    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 655.8k Views 92 Watching
      smicha
      I love 1.1.4. Works great! Fantastic plugin.
      Could you reveal what is "architect tools" for? And when will it be released?
        It's the updated version of Plan Tools. I've promised to release it very soon - a while ago. 😳
        • cottyC
          cotty
          I'm playing around and want to select only some vertices from the front. I know the options "ignore backfaces" and "select only visible", but I'm not able to achive the desired selection...?
          vertex_visible.skp
          my SketchUp gallery
          • pbacotP
            I've run across the same thing and wasn't sure what to think about it.
            • cottyC
              cotty
              I've played a little more and noticed, that it depends on the soft radius: 30cm only selects front vertices, with 40cm the back vertices are selected too...
              my SketchUp gallery
              • cottyC
                cotty
                Here are some variations...
                my SketchUp gallery
                  Ah, yes. Soft-selection is affected by proximity of the selected vertices - not connected distance. I have it on my list to implement a soft-selection that acts upon connected distance that would have solved your problems in this particular case. Unfortunately that doesn't help you now. 😞
                  • panixiaP
                    panixia
                    nice! i was here to do the same exact request because i just modeled an hanging cloth and found that having an option of "only connected" for soft selection would be really cool.. i know 3dstudio max has a sort of cloth simulator, but i find 3dsmax is.. how can i say.. a "bit more expensive" than your tool.. πŸ˜„
                    oh.. and "merge to point" rules!!! go for it!
                    • opalO
                      opal
                      would putting part of the model on a different layer and hiding it help to get only one surface's verts?
                      • cottyC
                        cotty
                        No (urgent) problem because I'm only playing around πŸ˜‰
                        Should a "Select only visible" does help anyway to reduce the selection?
                        Yes, a selection with no soft selection (r=0) and grouping these vertices for soft selection is a workaround...
                        my SketchUp gallery
                          I was about to say no - but then gave it a second thought and tried it. And yes, it works. Hiding the geometry you don't want affected will prevent them from being affected by soft-selection. πŸ˜„
                          I think I might have to add that to the FAQ. Nice trick.
                          No - it would only effect selected vertices - not the soft-selection.
                          • pbacotP
                            Just grouping the faces on the far side protects them--or am I missing the point?
                            But you have to be sure your operation doesn't affect the boundary vertices or you'll have trouble getting the shape back together again.
                              That is one possibility, yes. But as you mention - you might end up with not being able to merge the vertices again. Simply hiding the stuff you don't want affected solves it without having to modify the mesh.
                                d12dozr
                                @thomthom said:
                                ...I have it on my list to implement a soft-selection that acts upon connected distance that would have solved your problems in this particular case...
                                πŸ‘ πŸ‘ I was also wishing for this a few days ago.
                                http://goo.gl/f7ooYh
                                • pbacotP
                                  OH, now I see! It somehow retains connection, even when your selection's along the boundary, but still doesn't include the hidden parts in the selection. Ingenious.
                                    SCF Premium members can now buy Vertex Tools for a discounted price of 16$
                                    • pbacotP
                                      Thanks TT. I already have it. How much for Bezier Surface?
                                        Not sure what Bezier Surface will be priced at. But existing Vertex Tools customer will get a discount.
                                        • pbacotP
                                          Heh, just prodding. Can't be had for any price as yet. πŸ˜‰
                                          • Mistro11M
                                            Mistro11
                                            Just bought it!!! Great plugin TT! I think my arsenal of tools is pretty beefed up now. Thanks.
                                            Structural Integrity is Not Just Physical...It's in the Design and Purpose
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 33
                                            • 34
                                            • 15 / 34
