    [Plugin] Automatic Face Reverser
    35 Posts 32 Posters 87.0k Views 32 Watching
    • honoluludesktopH
      honoluludesktop
      Sigh.....I spent several weeks duplicating this plugin because I didn't do a good enough job searching for this one. Oh well, good practice programing.
      From the documentation, it will find faces inside components and groups, this is better then reverse_back_face, but not in interior views (reverse_back_face will). Maybe some one will come along and do both.
      • L
        lenova
        Thank you!
        • O
          orjinalp
          thanks...
            sijeljaaf
            Thank you so much but it doesn't work with my sketchup pro 8
              You have to explain how it doesn't work...
              Does it download, install, add menu entires, any error messages [on screen or in the Ruby Console?], run as expected but not reverse faces, do it sometimes work, does it work but not work as you envisaged???
              Once we have a better idea we can think about how we can resolve the issue, clearly it works for lots of people so something must be awry with your setup...
              • JVT_LTDJ
                JVT_LTD
                Many thanks to this... Its truly functional...
                • U
                  unal
                  teşekkürler:)
                  • V
                    vaaron21
                    @tig said:
                    It comes up in the plugin manager but it doesn't appear in the drop down menu for plugins.
                      If you read the PDF file that came with the plugin you would see on the third page that this plugin shows only in the context menu. It doesn't appear in Plugins or any other the other menus.
                        jorgesalros
                        Works fine, well done
                        • F
                          function
                          I'm not seeing the context menu in 2014... this plugin is great!
                          • bazB
                            baz
                            Me too
                            • BoxB
                              Baz, Didiers plugins haven't been updated to work with SU2014 but some of them can be fixed. This is one of them. It's a simple edit.
                              Tig explains how here.
                              http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=12354%26amp;start=60#p513679
                                Didier has agreed that I might update some of his Plugins available from the PluginStore...
                                Please get the latest version from the PluginStore http://sketchucation.com/pluginstore?pln=Vbfr It is compatible with v2014 and v2015.
                                • E
                                  Emersonvip
                                  thanks! very good. 5 stars.
                                    m93a
                                    Automatic face reverser? Wonder how it works on a mobius strip...
                                    • boofredlayB
                                      boofredlay
                                      It would generate perpetual energy like the cat and toast in this video.
                                      • HornOxxH
                                        HornOxx
                                        Thanks for this Plugin 👍
                                        Great video - i love this physics fun 😄 😄
                                        never trust a skinny cook
                                          Sidharth ravva
                                          This does not work. I use skp pro 2018. Please include a video on how to use it.
                                          • P
                                            proem Newcomers
                                            Hi!
                                            Can someone update this plugin or recommend one with the same effect. I found Fredo tools but I don't want to install all the stuffs that I don't use.
                                            Thanks.
                                            • 2 / 2
