What's the best way ?! [Organic Shapes - Buildings]
63 Posts 13 Posters 10.1k Views
  • Y Offline
    yitzhar
    hi everyone
    what would be the best way for doing constractions like those curved?
    i tried out few ways -
    first i built the shape with lss tool - blend for the curved shape
    than i thought i would seperate the wireframe and make the line to pipe tool
    for the line without the faces ... but i only got the floor line and one more
    line in one direction .. i need the mirror line too and more of the complex cons'.
    tried the subdiv' tools but they all still have one directions line and not two sides.
    what do you say ?
    look for us on facebook : creatioIL
      Maybe this Extrude Edges by rail to lattice by Tig ?
      • Y Offline
        yitzhar
        i have tried lattice by tig its little bit hard to under stand and to get that shapes ...
        i need to have the shape as it shown on the pictures under the glass ... the metals ?
        someone can give me and other tutorial please?
        thank you
          gilles
          Something like this?
          FredoScale http://sketchucation.com/forums/viewtopic.php?t=42089
          FFD http://sketchucation.com/forums/viewtopic.php?t=6029#p36127
          leaning-building.skp
          • Y Offline
            yitzhar
            YES, this is exactly what i ment (to directions for the line)
            please can you give little more details on how excactly you did it ?
            thank you
              gilles
              Just drawn two floors, copy, deform with Fredo's taper and Cphillips FFD.
              Did you open the file?
              Pour Pilou avant réclamation.
              • Y Offline
                yitzhar
                the problem is with the lines and not with the curve shape...
                i know how to make the twist but not the constr' lines that you showed in your file.
                its look like trinangle shapes on the faces and on your file its look like 2 trin' on same shape
                  gilles
                  I just drawn them in the first step, not a big deal.
                    DOD3R
                    Hi guys,
                    Its possible to make it from same triangles?
                    So it would be easier to prefabricate and construct (one triangular window)?
                    • Y Offline
                      yitzhar
                      i find out that the easy way was -
                      draw the edges curves and than use this Extrude Edges by rail to lattice by Tig
                      but this is if you only work with face and not circuls ..
                        DOD3R
                        could it be done with one component? for example I make some crazy geometry and than triangle component. Is there any way how, to make that geometry from one triangular component?
                          • The vertical and horizontal cross-sections of the tower are all unique.
                          • There is an asymmetric shape – no two rooms are the same. Every one of the 12,500 panes of glass on the façade is a different size, although each pane is triangular.
                          • All 8,250 steel diagrid members are different thicknesses, length and orientation.
                          more here:
                          http://www.ctbuh.org/TallBuildings/FeaturedTallBuildings/CapitalGateTowerAbuDhabi/tabid/3380/language/en-GB/Default.aspx
                          • Y Offline
                            yitzhar
                            jaff so whats your way for modeling that ?
                              DOD3R
                              LSS toolbar looks great, but didnt try it yet.
                                Jeff so whats your way for modeling that ?
                                I am affraid that you must draw one by one!
                                If you want make "a real copycat" of course 😄
                                • Y Offline
                                  yitzhar
                                  the lss tools is great tool - i used it mixing it with the edges to rails -
                                  the lss for making the floors and the panes and than i took the edges to rails plugin
                                  to make the grid with glass on the curve faces.
                                  and did it twice one from the bottom up and one from up to the bottom that way you getting
                                  X SHAPES for the grid and not \ DIRECTION ...
                                    Show us some images of results 😉
                                      altab
                                      I second that.
                                        my way? i'd use rhino's paneling tools.. i mean, the paneling tools are made for this type of stuff.. why make life difficult by trying to do it in sketchup 😉
                                        2 rail sweep to get a surface..
                                        make a paneling grid..
                                        populate the grid with shape of your choice..
                                          Rhino 5?
                                          • 1 / 4
                                          1 / 4
