    What's the best way ?! [Organic Shapes - Buildings]
    63 Posts 13 Posters 16.2k Views 13 Watching
    • yitzharY
      yitzhar
      i have tried lattice by tig its little bit hard to under stand and to get that shapes ...
      i need to have the shape as it shown on the pictures under the glass ... the metals ?
      someone can give me and other tutorial please?
      thank you
      look for us on facebook : creatioIL
      • gillesG
        gilles
        Something like this?
        FredoScale http://sketchucation.com/forums/viewtopic.php?t=42089
        FFD http://sketchucation.com/forums/viewtopic.php?t=6029#p36127
        leaning-building.skp
        • yitzharY
          yitzhar
          YES, this is exactly what i ment (to directions for the line)
          please can you give little more details on how excactly you did it ?
          thank you
          • gillesG
            gilles
            Just drawn two floors, copy, deform with Fredo's taper and Cphillips FFD.
            Did you open the file?
            Pour Pilou avant réclamation.
            • yitzharY
              yitzhar
              the problem is with the lines and not with the curve shape...
              i know how to make the twist but not the constr' lines that you showed in your file.
              its look like trinangle shapes on the faces and on your file its look like 2 trin' on same shape
              • gillesG
                gilles
                I just drawn them in the first step, not a big deal.
                  DOD3R
                  Hi guys,
                  Its possible to make it from same triangles?
                  So it would be easier to prefabricate and construct (one triangular window)?
                  • yitzharY
                    yitzhar
                    i find out that the easy way was -
                    draw the edges curves and than use this Extrude Edges by rail to lattice by Tig
                    but this is if you only work with face and not circuls ..
                      DOD3R
                      could it be done with one component? for example I make some crazy geometry and than triangle component. Is there any way how, to make that geometry from one triangular component?
                      • jeff hammondJ
                        • The vertical and horizontal cross-sections of the tower are all unique.
                        • There is an asymmetric shape – no two rooms are the same. Every one of the 12,500 panes of glass on the façade is a different size, although each pane is triangular.
                        • All 8,250 steel diagrid members are different thicknesses, length and orientation.
                        more here:
                        http://www.ctbuh.org/TallBuildings/FeaturedTallBuildings/CapitalGateTowerAbuDhabi/tabid/3380/language/en-GB/Default.aspx
                        • yitzharY
                          yitzhar
                          jaff so whats your way for modeling that ?
                            DOD3R
                            LSS toolbar looks great, but didnt try it yet.
                              Jeff so whats your way for modeling that ?
                              I am affraid that you must draw one by one!
                              If you want make "a real copycat" of course 😄
                              • yitzharY
                                yitzhar
                                the lss tools is great tool - i used it mixing it with the edges to rails -
                                the lss for making the floors and the panes and than i took the edges to rails plugin
                                to make the grid with glass on the curve faces.
                                and did it twice one from the bottom up and one from up to the bottom that way you getting
                                X SHAPES for the grid and not \ DIRECTION ...
                                  Show us some images of results 😉
                                    altab
                                    I second that.
                                    • jeff hammondJ
                                      my way? i'd use rhino's paneling tools.. i mean, the paneling tools are made for this type of stuff.. why make life difficult by trying to do it in sketchup 😉
                                      2 rail sweep to get a surface..
                                      make a paneling grid..
                                      populate the grid with shape of your choice..
                                        Rhino 5?
                                        • jeff hammondJ
                                          @thomthom said:
                                          Rhino 5?
                                          yeah.. (there is no rhino 4 for mac.. and actually, there's no official rhino 5 on mac either 😉.. still a beta)
                                            Or in Moment of Inspiration where you can project any volumes on an another tortured one! 💚
                                            Here my little triangles are not all in the same plan
                                            so the circular "side" is slighty offseted
                                            Colors are randomized on each volume!
                                            Of course each triangle is deformed following the form!
                                            • 1 / 4
