    [Plugin] TIG-Smart_offset
    143 Posts 55 Posters 181.3k Views 54 Watching
    • jeff hammondJ Offline
      @chris fullmer said:
      voodoo. definitely voodoo at work here.
      ha.. that darn voodoo! 😄
      some more info:
      so here's what the deal with the toolbar is.. (in this example, i have 3 squares with faces drawn)
      •cmmdA (select all)
      •toolbar remains greyed out (menu item is live)
      •do something else (rotate, pan, etc)
      •toolbar becomes active
      •deselect all
      •toolbar remains active (menu item greys out)
      •do something else (switch tool, orbit, etc)
      •toolbar greys out
      so it appears, on mac, that something has to happen other than simply selecting in order to jump start the toolbar into updating it's state
        ccbiggs
        Hey Tig,
        I am getting the same thing Jeff has. But since Jeff actually knows what he is doing, he can do the ruby troubleshooting. Will stay tuned to see what you fellas figure out.
        It works great on my windows machine at home.
        Thanks Tig
        Update
        Jeff says his works. It does not work on my mac.
        with nothing preselected TIG::Smart_offsetter.suitable?()
        false
        with one edge preselected TIG::Smart_offsetter.suitable?()
        false
        with one face preselected TIG::Smart_offsetter.suitable?()
        true
        with lots of things [including some edges] preselected TIG::Smart_offsetter.suitable?()
        true
        with one edge preselected TIG::Smart_offsetter.dialog()
        TIG.Smart_offset:
        PreSelect Face[s] !
        with one face preselected TIG::Smart_offsetter.dialog()
        Offset [+/-ve=out/
        My drop down "Tools" Menu works with a face preselected. The toolbar does not.
        Nothing works with just edges selected.
        If you need me to check anything else, and I do not get right back to ya, I am not ignoring you I am just here there and everywhere today.
          Here's v1.3 http://sketchucation.com/forums/viewtopic.php?p=446462#p446462
          Removed 'suitable?' method, to suit MACs, more error traps etc.
          Try this and report back... 😒
            ccbiggs
            It works the same for me. With a face selected the drop down tools menu item will work but the single icon toolbar will not.
              Which is weird... because they BOTH use 'cmd' and share the same enabled/grayed code...
              To check that the toolbar WILL work somehow... can you please edit the file 'TIG-Smart_offset.rb' on your MAC with a plain text editor [BBedit???] and find the three lines starting at #117 reading:
              		cmd.set_validation_proc{
              			Sketchup.active_model.selection.grep(Sketchup;;Face)[0] ? MF_ENABLED ; MF_GRAYED
              and change them to read
              		#cmd.set_validation_proc{
              			#Sketchup.active_model.selection.grep(Sketchup;;Face)[0] ? MF_ENABLED ; MF_GRAYED
              i.e. add a # in front of each of the three lines to disable them.
              Now the tool's command should always be 'enabled' in the menu & the toolbar button, if you try to use it without a Face in the Selection you'll get an error messagebox...
              Let me know how this goes...
              Incidentally, BEFORE [& after] you make the changes... do you get the tool's context-menu item IF there's a Face in the Selection ?
                that does the trick.. the toolbar is always active now and i'll just receive an error if i try to run the tool without an appropriate selection..
                [context menu works also.. but it worked prior to disabling the above lines]
                  OK !
                  The current tool [v1.3] works just fine for PCs... but it baulks on a MAC with some of the enable/grayed code for the toolbar button - which is weird... 😕
                  The editing of the three lines of code in the script to disable them with a leading #... as indicated in the preceding posts... will fix it for MAC users...
                  I'll see if I can get a version working properly for PC and MAC without this cludge ! 😞
                  In the meantime, please report any issues...
