    [Plugin Library] LibFredo6 - v16.1a - 31 Aug 26
    2.2k Posts 580 Posters 6.6m Views 582 Watching
      Set it for something like 99 days.
        clownwhisper
        @chris fullmer said:
        Hi Clownwhisper, sorry its giving you such a headache. Care to elaborate a little more? What exact plugin are you trying to download?
        SketchUcation is (amongst other things) a forum, and does not have at this moment a true plugin library. So plugins are just added to forum threads like this one. For Fredo's plugins, he typically has a thread for each specific plugin, and then this thread is devoted to a standard library of files need to run all of his plugins.
        So, the first post in this thread has the zip file link, you should download that and extract it into your plugins folder. Then do the same for the specific plugin of his that you were trying to download.
        Anyhow, hope that helps. If not, help us out a little bit by saying which plugin you were trying to download. Thanks!
        I am an ASP.net programmer among other things.... You need to add popups to warn people that they need to be registered and logged in to download plugins.
        Talk about a convoluted pile of spaghetti
        wow....
          Nobody is holding a gun to your head. You don't have to be here at all. πŸ˜’
          Perhaps we should put all the plugins on the Premium side. Then everyone would get to pay to have access to them and we could afford to have a proper repository for them and the authors would all make some money for their hard work instead of just getting whiners complaining.
            I don't know... I think that the red warning at the bottom of the post tells most people enough (or - in other words - you don't have to be a programmer to figure out).
            In fact, we changed the original wording from (something like) "You do not have the required permissions to download attachments" to this (IMO) more friendly version.
            And yes, if we had (had) the proper resources, a proper plugin repository would be ready by now. True that indeed this is the downside of a free service. πŸ˜’
            • pbacotP Offline
              Well, I'll try that. I wouldn't mind it checking every 2 weeks, but it appears with the huge icon every session, not every 2 weeks.
              Peter
                Do you click on the ruby icon and then the check for Updates button? Or do you just close the ruby button?
                  To change the checking frequency use this box
                  • pbacotP Offline
                    I think I've done both. I thought checking would be automatic as per the set interval (yes I've reset the interval... I just did not set it to "every time you start SketchUp" πŸ˜’ )
                    I'll see if clicking the "Check for updates" puts it to bed until next scheduled time.
                      Yeah, you have to actually click the button to check for updates. It doesn't do it automatically. But after you do tick the button and let it check for them, it should be gone for the interval you have set.
                        moshe1caspi
                        In what directory i create the
                        DOCUMENTATION_Dir
                        itself?
                          Put it in the Plugins folder. Then you'll be able to access the PDF files from the Tools menu in SketchUp
                            br51
                            Hi All, I am new to this forum.
                            I am hoping someone would help me out here.
                            I try to install the LibFredo4.6 by copy the 'LIBREDO_DIR_46 and LibFredo6.rb' into the plugin folders of SketchUp8.
                            I got a pop up message:
                            ""Cannot load plugin LibFredo6 because the script cannot create DEFPARM_Dir folder in: /Library/Application Support/Google SketchUp 8/SketchUp/Plugins
                            Please create it manually, respecting the case""
                            and another message:
                            ""Error loading file LibFredo6.rb undefined method 'average_load_time' for Traductor::Plugin:Class""
                            Would someone tell me what have I done wrong? Many thanks!!
                              It sounds like you don't have the permissions for the Plugins folder set correctly. It needs to be set to Read and Write, not just Read Only.
                                br51
                                Thank you Dave R.
                                I got the problem solved by removing the LibFredo6.plugin and correct all the permissions to the folders as you suggested. thanks!!
                                OK, no more error messages but I dun see the plugins that I installed like RoundCorner inside sketchup8.
                                They are not under any of the menu?!? I am on a Mac 10.8.
                                Help please..
                                screen shot of my plugins folder
                                  I don't suppose you ticked the boxes in Preferences>Extensions, did you?
                                    MZ
                                    Hello,
                                    i start having right click grey menu issue after installing the plugin!! any suggestions?
                                      Have you installed the latest versions of all of Fredo's tools ?
                                      Many many updates ago some of them were implicated in the old gray-out issue - by making multiple 'commands' each time they were used, but they were all fixed.
                                      Also ensure your other tools are all up to date too - a few others had similar issues.
                                      Although I know of no current versions of any tools that do this.
                                      Also, are you using the latest SketchUp v8M4 ? A couple of SketchUp updates back it 'fixed' the old gray-out issue, by greatly increasing the number of 'commands' you can have loading.
                                      Since that 'fix' there have been virtually no reports of a 'gray-out' happening.
                                      So you must have many hundreds of Plugins loading at startup to aggravate it again ?
                                      Perhaps adding this new tool has pushed you over this maximum new limit !
                                      So it begs the question, why do you have so many tools loading every time you use SketchUp?
                                      I suggest that you only load those 3rd party tools that you use regularly, and deactivate the more rarely used Extensions - you can always reactivate/deactivate them as and when you need them.
                                      Some simple scripts aren't Extensions and probably don't make 'commands' anyway... other rarely used 'non-Extensions' that do create 'commands' can have their loader .rb file's file-type renamed - to say .rb! - and then they won't auto-load when SketchUp starts. Incidentally, you can always manually load any of these by typing into the Ruby Console load "xxxx.rb!" - where 'xxxx' the a particular tool's file-name.
                                      Having fewer Plugins loading will also speed up the SketchUp startup sequence etc...
                                      If none of the above applies please advise and we'll have to come up with some other ideas πŸ˜•
                                      • bazB Offline
                                        baz
                                        Hi guys, slightly off topic but any idea about this?
                                        I haven't changed anything I know of, it used to work fine.
                                        Cheers, Baz.
                                        PS: Great tip about putting help files in the DOCUMENTATION_Dir
                                          Try updating LibFredo first.
                                          • bazB Offline
                                            baz
                                            Hi Thomthom, do you mean 'libfredo6.rb
                                            PS: I don't seem to be getting notifications at the moment, so pls excuse.
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 111
                                            • 112
                                            • 25 / 112
