    [Plugin] TIG-Smart_offset
    143 Posts 55 Posters 184.3k Views 54 Watching
      @ccbiggs said:
      It works the same for me. With a face selected the drop down tools menu item will work but the single icon toolbar will not.
      Which is weird... because they BOTH use 'cmd' and share the same enabled/grayed code...
      To check that the toolbar WILL work somehow... can you please edit the file 'TIG-Smart_offset.rb' on your MAC with a plain text editor [BBedit???] and find the three lines starting at #117 reading:
      		cmd.set_validation_proc{
      			Sketchup.active_model.selection.grep(Sketchup;;Face)[0] ? MF_ENABLED ; MF_GRAYED
      and change them to read
      		#cmd.set_validation_proc{
      			#Sketchup.active_model.selection.grep(Sketchup;;Face)[0] ? MF_ENABLED ; MF_GRAYED
      i.e. add a # in front of each of the three lines to disable them.
      Now the tool's command should always be 'enabled' in the menu & the toolbar button, if you try to use it without a Face in the Selection you'll get an error messagebox...
      Let me know how this goes...
      Incidentally, BEFORE [& after] you make the changes... do you get the tool's context-menu item IF there's a Face in the Selection ?
      • jeff hammondJ Offline
        that does the trick.. the toolbar is always active now and i'll just receive an error if i try to run the tool without an appropriate selection..
        [context menu works also.. but it worked prior to disabling the above lines]
          OK !
          The current tool [v1.3] works just fine for PCs... but it baulks on a MAC with some of the enable/grayed code for the toolbar button - which is weird... ๐Ÿ˜•
          The editing of the three lines of code in the script to disable them with a leading #... as indicated in the preceding posts... will fix it for MAC users...
          I'll see if I can get a version working properly for PC and MAC without this cludge ! ๐Ÿ˜ž
          In the meantime, please report any issues...
          Merry Xmas ๐Ÿ˜„
          Apocalypse averted! ๐Ÿ˜›
          Phew! ๐Ÿ˜‰
          • simon le bonS Offline
            simon le bon
            Thank you for this one really "smart" dear TIG +++
            We were used to the quirks of the native offset tool as a fatality. It is a surprise to realize that it was not the case ๐Ÿ˜ฎ ๐Ÿ˜ฎ ๐Ÿ˜ฎ
            Merry Christmas to you too ๐Ÿ˜
            Simon
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/TIG-Smart_offsetv1320121221.jpg
              driven
              I posted this on the first page and it will work on both?
              set validation doesn't seem to work on macs on Toolbars
              cmd2=UI;;Command.new('TIG.Smart_offset'){self.dialog()}
              cmd2.small_icon=File.join(dir, 'TIG-Smart_offset.png')
              cmd2.large_icon=File.join(dir, 'TIG-Smart_offset.png')
              toolbar=UI;;Toolbar.new('TIG.Smart_offset')
              toolbar.add_item(cmd2)
                Here's v1.4 http://sketchucation.com/forums/viewtopic.php?p=446462#p446462
                It now only applies toolbar enabled/grayed [validation] on PCs; on a MAC the toolbar button is always enabled, but when you attempt to use it without a suitable preselection there's an error-messagebox...
                This now means PC and MAC users should have a quite similar usage ๐Ÿ˜„
                • DareDevilD Offline
                  DareDevil
                  Thanks for this advanced tool ! ๐Ÿ‘ Nice to solve round edge offset.
                  But I have a two requests :
                  First, (crossing post with Pilou ๐Ÿ˜‰) I think when the offset cross itself, there is a chance it make a hole. Your Smart Offset fill all the shape. It will be cool if your toll can solve this case.
                  The second is a bonus setting to create a round offset like this :
                  round-offset.jpgI don't know if it's "easy" to make this kind of function, perhaps crossing your offset tool and your Chamfer tool from 2D Tools.
                    From Daredevil
                    Original
                    Smart_Offest
                    Normal result wished
                    http://sketchucation.com/forums/download/file.php?id=98395&mode=view/rokbox.jpg
                      DareDevil/Pilou
                      I had been following your discussions about this in the French forum...
                      I know what you are asking for, but it is very complicated to come up with an algorithm to remove the 'hole' - it's easy for us to 'see' what's to go and what's to stay, but in code it is very complicated to ensure that the unwanted parts are removed.
                      If anyone has any ideas [even seemingly silly ones?] I am open to suggestions...
                      On the 'rounded corner' matter... This effectively a 'multi-fillet' tool.
                      The main issue I see in you'd need to select just the edges to fillet and not a face, otherwise in the case you illustrated the already curved part would potentially get 'multi-filleted'...
                      That's x6 clicks to select the ones needed with a new tool - or x2 to select face & its-edges, then x2+Ctrl+Shift to remove the face and the unwanted arc [or +x1 click to make a fence, e.g. for an 'arc' made from exploded edges...] - say x4 or x5...
                      OR using the existing 2dFillet tool x2 per vertex = x10 clicks.
                      But are your few extra clicks worth my lost brain-cells needed to contrive this wonder ?
                        For the multi fillet
                        Surely not but don't forget the pleasure to find the solution! ๐Ÿ˜‰
                        • N Offline
                          numerobis
                          WOW!!! This is really helpful! Great! Thank you very much!!! ๐Ÿ˜Ž
                          And Merry Christmas to you too! ๐Ÿ˜„
                          • takesh hT Offline
                            takesh h
                            "Smart TIG" offsets indeed!
                              that pleasure would be nothing compared to the pleasure experienced by figuring this one out ๐Ÿ˜†
                              the inner pie was offset on both.. sketchup offset gives the result on the left.. the right one is how it should be.. (and besides.. TIG-Genius_offset.rb has a nice ring to it : )
                                rv1974
                                TIG, marry Xmas and thank you for this great present.
                                P.S. Could you take a look at attached?
                                P.P.S. a. It'd be neat if this tool was mode-less (I mean replicating the native SU behavior)
                                b. a number of offset option???
                                some segments offset wrong way
                                • jolranJ Offline
                                  jolran
                                  Thank you TIG and Merry Christmas!
                                  This one is a difficult task.
                                  • JClementsJ Offline
                                    JClements
                                    Thank you, Santa TIG. Milk and cookies will await you Xmas morning. ๐Ÿ˜„
                                    Any chance of having:
                                    1- a "Weld Offset" option button in the dialog
                                    or
                                    2- have the offset automatically welded if its source-edges were made from the circle, arch, polygon tools or previously "welded" edges?
                                    Regards, John
                                      matt.gordon320
                                      Thanks TIG! I don't think I could have asked for a better Christmas/World not ending present!
                                      • PixeroP Offline
                                        Pixero
                                        Thanks for this great plugin.
                                        Would it be very difficult to have it work as an interactive tool also using the measurement toolbar instead of the pop up window so it can replace the native tool all together?
                                          Here's v1.5 http://sketchucation.com/forums/viewtopic.php?p=446462#p446462
                                          There's some code improvements and fewer fails etc.
                                          Some of the requested changes like 'holes', welded-outlines and VCB input will have to wait...
                                          Merry Xmas... ๐Ÿ˜„
                                          • fredo6F Offline
                                            Pixero,
                                            Then you can use Offset on Surfacewhich shows interactively the offset profile and allow to type the offset distance in the VCB. Still many glitches with convoluted contours however.
                                            • 3 / 8
