    [Plugin Library] LibFredo6 - v15.9b - 21 Apr 26
    2.2k Posts 578 Posters 4.7m Views 580 Watching
    • bazB Offline
      baz
      Hi Thomthom, do you mean 'libfredo6.rb
      PS: I don't seem to be getting notifications at the moment, so pls excuse.
        @Baz
        No !
        Get the whole and very latest LibFredo version, available from the first page and install it as directed.
        The update fixes the issue you just reported, which is caused by the changes in the SCF setup a few weeks ago...
        • bazB Offline
          baz
          Thanks Tig.
            BlueAngel4
            Thanks for these plugins! 😎
            • fredo6F Offline
              NEW RELEASE: LibFredo6 v4.7a - 28 Nov 12
              LibFredo6 4.7a is a major release dedicated to Curvizard 1.1.
              • ArcA Offline
                Arc
                update translation...
                Chinese language
                • OxerO Offline
                  Oxer
                  Hi Fredo,
                  This is the new translation for LibFredo6 Spanish (Spain) Language.
                  LibFredo6 Spanish Language (Spain)
                    ByKAz
                    I just updated the LibFredo, FredoScale, and FredoTools. Looks like I did something wrong. I saw in br51 post at page 34 the same issue, I tried to fix it, following his post but It didn't work...
                    Any help
                    I'm a Mac user OSX 10.8.2 (Mountain Lion)
                    • fredo6F Offline
                      You seem to have resinstalled over a fresh SU version.
                      At least, you need to create the folder DEFPARAM_Dir manually (as indicated) because it cannot be done from the Ruby script for some security reasons.
                        Adjust your main 'plugins' folder security permissions to FULL [read/write] for ALL and have it trickle down to all contents, subfolders too...
                        Otherwise, you will forever be having issues installing tools into there, and also with some tools that need to write temp/log files, or to make their own subfolders etc in there...
                          ByKAz
                          Yes I had expecting some SU issues, and the SU support advice me to reinstall.
                          After that I became to have installations problem that I hadn't before, but I follow all Fredo's and TIG advice and looks like it works...
                          Thanks for all your support...
                          • slocraftusS Offline
                            slocraftus
                            good plugin!!!! thank you !!! but it doesn't work in milimeters πŸ˜„DDDD
                              πŸ˜’
                              What are you talking about? What doesn't work with millimeters? The LibFredo06 files are, as described in the first post of this thread, just a shared library used by other plugins. Is it one of those plugins that you are having trouble with? I'll bet any money all of Fredo's plugins work in millimeters.
                                slocraftus
                                yep now i ve changed settings instead of 50 cm 0.5mm. anyway thanks
                                  @slocraftus
                                  πŸ˜•
                                  What are you talking about ?
                                  This is a 'Lib' thread which does nothing but help other tools work.
                                  If you have an issue with one of the related tools post in that thread.
                                  This is nonsense otherwise... πŸ˜’
                                  • fredo6F Offline
                                    I think you refer to the offset value in RoundCorner.
                                    As mentioned by TIG, this is not related to LibFredo6 itself.
                                      sellberg
                                      This is not actually a comment on the latest LibFredo6, but more of a huge THANK YOU to Fredo6 and all of the people engaged in making the RB:s that are affiliated to Fredo6! You can tell there is a lot of work put into them.
                                      These plugins are GREAT.
                                      I think intermediate and advanced users of SU really have a lot of use for these plugins. Not only are the basic ideas for the functions very good but the code is also well written and the user friendliness is high.
                                      I work with architectural design and more free-form stuff and today I almost addicted to many of these RB:s by Fredo6.
                                      (sorry for posting this here, I couldnΒ΄t figure out how to send a message directly. Hope you see this)
                                      / KJS
                                        slocraftus
                                        its good thing and works very well
                                        one question my eraser tool with ctrl also rounds corners is it because of this plugin?
                                          It doesn't round corners, it just softens edges. This is native behavior and has nothing to do with LibFredo6 or the Round Corners plugin.
                                          It sounds as if you would find this link a good thing. This, too.
                                            design54
                                            please help me, i install the latest release of libfredo and round corner, but the round corner did not work.the small toolbar that contains 3 icons appears but when i want to use it the the tallbar that contain the measurement does not appear
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 111
                                            • 112
                                            • 26 / 112
