    [Plugin] [$] Artisan (1.2.3) - Feb 28, 2014
    296 Posts 95 Posters 143.3k Views 95 Watching
    • pbacotP Offline
      @whaat said:
      @pbacot said:
      Sometimes I get no results from the sculpt tool at all. However this can change when I close the model or SU and reopen. What might be the things that make this tool work better, or worse?
      Hi Peter,
      Maybe you have a mask active? If you have any edge or face selected, the sculpt tool will only affect those selected entities. I am not sure why else you would experience this.
      Dale
      Thank you, Dale, I'll keep that in mind!
      BTW is is mathematically impossible to have smooth work in vertical lock mode (like sculpt and flatten)? What do you think about a lock down setting instead of the shift key?
      Great tool. Still learning, I guess.
      Peter
      • W Offline
        Whaat
        @pbacot said:
        @whaat said:
        Hi Peter,
        Dale
        Peter
        Good suggestions, thanks! I will add them to the wishlist.
        • W Offline
          Whaat
          matsuo:
          It might help if you post the file. Also, what other plugins do you have installed?
          Try temporarily putting all other plugins in a backup folder so they don't get loaded by SU to see if that fixes things. Then, try to use process of elimination to see if one particular plugin is contributing to the bug-splat.
          Thanks.
          Dale
            matsuo_lano
            Well, I'm using a new file, so there's nothing in there that could cause problems
            Edit: I've removed all the plugins, and no more bugsplats!
            Edit 2: Reinstalled SketchUp + replaced all the outdated plugins = problem solved!
            You try to rearrange me 'till I'm sane
            • guanjinG Offline
              guanjin
              @guanjin said:
              Why do I install the free 15-day version of the display icon gray, can not be used.
              If I buy genuine worry about will not be displayed? ?
              Normal installation, but can not find the tool。
              I did something wrong
                Have you activated it in Preferences > Extensions ?
                Have you then activated its Toolbar ??
                • guanjinG Offline
                  guanjin
                  The toolbar nor any option
                    Have you 'activated' its Extension ??
                    You have not said anything about this...
                    • guanjinG Offline
                      guanjin
                      Expansion which has also activated the 😳
                        Does that mean you got it to work?
                        Your phrasing does not explain things at all...
                        • pbacotP Offline
                          A couple questions--maybe others have these issues (features?).
                          1. When I select with the sculpt select tool, the selection partially disappears (some faces become unselected) during the first sculpt operation. The full selection might be functional during the first operation, but upon completion of the operation only the remaining selection is active. Why doesn't my full selection stay until I change it? I'd like to keep working on the selected faces. [This seems to be faces along the edge of the selection, which become deselected. I find that if I then add them back in, they stay selected better?]
                          2. The sculpt circle and arrow disappears during the operation (often not always).
                          3. Here's an example of something I want to do. I would like to select an area on one side of a hard edge and bring that edge up with the selection. This sort of works, stretching the faces on the opposite side. Is there a plugin or method that would leave those far side faces in place and infill the gap? Such a method could (for example) create a vertical face with breaks top and bottom as the geometry on the selected side is raised.
                          • sicksickisckS Offline
                            sicksickisck
                            knife tool could draw faces at the intersection! 😎 [ of such an option ]
                            • mitcorbM Offline
                              mitcorb
                              @pbacot:
                              Your second item I have also seen. It may have something to do with the tool's focus and sometimes cannot find the face normal?--especially in a busy area. Sometimes zooming in and adjusting the radius has helped me. I have occasionally used -BTM's Sculpt in conjunction with Artisan while in Sketchup v7. I don't know how that one will perform in v8.
                              On your first item, does this have anything to do with the Crease Tool?
                              • pbacotP Offline
                                Thanks for the note, Tim. Never tried Sculpt. I see no pattern to my issues, but I think my new computer's speed is helping. Still they seem pretty common and troublesome--such as the loss of selections in the middle of operations.
                                I have a lot of thoughts for Artisan for shaping terrain, but meanwhile it is still a fantastic and cool tool. And that's just talking about the sculpt side. The SDS side is also mind-boggling.
                                • PixeroP Offline
                                  Pixero
                                  My one wish for Artisan is that it kept UV coordinates when subdividing and sculpting.
                                  Thomthoms Quads perhaps?
                                  • W Offline
                                    Whaat
                                    Sculpting...no
                                    Subdividing...yes - is this not working for you?
                                    • holmes1977H Offline
                                      holmes1977
                                      Im working alot more from home so using my Laptop
                                      -ASUS G74
                                      -i7 CPU @2.00Ghz
                                      -8 GB RAM
                                      -Win7 64bit
                                      SU8 Pro
                                      Im having problems with using this pluggin. I draw a simple rectangle, select the rectangle, select Subdivide selection, which divides the rectangle. I again select subdivide selection and I get a bug splat. I have tried this 10 times with the same result every time. Ive uninstalled the Artisan and re installed it, but still with the same result. This problem does not happen on my work computer. Do I need to delete all pluggins and slowly reinstall to see if there is a conflict?
                                      Exaggeration makes a dull story better.
                                      • mitcorbM Offline
                                        mitcorb
                                        Hi, holmes:
                                        Can this be anything to do with the "physical" size of the rectangle? or scale? Just asking. I don't know if that is relevant.
                                          holmes1977
                                          @mitcorb said:
                                          Hi, holmes:
                                          The rectangle is randomly about 5m by as 10m. Its really got me beat
                                            pepa
                                            @holmes1977 said:
                                            -ASUS G74
                                            -i7 CPU @2.00Ghz
                                            -8 GB RAM
                                            -Win7 64bit
                                            SU8 Pro
                                            Hi I tried instal new vray 1.6 and started exactly same issue. If are you using new vray try turn it of in extension panel or uninstall it, works for me.. maybe some ruby conflict
                                            http://jsvizualizace.daportfolio.com/
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 13 / 15
