    [Plugin] TIG-Smart_offset
    143 Posts 55 Posters 186.5k Views 54 Watching
      From Daredevil
      Original
      Smart_Offest
      Normal result wished
      http://sketchucation.com/forums/download/file.php?id=98395&mode=view/rokbox.jpg
        DareDevil/Pilou
        I had been following your discussions about this in the French forum...
        I know what you are asking for, but it is very complicated to come up with an algorithm to remove the 'hole' - it's easy for us to 'see' what's to go and what's to stay, but in code it is very complicated to ensure that the unwanted parts are removed.
        If anyone has any ideas [even seemingly silly ones?] I am open to suggestions...
        On the 'rounded corner' matter... This effectively a 'multi-fillet' tool.
        The main issue I see in you'd need to select just the edges to fillet and not a face, otherwise in the case you illustrated the already curved part would potentially get 'multi-filleted'...
        That's x6 clicks to select the ones needed with a new tool - or x2 to select face & its-edges, then x2+Ctrl+Shift to remove the face and the unwanted arc [or +x1 click to make a fence, e.g. for an 'arc' made from exploded edges...] - say x4 or x5...
        OR using the existing 2dFillet tool x2 per vertex = x10 clicks.
        But are your few extra clicks worth my lost brain-cells needed to contrive this wonder ?
          For the multi fillet
          Surely not but don't forget the pleasure to find the solution! ๐Ÿ˜‰
          • N Offline
            numerobis
            WOW!!! This is really helpful! Great! Thank you very much!!! ๐Ÿ˜Ž
            And Merry Christmas to you too! ๐Ÿ˜„
            • takesh hT Offline
              takesh h
              "Smart TIG" offsets indeed!
              • jeff hammondJ Offline
                that pleasure would be nothing compared to the pleasure experienced by figuring this one out ๐Ÿ˜†
                the inner pie was offset on both.. sketchup offset gives the result on the left.. the right one is how it should be.. (and besides.. TIG-Genius_offset.rb has a nice ring to it : )
                  rv1974
                  TIG, marry Xmas and thank you for this great present.
                  P.S. Could you take a look at attached?
                  P.P.S. a. It'd be neat if this tool was mode-less (I mean replicating the native SU behavior)
                  b. a number of offset option???
                  some segments offset wrong way
                  • jolranJ Offline
                    jolran
                    Thank you TIG and Merry Christmas!
                    This one is a difficult task.
                    • JClementsJ Offline
                      JClements
                      Thank you, Santa TIG. Milk and cookies will await you Xmas morning. ๐Ÿ˜„
                      Any chance of having:
                      1- a "Weld Offset" option button in the dialog
                      or
                      2- have the offset automatically welded if its source-edges were made from the circle, arch, polygon tools or previously "welded" edges?
                      Regards, John
                        matt.gordon320
                        Thanks TIG! I don't think I could have asked for a better Christmas/World not ending present!
                        • PixeroP Offline
                          Pixero
                          Thanks for this great plugin.
                          Would it be very difficult to have it work as an interactive tool also using the measurement toolbar instead of the pop up window so it can replace the native tool all together?
                            Here's v1.5 http://sketchucation.com/forums/viewtopic.php?p=446462#p446462
                            There's some code improvements and fewer fails etc.
                            Some of the requested changes like 'holes', welded-outlines and VCB input will have to wait...
                            Merry Xmas... ๐Ÿ˜„
                            • fredo6F Offline
                              Pixero,
                              Then you can use Offset on Surfacewhich shows interactively the offset profile and allow to type the offset distance in the VCB. Still many glitches with convoluted contours however.
                                blajnov
                                Excess loop ...
                                  @blajnov
                                  Looking at ways of minimizing this, and offsetting curves as curves...
                                  Watch this space...
                                    Here's v1.6 http://sketchucation.com/forums/viewtopic.php?p=446462#p446462
                                    Curves/Arcs are now offset as curves in the offset-outline...
                                    Speed improved.
                                    Glitches avoided.
                                    A Very Extra-Merry Xmas to you all... ๐Ÿ˜„
                                      JClements
                                      Santa never rests. โ˜€
                                      • micioneM Offline
                                        micione
                                        TIG,
                                        this, in the latest version (1.6) of your very useful tool.
                                        (windows 7 - Last Updated SketchUp).
                                        regards,
                                        Roberto
                                          blajnov
                                          Error Again
                                            rv1974
                                            @blajnov said:
                                            Error Again
                                            the 48.4 dimension was not taken 'legitimately' (you should measure from the center of the arch segment perpendicular to offset segment)
                                            • 3 / 8
