    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 608.7k Views 92 Watching
      would putting part of the model on a different layer and hiding it help to get only one surface's verts?
      I was about to say no - but then gave it a second thought and tried it. And yes, it works. Hiding the geometry you don't want affected will prevent them from being affected by soft-selection. πŸ˜„
      I think I might have to add that to the FAQ. Nice trick.
      @cotty said:
      Should a "Select only visible" does help anyway to reduce the selection?
      No - it would only effect selected vertices - not the soft-selection.
      • pbacotP Offline
        Just grouping the faces on the far side protects them--or am I missing the point?
        But you have to be sure your operation doesn't affect the boundary vertices or you'll have trouble getting the shape back together again.
          That is one possibility, yes. But as you mention - you might end up with not being able to merge the vertices again. Simply hiding the stuff you don't want affected solves it without having to modify the mesh.
            d12dozr
            @thomthom said:
            ...I have it on my list to implement a soft-selection that acts upon connected distance that would have solved your problems in this particular case...
            πŸ‘ πŸ‘ I was also wishing for this a few days ago.
            http://goo.gl/f7ooYh
            • pbacotP Offline
              OH, now I see! It somehow retains connection, even when your selection's along the boundary, but still doesn't include the hidden parts in the selection. Ingenious.
                SCF Premium members can now buy Vertex Tools for a discounted price of 16$
                • pbacotP Offline
                  Thanks TT. I already have it. How much for Bezier Surface?
                    Not sure what Bezier Surface will be priced at. But existing Vertex Tools customer will get a discount.
                    • pbacotP Offline
                      Heh, just prodding. Can't be had for any price as yet. πŸ˜‰
                      • Mistro11M Offline
                        Mistro11
                        Just bought it!!! Great plugin TT! I think my arsenal of tools is pretty beefed up now. Thanks.
                        i7-4930k @3.4/3.7GHz, 32Gb RAM, NVidia GTX 980Ti 6Gb, Windows 7 Pro 64bit
                        Structural Integrity is Not Just Physical...It's in the Design and Purpose
                          πŸ˜„ Yea. It's taking its time. At the moment I'm rewriting a piece of the core which require some larger changes affecting everything. Once it's complete it should allow me to work on the UI features and tools.
                            πŸ‘ πŸ‘ πŸ˜„
                            • panixiaP Offline
                              panixia
                              i have to model a couple terrific of old sofa/chairs and tried to figure out how to do this.. at the end i managed to do this without using neither vray displacement or artisan/blender wathever subdivision modeling.. just the combination of your brilliant mesh from eightmap plugin and of course VT.. faster and more effective than whatever i could dream of..
                              this is a fast draft anyway, i plan to try a better one, but so far way better and easier than i expected at first.
                              once again, thank you..
                              • panixiaP Offline
                                panixia
                                just forgot to upload the file.. 😳
                                  That's looking mighty nice! And mighty heavy. Got a pure wireframe screenshot?
                                  I'm curious to how you worked this. How did you combine the mesh from Mesh from Heighmap into this sofa?
                                  • panixiaP Offline
                                    panixia
                                    in a pure grey hdr + infinte plane it renders quite fast in vray, few minutes with mediun settings at 2000x1666.. i will try it in a fully lihtened and reflective context to see what appens, i think.
                                    feel free to use this model for anything you like. (maibe doing a rendering of your granny house.. duh) πŸ˜„
                                    edit - the model is slightly more than 4mb and i have never create an account or uploaded something in sketchup wharehouse, so you can download the model from here:
                                    http://www.2shared.com/file/gZ9Jkupc/GRANNYS_SOFA.html
                                    hope it work, let me know..
                                      That's a nice sample model for me to use when testing Vertex Tools performance. Lots of vertices. And Soft-Selection rainbow looks pretty. πŸ˜„
                                      Mind if I show it off as a user example for Vertex Tools?
                                      • panixiaP Offline
                                        panixia
                                        mind? what? i would be relly proud man! 😲
                                          Sweet! πŸ˜„
                                          If you make more of these I'd love to see some work in progress that display the steps and actions. It'd be really nice to show this on the Vertex Tools site and G+ galleries.
                                          • panixiaP Offline
                                            panixia
                                            i will surely do it, i don't know exactly, but in the next days i think.. they should be part of an house rebuilt were they want to preserve the granny's sofa and harmachairs πŸ˜’
                                            the actual render should be done after christmas as far as iknow, but in the meanwhile i'm studing this monster furniture in the spare time.. you never know..
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 33
                                            • 34
                                            • 15 / 34
