    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.9m Views 202 Watching
    • T
      TheIsingGuy
      When I put this into Sketchup 8, I get the following Error message:
      Error Loading File ZLoader__OnSurface.rb
      no such file to load -- LibFredo6.rb
      • GaieusG
        Please, go back to the first post and under the download section, re-read what's needed. In this case:
        "IMPORTANT: Requires to download LibFredo6 3.6 or higher if not already installed"
        Install this library as well.
          Also - the second post before your post contained the exact same question.
          • jgbJ
            jgb
            Fredo, anybody........
            What am I doing wrong here? ❓ ❓
            I've had this problem before, but solved it in a roundabout way. Messy but it worked. 🤢
            It used to work as I recall, then it didn't, but until now I just went on.
            I am trying to draw an arc on a curved surface. But the end segments of the arc bend away from the arc, (in a consistent manner every time) effectively destroying a nice arc.
            The black dotted precurve is OK, but the red lined curve distorts. I do keep the cursor on the surface or on a line on the surface, but nothing seems to work.
            I'm trying to form a contour for Curviloft to round out the edges of the flight deck on my airship.
            I have 2 complete screen-shots of the problem. If you want a SKP of the object, I'll post it.
            Arc on upper surface failed
            Arc on side surface failed
            jgb
            • fredo6F
              Joel,
              That's a big deficiency of Tools on Surface and in particular for Arc drawing when the arc is on fully on the surface. I am afraid I have no workaround quickly for that.
              • jgbJ
                jgb
                Joel,
                Kinda makes the Arc function a little less than useful, ya think??? 😮
                Is there at least a plan to fix?
                jgb
                • fredo6F
                  No immediate plan I am afraid!
                  Maybe you can extrude the surface to prolong it and draw the arc over it.
                  Possibly, send me the model so that I have a quick look.
                  • jgbJ
                    jgb
                    Don't understand what you mean to extrude the surface to prolong it.
                    Anyway, I made the curves manually and completed that portion of the model, so posting it will not be of use to you. Next time, I will save a copy of what I'm doing for you.
                    Funny thing though, ARC did work on a smaller section over 2 or 3 faces. The difference in size was significant (30 ft did not work, 20 inches did work) and I believe the segment count was different for each.
                    Tomorrow I will experiment with sizes & segments to see if there is a pattern. If there is, that should be a clue for you.
                    jgb
                    • G
                      galinette
                      Dear all,
                      First, thanks for the awesome plugins.
                      I'm trying to use Tools on Surface without success. I installed the latest 1.8a with the LibFredo6 4.6, but I have no toolbar, no menu, and nothing under preferences/extensions
                      I could install Joint Push Pull without any issue and it worked well.
                      Here is my plugins folder:
                      Thanks for help! I have to draw a pretty complicated curved building facade with openings in it, joint push/pull with curves on surfaces should do it!
                      Regards,
                      Etienne
                        Do you have FULL security permissions to the Plugins folder ?
                        Check/change in context-menu; select its icon and > Properties > Security > Edit.
                        You [and 'everyone else using SUp'] should have FULL permissions to read/write/change the Plugins, Components, Materials and Style folders - simply being an Admin is not sufficient.
                        It might be that you have got the files in the right locations/subfolders etc BUT some of Fredo's tools need to read/write log/dat files to Plugins/subfolders etc and with even the slightest limitations on the folder's permissions can stop things working. Reinstall the files after fixing the permissions to FULL in case there are residual issues...
                        What's inside the subfolder TOS_Dir_18 ?
                        But assuming it's still broken! I wouldn't expect a clash with it... but try renaming skindigo.rb to skindigo.rb! [also the 'ocean.rb' ??? what's that] and then restarting SketchUp; see if TOS appears then... Sometimes 'uncommon' scripts have unexpected results on 3rd party tools...
                        • G
                          galinette
                          I moved away skindigo.rb, skindigo dir, and ocean.rb (which is a small script I made)
                          I add my user full privileges to the plugins folder and subfolders
                          I also checked the ruby console, no errors or warnings when the plugin loads
                          • cottyC
                            cotty
                            @tig said:
                            but try renaming skindigo.rb to skindigo.rb! and restarting SketchUp; see if TOS appears then... Sometimes uncommon scripts have unexpected results on 3rd party tools...
                            I don't think that Skindigo by Whaat have to do with this, I use both without any problems ...
                            my SketchUp gallery
                              @cotty said:
                              ...I don't think that Skindigo by Whaat have to do with this, I use both without any problems ...
                              I agree that it's probably completely innocent, it was a last ditch attempt to see if there was some unexpected clash...
                              • G
                                galinette
                                Damned...
                                Could it be incompatibility with the newer version of LibFredo (4.6)?
                                By the way, I just upgraded Sketchup to 8.0.15158
                                Etienne
                                  No known issues with the latest Lib - indeed it fixed an issue...
                                  Let's backtrack...
                                  TOS is an Extension.
                                  Have you treble checked that it is not listed under Preferences > Extensions
                                  called 'Tools On Surface'.
                                  If it is then activate it by 'ticking' it.
                                  Once it's activated then you might also have to activate its toolbar from the View > Toolbars menu - called 'Tools On Surface'
                                  • G
                                    galinette
                                    Nothing like Tools on Surface in extensions. I just noticed that roundcorners is not listed as well.
                                    I used RoundCorners by the past with sketchup 7, with no issues. Recently, I reinstalled to Sketchup 8, added LibFredo, JoinPushPull, RoundCorners and Tools on Surface. Only JoinPushPull is listed and works.
                                    And of course I looked in the toolbars menu! I use plugins from quite a while, but this time it is a mess...
                                    I will try on another computer with a fresh sketchup install just in case.
                                    • G
                                      galinette
                                      Well, I deleted all plugins, re-downloaded all, everything works...
                                      Sorry for the mess
                                      Etienne
                                        Weird! 😲
                                        But at least it's fixed.
                                        Although we don't know how exactly... 😕
                                          Perhaps the problem has to do with the order of events? I've assisted several users who have Win7 and had problems getting plugins to work. They tried installing the plugin prior to setting the admin privileges for the Plugins folder correctly. Removing the .rb file from the folder and installing it anew allowed it to work.
                                          • sicksickisckS
                                            sicksickisck
                                            great plugin 😍 but I need more shapes maybe shape editor [in commercial version ]
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 31
                                            • 32
                                            • 21 / 32
