    [Plugin] SolidSolver
    129 Posts 40 Posters 113.1k Views 40 Watching
      Anton_S
      • jgbJ Offline
        jgb
        @tig said:
        Here's v1.5 http://sketchucation.com/forums/viewtopic.php?p=359994#p359994
        it now works on groups AND component instances; makes the result unique, if needs be.
        Thanks a bunch. I'll check it on Sunday.
        jgb
          smicha
          Thank you TIG. Great work as always.
          • jgbJ Offline
            jgb
            TIG;
            Seems to work fine with comps now. Thanks for the response.
            jgb
              Bertier
              @pout said:
              Hey Tig, ...
              Hey Pout good to see you there !
              Sorry not to see you in Boulder !
                Sergio Morera
                Brilliant as usual!
                  Here's v1.6 http://sketchucation.com/forums/viewtopic.php?p=359994#p359994
                  It has:
                  • Improved internal partition removal, even when they are not full width etc.
                    [It is still fool-able though!]
                  • A context-menu item is now available if there is an appropriate selection.
                  • Its progress ... is now indicated in the status-bar.
                  • pbacotP Offline
                    Thanks TIG. This is something I am looking at daily--ways to make solids.
                    Probably an obvious idea to many: I was getting a shape that had way too many interior faces. I decided that with smoothing, I had very few outside surfaces to deal with. So I selected the outside surfaces one by one (double click) and grouped--and had a solid rather quickly, without fussing about the center.
                    Your work on this is really appreciated.
                    • cottyC Offline
                      cotty
                      Thank you for the update!
                      my SketchUp gallery
                        smicha
                        Thank you TIG.
                          Here's v1.7 http://sketchucation.com/forums/viewtopic.php?p=359994#p359994
                          It has some speed improvements.
                          It has a better/harder-to-fool internal-partition removal algorithm.
                          The removal of coplanar-edges [if any] is now a final option.
                            Here's v1.8 http://sketchucation.com/forums/viewtopic.php?p=359994#p359994
                            It has some more speed improvements.
                            It has an even better/harder-to-fool internal-partition removal algorithm.
                            You can repeat the process once if it's still not solid.
                            You may also need to try processing again 'manually' - if there are several internal-partitions facing each other etc...
                            • cottyC Offline
                              cotty
                              15 minutes between updates, that is fast 😉
                              Thank you!
                              my SketchUp gallery
                                smicha
                                Thank you!
                                Fast and accurate 😄 This is how TIG works 😄
                                Thank you again TIG.
                                • guanjinG Offline
                                  guanjin
                                  Updated version too fast, thank you
                                    Here's v1.9 http://sketchucation.com/forums/viewtopic.php?p=359994#p359994
                                    Internal partition removal is again improved, multiple parallel face to face partitions now removed [up to ~10,000 per near-normal].
                                    I have successfully tested it on several non-solids - including the dreaded 'coil' and some others with complex internal flaps and multiple partition faces, as well as holes etc...
                                    Please report any 'breakages' and supply me with an example SKP so I can see what's up...
                                    Sorry this update took so long but I had to go to the grocery store... 😉
                                      smicha
                                      • guanjinG Offline
                                        guanjin
                                        Can not fix this broken surface of the sphere!!
                                        This tool can do a very good repair。
                                        http://sketchucation.com/forums/viewtopic.php?f=323&t=48557
                                          Unfortunately that method to heal holes in a sphere creates internal partitions.
                                          I scrapped to to solve the 'coil' problem...
                                          I'll look into a reworking...
                                            Here's v2.0 http://sketchucation.com/forums/viewtopic.php?p=359994#p359994
                                            It has some improved hole healing.
                                            I have successfully tested it on several non-solids - including the dreaded 'coil', 'holey spheres' etc, and some others with complex internal flaps and multiple partition faces, as well as holes etc...
                                            Sorry this update took so long but I had to combine code from the latest version with an earlier one so that the 'coil' and 'holey spheres' are both 'solved'... 😉 😒
                                            • 2 / 7
