    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 433.2k Views 92 Watching
      @pixero said:
      your nurbs plugin sometime soon?
      I am working on Bezier Surface now that Vertex Tools 1.1 is out. It'll get the main attention until I get something working there. Then I'll see what I do next.
      • PixeroP Offline
        Pixero
        Yes, sorry Bezier Surface was what I meant.
          smicha
          I love 1.1.4. Works great! Fantastic plugin.
          Could you reveal what is "architect tools" for? And when will it be released?
            It's the updated version of Plan Tools. I've promised to release it very soon - a while ago. 😳
            • cottyC Offline
              cotty
              I'm playing around and want to select only some vertices from the front. I know the options "ignore backfaces" and "select only visible", but I'm not able to achive the desired selection...?
              vertex_visible.skp
              my SketchUp gallery
              • pbacotP Offline
                I've run across the same thing and wasn't sure what to think about it.
                • cottyC Offline
                  cotty
                  I've played a little more and noticed, that it depends on the soft radius: 30cm only selects front vertices, with 40cm the back vertices are selected too...
                  my SketchUp gallery
                  • cottyC Offline
                    cotty
                    Here are some variations...
                    my SketchUp gallery
                      Ah, yes. Soft-selection is affected by proximity of the selected vertices - not connected distance. I have it on my list to implement a soft-selection that acts upon connected distance that would have solved your problems in this particular case. Unfortunately that doesn't help you now. 😞
                      • panixiaP Offline
                        panixia
                        nice! i was here to do the same exact request because i just modeled an hanging cloth and found that having an option of "only connected" for soft selection would be really cool.. i know 3dstudio max has a sort of cloth simulator, but i find 3dsmax is.. how can i say.. a "bit more expensive" than your tool.. πŸ˜„
                        oh.. and "merge to point" rules!!! go for it!
                        • opalO Offline
                          opal
                          would putting part of the model on a different layer and hiding it help to get only one surface's verts?
                          • cottyC Offline
                            cotty
                            No (urgent) problem because I'm only playing around πŸ˜‰
                            Should a "Select only visible" does help anyway to reduce the selection?
                            Yes, a selection with no soft selection (r=0) and grouping these vertices for soft selection is a workaround...
                            my SketchUp gallery
                              I was about to say no - but then gave it a second thought and tried it. And yes, it works. Hiding the geometry you don't want affected will prevent them from being affected by soft-selection. πŸ˜„
                              I think I might have to add that to the FAQ. Nice trick.
                              No - it would only effect selected vertices - not the soft-selection.
                              • pbacotP Offline
                                Just grouping the faces on the far side protects them--or am I missing the point?
                                But you have to be sure your operation doesn't affect the boundary vertices or you'll have trouble getting the shape back together again.
                                  That is one possibility, yes. But as you mention - you might end up with not being able to merge the vertices again. Simply hiding the stuff you don't want affected solves it without having to modify the mesh.
                                    d12dozr
                                    @thomthom said:
                                    ...I have it on my list to implement a soft-selection that acts upon connected distance that would have solved your problems in this particular case...
                                    πŸ‘ πŸ‘ I was also wishing for this a few days ago.
                                    http://goo.gl/f7ooYh
                                    • pbacotP Offline
                                      OH, now I see! It somehow retains connection, even when your selection's along the boundary, but still doesn't include the hidden parts in the selection. Ingenious.
                                        SCF Premium members can now buy Vertex Tools for a discounted price of 16$
                                        • pbacotP Offline
                                          Thanks TT. I already have it. How much for Bezier Surface?
                                            Not sure what Bezier Surface will be priced at. But existing Vertex Tools customer will get a discount.
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 33
                                            • 34
                                            • 15 / 34
