    [Plugin][$] Curvizard - v2.5a - 01 Apr 24
    198 Posts 58 Posters 386.9k Views 57 Watching
    • fredo6F
      @guanjin said:
      Thanks for update again, but the language translation problems still exist, thank you!
      [attachment=0:2dklo00h]<!-- ia0 -->未命名.jpg<!-- ia0 -->[/attachment:2dklo00h]
      Thanks for signaling the bug. I fixed it and will republish.
      But before I do, do you have the Curvizard_ZH.lang file so that I integrate it in the release.
      • guanjinG
        guanjin
        [attachment=0:22t88ozw]<!-- ia0 -->未命名.jpg<!-- ia0 -->[/attachment:22t88ozw]
        Dear Fredo6: Chinese language file has been sent to your mailbox, please find Thank you!
        • OxerO
          Oxer
          Thanks Fredo for the update it's very useful !! 👍
          The problem with the translation continues and missing some translations. I have done the Spanish translation (Spain) but how i say you there are missing translations.
          Thanks again Fredo.
          Spanish Language (Spain)
          • fredo6F
            Oxer,
            Thanks very much for the update.
            Note that part of the transaltion is in LibFredo
            The issue with the translation effective in the Luancher and tooltips of the main icons will be fixed in release 1.1b.
            • OxerO
              Oxer
              Thanks Fredo!!
              • fredo6F
                NEW RELEASE: Curvizard v1.1c - 29 Nov 12
                Minor release over 1.1a:
                • fix a problem in Cleanup Contour which cannot be launched
                • fix to a problem for translation for the Quick Launcher
                • Integration of Chinese translation (guanjin)
                • Update to the Spanish (Spain) translation (Oxer)
                • ArcA
                  Arc
                  Translation into Chinese...
                  Chinese language
                    smicha
                    Fredo, You are genius!!! Thank you so much for fantastic update.
                    • V
                      victor hugo
                      Pretty useful plugin!!!
                      I've downloaded the update 1.1c and installed per instructions and when I go to "Fredo tools" to "Check the Plugin Update"; Curvizard still shows in pink/red. I re-downloaded the file and it keeps saying I need to do update!!!??
                      Thanks.
                      • cottyC
                        cotty
                        1.1c or 1.1d?
                        my SketchUp gallery
                        • V
                          victor hugo
                          I had 1.1c and just did 1.1d and the attched is what is showing
                          Thanks.
                          • cottyC
                            cotty
                            You are right, it seems that in the 1.1d file "Curvizard.plugin" the version is still 1.1c ...
                            my SketchUp gallery
                            • guanjinG
                              guanjin
                              I am also, but does not affect use.
                                small08
                                Amazing work Fredo, Thank-you!
                                  matt.gordon320
                                  Hi Fredo,
                                  I was wondering if you might be able to take a look at my office's model to see what might be causing the error(s) I'm getting? I've attached both the model and the error report.
                                  Matt
                                  Master Topo Clean ERROR.skp
                                  Ruby Error - Curvizard#simplify_curve - 10-Dec-12 13_43_35.txt
                                    Matt
                                    What are you trying to do when you get the error message ?
                                    Your post is too scant. 😕
                                      matt.gordon320
                                      My apologies, my message is absolutely lacking in any detail 😳
                                      I've brought in a dwg containing topographic information from a civil consultants's office, and I'm trying to use Curvizard to simplify the contours. When I do, the interface of SketchUp pauses for a second, then comes up with an error message window containing the information in the attached text report. I can't quite figure out what the error is, or whether it's something that I introduced through cleaning up the DWG, or whether it's something that is just lost in translation from AutoCAD => SketchUp.
                                      Hope that's better 😄
                                      Matt
                                        There are lots of 'gaps' in your contours etc which are probably causing the issues.
                                        You could always draw a few lines in to heal the critical ones before doing anything else...
                                        I ran your contour-lines [without any other processing] through the Sandbox Tools > From Contours.
                                        After some processing it made a complex terrain mesh...Capture.PNGI assume this is something like you hoped for ? Perhaps you need to choose your tools... "When the only tool you have is a hammer, everything starts to look like a nail..." 😉
                                        • fredo6F
                                          The erreor 'reference to deleted vertex' may occur in some situations and not easy to fix.
                                          I suggest you use the mode "Erase and Create" rather than deform.
                                          Were you processing all (or many) contours at once?
                                            matt.gordon320
                                            After some processing it made a complex terrain mesh...[attachment=0:28k6bpaf]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:28k6bpaf]I assume this is something like you hoped for ? Perhaps you need to choose your tools... "When the only tool you have is a hammer, everything starts to look like a nail..." 😉
                                            Yes, I tried running the "From Contours", and it worked fine, I was just trying to test the difference in file size that Fredo's tool might save. I'm pretty much the only one in the office who bothers to try to keep file size down, so I figured I'd try it.
                                            I'll try to see if "Erase and Create" will work for me. I was running all of them at once. It's my first time using the tool 😳 so I was more just testing than anything. Is running all of them at once a terrible idea, like I'm currently realizing it might be?
                                            • 3 / 10
