    [Plugin] SolidSolver
    129 Posts 40 Posters 106.0k Views 40 Watching
      smicha
      Thank you TIG.
        Here's v1.7 http://sketchucation.com/forums/viewtopic.php?p=359994#p359994
        It has some speed improvements.
        It has a better/harder-to-fool internal-partition removal algorithm.
        The removal of coplanar-edges [if any] is now a final option.
          Here's v1.8 http://sketchucation.com/forums/viewtopic.php?p=359994#p359994
          It has some more speed improvements.
          It has an even better/harder-to-fool internal-partition removal algorithm.
          You can repeat the process once if it's still not solid.
          You may also need to try processing again 'manually' - if there are several internal-partitions facing each other etc...
          • cottyC Offline
            cotty
            15 minutes between updates, that is fast πŸ˜‰
            Thank you!
            my SketchUp gallery
              smicha
              Thank you!
              Fast and accurate πŸ˜„ This is how TIG works πŸ˜„
              Thank you again TIG.
              • guanjinG Offline
                guanjin
                Updated version too fast, thank you
                  Here's v1.9 http://sketchucation.com/forums/viewtopic.php?p=359994#p359994
                  Internal partition removal is again improved, multiple parallel face to face partitions now removed [up to ~10,000 per near-normal].
                  I have successfully tested it on several non-solids - including the dreaded 'coil' and some others with complex internal flaps and multiple partition faces, as well as holes etc...
                  Please report any 'breakages' and supply me with an example SKP so I can see what's up...
                  Sorry this update took so long but I had to go to the grocery store... πŸ˜‰
                    smicha
                    πŸ‘
                    • guanjinG Offline
                      guanjin
                      Can not fix this broken surface of the sphere!!
                      This tool can do a very good repair。
                      http://sketchucation.com/forums/viewtopic.php?f=323&t=48557
                        Unfortunately that method to heal holes in a sphere creates internal partitions.
                        I scrapped to to solve the 'coil' problem...
                        I'll look into a reworking...
                          Here's v2.0 http://sketchucation.com/forums/viewtopic.php?p=359994#p359994
                          It has some improved hole healing.
                          I have successfully tested it on several non-solids - including the dreaded 'coil', 'holey spheres' etc, and some others with complex internal flaps and multiple partition faces, as well as holes etc...
                          Sorry this update took so long but I had to combine code from the latest version with an earlier one so that the 'coil' and 'holey spheres' are both 'solved'... πŸ˜‰ πŸ˜’
                          • pbacotP Offline
                            The coil ? 😲 Thanks TIG!
                            • jgbJ Offline
                              jgb
                              @pbacot said:
                              Thanks TIG. This is something I am looking at daily--ways to make solids.
                              Probably an obvious idea to many: I was getting a shape that had way too many interior faces. I decided that with smoothing, I had very few outside surfaces to deal with. So I selected the outside surfaces one by one (double click) and grouped--and had a solid rather quickly, without fussing about the center.
                              Your work on this is really appreciated.
                              NOT obvious..... A damned good idea. β˜€ β˜€ β˜€
                              (good thing I thought of it) 🀣
                              jgb
                                Bertier
                                great man TIG
                                  Ye all be donating to this lad, yes? Feed the man some cookies!
                                  • guanjinG Offline
                                    guanjin
                                    Thank you for TIG:
                                    Get a good fix on the different complex surface。
                                    • guanjinG Offline
                                      guanjin
                                      Or repair unsuccessful cube to see the animation! !
                                        Guanjin
                                        You could have course use a 'make-faces' on the cube's faces beforehand... πŸ˜’
                                        SolidSolver is intended to fix non-solids that are at least partially right !
                                        I can't see why the perforated cube fails...
                                        When I make one that looks like that it 'solidifies' just fine...***
                                        Please post/attach a SKP containing it, so that I can see better how you've configured it to break SolidSolver...
                                        ***PS: After some further tests I now suspect that it's something to do with the 'triangular hole'...
                                        I'm investigating and will post an update asap...
                                          Here's v2.1 http://sketchucation.com/forums/viewtopic.php?p=359994#p359994
                                          It has some improved hole healing - especially with certain kinds of triangular holes now made more robust.
                                          Please report any further 'breakages' and if possible supply me with an example SKP so I can see what's up... πŸ˜•
                                          • guanjinG Offline
                                            guanjin
                                            Thank TIG:
                                            Real-time updates.
                                            Test no problem, tomorrow I further tests to see if.
                                            • 2 / 7
