
                    I just drawn them in the first step, not a big deal.
                      DOD3R
                      Hi guys,
                      Its possible to make it from same triangles?
                      So it would be easier to prefabricate and construct (one triangular window)?
                      • yitzharY Offline
                        yitzhar
                        i find out that the easy way was -
                        draw the edges curves and than use this Extrude Edges by rail to lattice by Tig
                        but this is if you only work with face and not circuls ..
                          DOD3R
                          could it be done with one component? for example I make some crazy geometry and than triangle component. Is there any way how, to make that geometry from one triangular component?
                          • jeff hammondJ Offline
                            • The vertical and horizontal cross-sections of the tower are all unique.
                            • There is an asymmetric shape – no two rooms are the same. Every one of the 12,500 panes of glass on the façade is a different size, although each pane is triangular.
                            • All 8,250 steel diagrid members are different thicknesses, length and orientation.
                            more here:
                            http://www.ctbuh.org/TallBuildings/FeaturedTallBuildings/CapitalGateTowerAbuDhabi/tabid/3380/language/en-GB/Default.aspx
                            • yitzharY Offline
                              yitzhar
                              jaff so whats your way for modeling that ?
                                DOD3R
                                LSS toolbar looks great, but didnt try it yet.
                                  Jeff so whats your way for modeling that ?
                                  I am affraid that you must draw one by one!
                                  If you want make "a real copycat" of course 😄
                                  • yitzharY Offline
                                    yitzhar
                                    the lss tools is great tool - i used it mixing it with the edges to rails -
                                    the lss for making the floors and the panes and than i took the edges to rails plugin
                                    to make the grid with glass on the curve faces.
                                    and did it twice one from the bottom up and one from up to the bottom that way you getting
                                    X SHAPES for the grid and not \ DIRECTION ...
                                      Show us some images of results 😉
                                        altab
                                        I second that.
                                          my way? i'd use rhino's paneling tools.. i mean, the paneling tools are made for this type of stuff.. why make life difficult by trying to do it in sketchup 😉
                                          2 rail sweep to get a surface..
                                          make a paneling grid..
                                          populate the grid with shape of your choice..
                                            Rhino 5?
                                            • 1 / 4