                  Merry Xmas 😄
                  Apocalypse averted! 😛
                  Phew! 😉
                  • simon le bonS Offline
                    simon le bon
                    Thank you for this one really "smart" dear TIG +++
                    We were used to the quirks of the native offset tool as a fatality. It is a surprise to realize that it was not the case 😮 😮 😮
                    Merry Christmas to you too 😍
                    Simon
                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/TIG-Smart_offsetv1320121221.jpg
                      driven
                      I posted this on the first page and it will work on both?
                      set validation doesn't seem to work on macs on Toolbars
                      cmd2=UI;;Command.new('TIG.Smart_offset'){self.dialog()}
                      cmd2.small_icon=File.join(dir, 'TIG-Smart_offset.png')
                      cmd2.large_icon=File.join(dir, 'TIG-Smart_offset.png')
                      toolbar=UI;;Toolbar.new('TIG.Smart_offset')
                      toolbar.add_item(cmd2)
                        Here's v1.4 http://sketchucation.com/forums/viewtopic.php?p=446462#p446462
                        It now only applies toolbar enabled/grayed [validation] on PCs; on a MAC the toolbar button is always enabled, but when you attempt to use it without a suitable preselection there's an error-messagebox...
                        This now means PC and MAC users should have a quite similar usage 😄
                        • DareDevilD Offline
                          DareDevil
                          Thanks for this advanced tool ! 👍 Nice to solve round edge offset.
                          But I have a two requests :
                          First, (crossing post with Pilou 😉) I think when the offset cross itself, there is a chance it make a hole. Your Smart Offset fill all the shape. It will be cool if your toll can solve this case.
                          The second is a bonus setting to create a round offset like this :
                          round-offset.jpgI don't know if it's "easy" to make this kind of function, perhaps crossing your offset tool and your Chamfer tool from 2D Tools.
                            From Daredevil
                            Original
                            Smart_Offest
                            Normal result wished
                            http://sketchucation.com/forums/download/file.php?id=98395&mode=view/rokbox.jpg
                              DareDevil/Pilou
                              I had been following your discussions about this in the French forum...
                              I know what you are asking for, but it is very complicated to come up with an algorithm to remove the 'hole' - it's easy for us to 'see' what's to go and what's to stay, but in code it is very complicated to ensure that the unwanted parts are removed.
                              If anyone has any ideas [even seemingly silly ones?] I am open to suggestions...
                              On the 'rounded corner' matter... This effectively a 'multi-fillet' tool.
                              The main issue I see in you'd need to select just the edges to fillet and not a face, otherwise in the case you illustrated the already curved part would potentially get 'multi-filleted'...
                              That's x6 clicks to select the ones needed with a new tool - or x2 to select face & its-edges, then x2+Ctrl+Shift to remove the face and the unwanted arc [or +x1 click to make a fence, e.g. for an 'arc' made from exploded edges...] - say x4 or x5...
                              OR using the existing 2dFillet tool x2 per vertex = x10 clicks.
                              But are your few extra clicks worth my lost brain-cells needed to contrive this wonder ?
                                For the multi fillet
                                Surely not but don't forget the pleasure to find the solution! 😉
                                • N Offline
                                  numerobis
                                  WOW!!! This is really helpful! Great! Thank you very much!!! 😎
                                  And Merry Christmas to you too! 😄
                                  • takesh hT Offline
                                    takesh h
                                    "Smart TIG" offsets indeed!
                                      that pleasure would be nothing compared to the pleasure experienced by figuring this one out 😆
                                      the inner pie was offset on both.. sketchup offset gives the result on the left.. the right one is how it should be.. (and besides.. TIG-Genius_offset.rb has a nice ring to it : )
                                        rv1974
                                        TIG, marry Xmas and thank you for this great present.
                                        P.S. Could you take a look at attached?
                                        P.P.S. a. It'd be neat if this tool was mode-less (I mean replicating the native SU behavior)
                                        b. a number of offset option???
                                        some segments offset wrong way
                                        • jolranJ Offline
                                          jolran
                                          Thank you TIG and Merry Christmas!
                                          This one is a difficult task.
                                          • JClementsJ Offline
                                            JClements
                                            Thank you, Santa TIG. Milk and cookies will await you Xmas morning. 😄
                                            Any chance of having:
                                            1- a "Weld Offset" option button in the dialog
                                            or
                                            2- have the offset automatically welded if its source-edges were made from the circle, arch, polygon tools or previously "welded" edges?
                                            Regards, John
                                            • 3 / 8
