    How to create a Mask in Layout
    layout
    42 Posts 9 Posters 5.8k Views 9 Watching
      What do you mean, "what do you do?" What would you do? Could you post an example?
        You could us Fog in SKP scene-tab or a Style with depth-cues - to show them feinter.
        You could use a SectionPlane in the SKP scene-tab to hide everything towards the back of the model.
        You could make a large white grouped vertical face on a special layer that's only on in that scene-tab, locate it to obscure the back of the model.
        Or a shaped mask face overlaid in LayOut to hide them, or even made edgeless and translucent to show what's behind feinter.
        There are many ways to achieve different effects - you choose or invent one that does what you want... πŸ˜•
          penumbra
          Thanks tig. Very helpful.
          • pbacotP Offline
            Penumbra,
            In common elevations, one should be able to see background elements of the building. Here is a masterful use of fog by Sonder, in SU and LO:
            http://sketchucation.com/forums/download/file.php?id=80022&t=1
            http://sketchucation.com/forums/viewtopic.php?f=12&t=15911&p=374990#p374467
            Peter
              penumbra
              Thanks Peter, i find fog difficult to control but once is setup right, looks great.
              • bmikeB Offline
                bmike
                I find it difficult to use as well, likely operator error on my part.
                  Use [and update] scene-tabs, styles etc to 'remember' your settings for fog, layers etc
                    sonder
                    Fog is really easy to use. I set it up always in SU saved to the scene. Once you understand how the two arrows work, it is really intuitive. I like to think of the two as - right arrow = overall fog thickness - thicker as you slide to the left. Left arrow = fog depth from view point to your model - gets thinner as you slide it towards the right arrow.
                    I wish the fog in my brain were so easily controlled.
                    • bmikeB Offline
                      bmike
                      Do you need a separate style anytime you change the arrows? Or is it remembered per scene like the shadows?
                      • pbacotP Offline
                        Per Scene.
                          sonder
                          Yes, it saves with the scene when updated after adjustment.
                          • 2 / 3
