    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 655.8k Views 92 Watching
    • cottyC
      cotty
      @cotty said:
      I've played a little more and noticed, that it depends on the soft radius: 30cm only selects front vertices, with 40cm the back vertices are selected too...
      Here are some variations...
      my SketchUp gallery
        Ah, yes. Soft-selection is affected by proximity of the selected vertices - not connected distance. I have it on my list to implement a soft-selection that acts upon connected distance that would have solved your problems in this particular case. Unfortunately that doesn't help you now. 😞
        • panixiaP
          panixia
          nice! i was here to do the same exact request because i just modeled an hanging cloth and found that having an option of "only connected" for soft selection would be really cool.. i know 3dstudio max has a sort of cloth simulator, but i find 3dsmax is.. how can i say.. a "bit more expensive" than your tool.. πŸ˜„
          oh.. and "merge to point" rules!!! go for it!
          • opalO
            opal
            would putting part of the model on a different layer and hiding it help to get only one surface's verts?
            • cottyC
              cotty
              No (urgent) problem because I'm only playing around πŸ˜‰
              Should a "Select only visible" does help anyway to reduce the selection?
              Yes, a selection with no soft selection (r=0) and grouping these vertices for soft selection is a workaround...
              my SketchUp gallery
                I was about to say no - but then gave it a second thought and tried it. And yes, it works. Hiding the geometry you don't want affected will prevent them from being affected by soft-selection. πŸ˜„
                I think I might have to add that to the FAQ. Nice trick.
                No - it would only effect selected vertices - not the soft-selection.
                • pbacotP
                  Just grouping the faces on the far side protects them--or am I missing the point?
                  But you have to be sure your operation doesn't affect the boundary vertices or you'll have trouble getting the shape back together again.
                    That is one possibility, yes. But as you mention - you might end up with not being able to merge the vertices again. Simply hiding the stuff you don't want affected solves it without having to modify the mesh.
                      d12dozr
                      @thomthom said:
                      ...I have it on my list to implement a soft-selection that acts upon connected distance that would have solved your problems in this particular case...
                      πŸ‘ πŸ‘ I was also wishing for this a few days ago.
                      http://goo.gl/f7ooYh
                      • pbacotP
                        OH, now I see! It somehow retains connection, even when your selection's along the boundary, but still doesn't include the hidden parts in the selection. Ingenious.
                          SCF Premium members can now buy Vertex Tools for a discounted price of 16$
                          • pbacotP
                            Thanks TT. I already have it. How much for Bezier Surface?
                              Not sure what Bezier Surface will be priced at. But existing Vertex Tools customer will get a discount.
                              • pbacotP
                                Heh, just prodding. Can't be had for any price as yet. πŸ˜‰
                                • Mistro11M
                                  Mistro11
                                  Just bought it!!! Great plugin TT! I think my arsenal of tools is pretty beefed up now. Thanks.
                                  Structural Integrity is Not Just Physical...It's in the Design and Purpose
                                    πŸ˜„ Yea. It's taking its time. At the moment I'm rewriting a piece of the core which require some larger changes affecting everything. Once it's complete it should allow me to work on the UI features and tools.
                                      πŸ‘ πŸ‘ πŸ˜„
                                      • panixiaP
                                        panixia
                                        i have to model a couple terrific of old sofa/chairs and tried to figure out how to do this.. at the end i managed to do this without using neither vray displacement or artisan/blender wathever subdivision modeling.. just the combination of your brilliant mesh from eightmap plugin and of course VT.. faster and more effective than whatever i could dream of..
                                        this is a fast draft anyway, i plan to try a better one, but so far way better and easier than i expected at first.
                                        once again, thank you..
                                        • panixiaP
                                          panixia
                                          just forgot to upload the file.. 😳
                                            That's looking mighty nice! And mighty heavy. Got a pure wireframe screenshot?
                                            I'm curious to how you worked this. How did you combine the mesh from Mesh from Heighmap into this sofa?
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 33
                                            • 34
                                            • 15 / 34
