    [Plugin Library] LibFredo6 - v16.3b - 21 Oct 26
    2.3k Posts 592 Posters 13.7m Views 594 Watching
      moshe1caspi
      In what directory i create the
      DOCUMENTATION_Dir
      itself?
        Put it in the Plugins folder. Then you'll be able to access the PDF files from the Tools menu in SketchUp
        • B
          br51
          Hi All, I am new to this forum.
          I am hoping someone would help me out here.
          I try to install the LibFredo4.6 by copy the 'LIBREDO_DIR_46 and LibFredo6.rb' into the plugin folders of SketchUp8.
          I got a pop up message:
          ""Cannot load plugin LibFredo6 because the script cannot create DEFPARM_Dir folder in: /Library/Application Support/Google SketchUp 8/SketchUp/Plugins
          Please create it manually, respecting the case""
          and another message:
          ""Error loading file LibFredo6.rb undefined method 'average_load_time' for Traductor::Plugin:Class""
          Would someone tell me what have I done wrong? Many thanks!!
            It sounds like you don't have the permissions for the Plugins folder set correctly. It needs to be set to Read and Write, not just Read Only.
            • B
              br51
              Thank you Dave R.
              I got the problem solved by removing the LibFredo6.plugin and correct all the permissions to the folders as you suggested. thanks!!
              OK, no more error messages but I dun see the plugins that I installed like RoundCorner inside sketchup8.
              They are not under any of the menu?!? I am on a Mac 10.8.
              Help please..
              screen shot of my plugins folder
                I don't suppose you ticked the boxes in Preferences>Extensions, did you?
                  MZ
                  Hello,
                  i start having right click grey menu issue after installing the plugin!! any suggestions?
                    Have you installed the latest versions of all of Fredo's tools ?
                    Many many updates ago some of them were implicated in the old gray-out issue - by making multiple 'commands' each time they were used, but they were all fixed.
                    Also ensure your other tools are all up to date too - a few others had similar issues.
                    Although I know of no current versions of any tools that do this.
                    Also, are you using the latest SketchUp v8M4 ? A couple of SketchUp updates back it 'fixed' the old gray-out issue, by greatly increasing the number of 'commands' you can have loading.
                    Since that 'fix' there have been virtually no reports of a 'gray-out' happening.
                    So you must have many hundreds of Plugins loading at startup to aggravate it again ?
                    Perhaps adding this new tool has pushed you over this maximum new limit !
                    So it begs the question, why do you have so many tools loading every time you use SketchUp?
                    I suggest that you only load those 3rd party tools that you use regularly, and deactivate the more rarely used Extensions - you can always reactivate/deactivate them as and when you need them.
                    Some simple scripts aren't Extensions and probably don't make 'commands' anyway... other rarely used 'non-Extensions' that do create 'commands' can have their loader .rb file's file-type renamed - to say .rb! - and then they won't auto-load when SketchUp starts. Incidentally, you can always manually load any of these by typing into the Ruby Console load "xxxx.rb!" - where 'xxxx' the a particular tool's file-name.
                    Having fewer Plugins loading will also speed up the SketchUp startup sequence etc...
                    If none of the above applies please advise and we'll have to come up with some other ideas πŸ˜•
                    • bazB
                      baz
                      Hi guys, slightly off topic but any idea about this?
                      I haven't changed anything I know of, it used to work fine.
                      Cheers, Baz.
                      PS: Great tip about putting help files in the DOCUMENTATION_Dir
                        Try updating LibFredo first.
                        • bazB
                          baz
                          Hi Thomthom, do you mean 'libfredo6.rb
                          PS: I don't seem to be getting notifications at the moment, so pls excuse.
                            @Baz
                            No !
                            Get the whole and very latest LibFredo version, available from the first page and install it as directed.
                            The update fixes the issue you just reported, which is caused by the changes in the SCF setup a few weeks ago...
                            • bazB
                              baz
                              Thanks Tig.
                              • B
                                BlueAngel4
                                Thanks for these plugins! 😎
                                • fredo6F
                                  NEW RELEASE: LibFredo6 v4.7a - 28 Nov 12
                                  LibFredo6 4.7a is a major release dedicated to Curvizard 1.1.
                                  • ArcA
                                    Arc
                                    update translation...
                                    Chinese language
                                    • OxerO
                                      Oxer
                                      Hi Fredo,
                                      This is the new translation for LibFredo6 Spanish (Spain) Language.
                                      LibFredo6 Spanish Language (Spain)
                                      • B
                                        ByKAz
                                        I just updated the LibFredo, FredoScale, and FredoTools. Looks like I did something wrong. I saw in br51 post at page 34 the same issue, I tried to fix it, following his post but It didn't work...
                                        Any help
                                        I'm a Mac user OSX 10.8.2 (Mountain Lion)
                                        • fredo6F
                                          You seem to have resinstalled over a fresh SU version.
                                          At least, you need to create the folder DEFPARAM_Dir manually (as indicated) because it cannot be done from the Ruby script for some security reasons.
                                            Adjust your main 'plugins' folder security permissions to FULL [read/write] for ALL and have it trickle down to all contents, subfolders too...
                                            Otherwise, you will forever be having issues installing tools into there, and also with some tools that need to write temp/log files, or to make their own subfolders etc in there...
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 115
                                            • 116
                                            • 25 / 116
